09-20-2005, 19:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | U8330 (R) Cid42 Brown, not supported. Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd LG 3G phone detected. Phone CID: 42 Phone color: Brown The phone is not supported. All threads terminated. There is any way to replace certificate to Red? or boot phone? TP dont work. Thx in advance. EDIT: Solved, my mistake with TP. Thx Last edited by Trixxie; 09-20-2005 at 19:15. |
09-20-2005, 19:55 | #2 (permalink) |
Member: 13748 Status: Offline Thanks Meter: 84 | New problem. Now when I try to flash phone this is the result: Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd LG 3G phone detected. Phone CID: 42 Phone color: Red Trying Red CID42 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 42 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 42 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Flash file: "Downgrade_U8330_to_U8130_V101_Unlock_by_any_code. flp" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Sending applet... Defeated! Sending applet... Baudrate = 921600Bd Analysing flash file... Replacing primary certificate... Signing... Programming flash... Time: 00:04:05 Preparing to program flash... Analysing flash file... Programming flash... Error flashing block at address: 0x21060000 All threads terminated. what can I do? Thx in advance & Best regards. |
09-21-2005, 22:48 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: albania Age: 52
Member: 22586 Status: Offline Thanks Meter: 36 | I am sure you are wrong about this bug. This error is due to low battery or damaged IC. Since phone is repaired, then your battery was low and you recharged it later. BR Mike |
09-22-2005, 00:49 | #6 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | No,no,no, I think you was make convert option to brown42. Thats I do today and phone was not supported anymore.But with TP you can make recovery certificate to cid42 and after that convert to red42 and all will be fine. wbr. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
7310 not support ?? i tried but not support. :( | kaholukkk | Universalbox | 1 | 03-13-2009 14:34 |
z550i cid 49 brown not pwr up | ricardoz | Cruiser Suite | 3 | 10-06-2006 17:47 |
W550 Only Red Supported Brown Not. | stanner_austin | HWK | 8 | 03-16-2006 09:53 |
LG U8338 CID 42 Brown.. Not supported?! | NeTRaW | Cruiser Suite | 3 | 10-01-2005 12:41 |
