10-26-2009, 10:40 | #1 (permalink) |
No Life Poster Join Date: Jan 2000 Location: NL Age: 55
Member: 847 Status: Offline Thanks Meter: 36 | Unknown server problem [256] Tried different cables, but same problem regards Sjakie Code: 10:37:33 SE S1 Flasher & Unlocker v2.13 by Cruiser Team 10:37:33 Initializing... ! 10:37:33 1. Choose the phone model ! 10:37:33 2. For flashing, select flash files and additional options ! 10:37:33 3. Double-click on the appropriate device (serial cable) ! 10:37:33 - or connect the phone via USB while holding its C button 10:37:39 Connecting via TMS Cable (COM4)… 10:37:39 Device driver version: 1.0.2154.0 10:37:39 Device driver date: 4-16-2004 ! 10:37:39 Connect the phone now 10:37:39 Connecting to the baseband CPU... 10:37:42 Entering baseband CPU service mode... 10:37:43 Phone type: T303 10:37:43 CDA info: 1222-5379 R1A 10:37:44 Phone software: 1209-8242 R2DA004 10:37:44 IMEI: 3537900xxxxxxx 10:37:44 Sending loader... 10:38:04 Reading TA… 10:38:07 Communicating with server… 10:38:11 Remainig credit (supreme): 8.31 E 10:38:12 Unknown server problem [256] E 10:38:12 Error: 0x16D3BA97 E 10:38:12 Error: 0x834ACC0E E 10:38:12 Error: 0x07F5EFDA E 10:38:12 Error: 0x51A411A0 E 10:38:12 Error: 0xB8C71F93 E 10:38:12 Error: 0x1850F89E E 10:38:12 Error: 0xCA02941A E 10:38:12 Failed! ! 10:38:12 Please disconnect battery and cable from the phone! ! 10:38:12 To report errors right-click this window |
The Following User Says Thank You to sjakie For This Useful Post: |
10-26-2009, 10:47 | #2 (permalink) |
Banned Thanks Meter: 346 | same problem for me 15:10:41 SE Ultimate Unlocker v4.10 by Cruiser Team 15:10:41 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 15:10:41 Initializing... ! 15:10:42 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 15:10:42 2. Choose the phone model ! 15:10:42 3. Select the desired options ! 15:10:42 4. Please connect the phone either via USB while holding 2-5… ! 15:10:42 - or via a serial cable and double-click on it in the device list 15:10:51 Selected phone: S500 15:10:51 Connecting via Cruiser UC-20 Cable (COM4)… 15:10:51 Device driver version: 2.4.6.0 15:10:51 Device driver date: 3-13-2008 15:10:54 Connecting to the baseband CPU... 15:10:54 Entering baseband CPU service mode... 15:10:54 Detected chipset: DB2020 15:10:54 Boot mode: ROM 15:10:54 Sending loader... 15:10:55 IMEI: 35344702570087 15:10:55 OTP CID: 51 15:10:55 Effective CID: 52 15:10:55 Restarting phone … 15:10:58 Sending loader... 15:10:58 Communicating with server… ! 15:11:00 News: Your credit consumption policy: Level 4 (Senior) 15:11:01 Remainig credit (supreme): 8.37 E 15:11:01 Error: 0xF62DDDA4 E 15:11:01 Error: 0x16D3BA97 E 15:11:01 Error: 0x834ACC0E E 15:11:01 Error: 0x51A411A0 E 15:11:01 Error: 0x78E56923 E 15:11:01 Error: 0x5C5AEBE3 E 15:11:01 Error: 0x3D35EAF1 E 15:11:01 Error: 0x07F5EFDA E 15:11:01 Unknown server problem [256] E 15:11:01 Failed! ! 15:11:01 To report errors right-click this window |
10-26-2009, 10:51 | #3 (permalink) |
No Life Poster Join Date: Sep 2003 Location: INDIA
Member: 38103 Status: Offline Sonork: 100.100782 Thanks Meter: 165 | I think something wrong at server end. Me too getting same error. Code: 15:18:07 SE Ultimate Unlocker v4.01 by Cruiser Team 15:18:07 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 15:18:07 Initializing... ! 15:18:07 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 15:18:07 2. Choose the phone model ! 15:18:07 3. Select the desired options ! 15:18:07 4. Please connect the phone either via USB while holding 2-5… ! 15:18:07 - or via a serial cable and double-click on it in the device list 15:18:10 Selected phone: W580 15:18:10 Connecting via Cruiser UC-10 Cable (COM3)… 15:18:10 Device driver version: 1.0.2154.0 15:18:10 Device driver date: 4-16-2004 15:18:11 Connecting to the baseband CPU... 15:18:11 Entering baseband CPU service mode... 15:18:11 Detected chipset: DB2020 15:18:11 Boot mode: ROM 15:18:11 Sending loader... 15:18:12 IMEI: 011572006XXXXX 15:18:12 OTP CID: 51 15:18:12 Effective CID: 52 15:18:12 Restarting phone … 15:18:14 Sending loader... 15:18:15 Communicating with server… ! 15:18:19 News: Your credit consumption policy: Level 4 (Senior) 15:18:19 Remainig credit (supreme): XX.09 E 15:18:20 Error: 0xE1E2479D E 15:18:20 Error: 0x16D3BA97 E 15:18:20 Error: 0x834ACC0E E 15:18:20 Error: 0x07F5EFDA E 15:18:20 Error: 0x51A411A0 E 15:18:20 Error: 0x78E56923 E 15:18:20 Error: 0x5C5AEBE3 E 15:18:20 Error: 0x3D35EAF1 E 15:18:20 Unknown server problem [256] E 15:18:20 Failed! ! 15:18:20 To report errors right-click this window br |
10-26-2009, 12:51 | #7 (permalink) |
Banned Thanks Meter: 346 | problem solved.thanku cruiser team 17:15:00 SE Ultimate Unlocker v4.10 by Cruiser Team 17:15:00 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:15:00 Initializing... ! 17:15:01 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:15:01 2. Choose the phone model ! 17:15:01 3. Select the desired options ! 17:15:01 4. Please connect the phone either via USB while holding 2-5… ! 17:15:01 - or via a serial cable and double-click on it in the device list 17:15:21 Selected phone: S500 17:15:21 Connecting via Generic EMP USB Flash Device (USB1)… 17:15:21 Device driver version: 2.2.0.5 17:15:21 Device driver date: 4-1-2009 17:15:22 Connecting to the baseband CPU... 17:15:22 Entering baseband CPU service mode... 17:15:22 Detected chipset: DB2020 17:15:22 Boot mode: ROM 17:15:22 Sending loader... 17:15:23 IMEI: 35344702570087 17:15:23 OTP CID: 51 17:15:23 Effective CID: 52 17:15:25 Please reconnect the phone (disconnect, connect while holding 2-5) 17:15:30 Sending loader... 17:15:30 Communicating with server… ! 17:15:32 News: Your credit consumption policy: Level 4 (Senior) 17:15:32 Remainig credit (supreme): 8.37 17:15:34 Remainig credit (supreme): 8.22 17:15:37 Please reconnect the phone (disconnect, connect while holding 2-5) 17:15:41 Sending loader... 17:15:44 Writing flash… 17:15:46 Turning off the phone... 17:15:48 Done. |
05-13-2010, 00:31 | #8 (permalink) |
Junior Member Join Date: Sep 2007
Member: 593565 Status: Offline Thanks Meter: 0 | got error while unlocking T715 Code: 01:27:19 SE Ultimate Unlocker v5.04 by Cruiser Team 01:27:19 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 01:27:19 Initializing... ! 01:27:19 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 01:27:19 2. Choose the phone model ! 01:27:19 3. Select the desired options ! 01:27:19 4. Please connect the phone either via USB while holding 2-5… ! 01:27:19 - or via a serial cable and double-click on it in the device list 01:27:32 Selected phone: T715 01:27:32 Connecting via Generic EMP USB Flash Device (USB1)… 01:27:32 Device driver version: 2.2.0.0 01:27:33 Device driver date: 9-18-2008 01:27:33 Connecting to the baseband CPU... 01:27:33 Entering baseband CPU service mode... 01:27:34 Detected chipset: DB3210 P2A 01:27:34 Boot mode: ROM 01:27:35 IMEI: **** 01:27:35 OTP CID: 53 01:27:35 Product type: Retail 01:27:35 Effective color: Red 01:27:35 Sending loader... 01:27:40 Communicating with server… ! 01:27:46 News: New pricing policies started. ! 01:27:46 News: Users with 1 or more credits and cruiser dongle have all operations for free. ! 01:27:47 News: Full pricing can be found on http://www.ultimate-unlocker.com/web/uu/buy#70 ! 01:27:47 News: Your consumption level is: Level 1 (Novice) 01:27:48 Remainig credit (supreme): 1.01 E 01:27:51 Error: 0xF62DDDA4 E 01:27:51 Error: 0x16D3BA97 E 01:27:51 Error: 0xBB357BB6 E 01:27:51 Error: 0xA6D1769F E 01:27:51 Error: 0x66A44ED1 E 01:27:51 Error: 0x99C5BD51 E 01:27:51 Error: 0x3D35EAF1 E 01:27:51 Error: 0x07F5EFDA E 01:27:51 Error: 0xF984FBBB E 01:27:51 Error data: 0xF984FBBB - 00000004:E3030000 E 01:27:51 Unknown server problem [256] E 01:27:51 Failed! ! 01:27:51 To report errors right-click this window |
05-13-2010, 08:05 | #12 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Server, again. Code: 08:57:50 SE S1 Flasher & Unlocker v3.00 by Cruiser Team 08:57:50 Initializing... ! 08:57:50 1. Choose the phone model ! 08:57:50 2. For flashing, select flash files and additional options ! 08:57:50 3. Double-click on the appropriate device (serial cable) ! 08:57:50 - or connect the phone via USB while holding its C button 08:57:59 Connecting via Cruiser UC-10 Cable (COM3)… 08:57:59 Device driver version: 2.4.6.0 08:57:59 Device driver date: 3-13-2008 ! 08:57:59 Connect the phone now 08:58:00 Connecting to the baseband CPU... 08:58:04 Entering baseband CPU service mode... 08:58:05 Phone type: W395 08:58:05 CDA info: 1221-2958 R6A 08:58:05 Phone software: 12175564 R1CB009 08:58:05 IMEI: 35236203189688 08:58:05 Sending loader... 08:58:16 Reading TA… 08:58:22 Communicating with server… ! 08:58:27 News: New pricing policies started. ! 08:58:27 News: Users with 1 or more credits and cruiser dongle have all operations for free. ! 08:58:27 News: Full pricing can be found on http://www.ultimate-unlocker.com/web/uu/buy#70 ! 08:58:28 News: Your consumption level is: Level 5 (Expert) 08:58:29 Remainig credit (supreme): 4.46 E 08:58:31 Unknown server problem [256] E 08:58:31 Error: 0xF62DDDA4 E 08:58:31 Error: 0x16D3BA97 E 08:58:31 Error: 0x834ACC0E E 08:58:31 Error: 0x51A411A0 E 08:58:31 Error: 0xB8C71F93 E 08:58:31 Error: 0x1850F89E E 08:58:31 Error: 0xCA02941A E 08:58:31 Error: 0x07F5EFDA E 08:58:31 Failed! ! 08:58:31 Please disconnect battery and cable from the phone! ! 08:58:31 To report errors right-click this window |
05-13-2010, 15:38 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: Bsb, DF Brasil
Member: 283943 Status: Offline Thanks Meter: 124 | Server error Hi sir, same error here: 11:32:08 SE Ultimate Unlocker v5.04 by Cruiser Team 11:32:08 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:32:08 Initializing... ! 11:32:08 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:32:08 2. Choose the phone model ! 11:32:08 3. Select the desired options ! 11:32:08 4. Please connect the phone either via USB while holding 2-5… ! 11:32:08 - or via a serial cable and double-click on it in the device list 11:32:23 Selected phone: W580 11:32:23 Connecting via Generic FTDI Cable (COM6)… 11:32:23 Device driver version: 1.0.2176.0 11:32:23 Device driver date: 12-12-2005 11:32:24 Connecting to the baseband CPU... 11:32:29 Entering baseband CPU service mode... 11:32:29 Detected chipset: DB2020 11:32:29 Boot mode: ROM 11:32:29 Sending loader... 11:32:30 IMEI: 35383202310984 11:32:30 OTP CID: 51 11:32:30 Effective CID: 52 11:32:30 Restarting phone … 11:32:32 Sending loader... 11:32:33 Communicating with server… ! 11:32:38 News: New pricing policies started. ! 11:32:39 News: Users with 1 or more credits and cruiser dongle have all operations for free. ! 11:32:39 News: Full pricing can be found on Buy - Ultimate Unlockers ! 11:32:40 News: Your consumption level is: Level 4 (Senior) 11:32:41 Remainig credit (supreme): 1.27 E 11:32:43 Error: 0xE1E2479D E 11:32:43 Error: 0xF62DDDA4 E 11:32:43 Error: 0x16D3BA97 E 11:32:43 Error: 0x834ACC0E E 11:32:44 Error: 0x51A411A0 E 11:32:44 Error: 0x78E56923 E 11:32:44 Error: 0x5C5AEBE3 E 11:32:44 Error: 0x3D35EAF1 E 11:32:44 Error: 0x07F5EFDA E 11:32:44 Unknown server problem [256] E 11:32:44 Failed! ! 11:32:44 To report errors right-click this window Pls fix it and advise. Rgds, |
Unknown server problem [256] | chikubie | Cruiser Suite | 11 | 07-19-2010 21:00 |
help: Unknown server problem [129] | ssa | D-Unlock Suite | 1 | 05-31-2009 11:43 |
Problem to Unlock SE P1i with D unlocker -Unknown server problem [129] | ahsotelo | D-Unlock Suite | 1 | 04-24-2009 13:45 |
Unknown server problem [129] | nalkhal | D-Unlock Suite | 12 | 03-17-2009 00:35 |
Unknown server problem [256] | prasadni | Cruiser Suite | 33 | 11-25-2008 23:10 |
