Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-26-2009, 10:40   #1 (permalink)
Member: 847
Thanks Meter: 36
Unknown server problem [256]
Hi, i get this error on unlock?
Tried different cables, but same problem
regards
Sjakie
  10:37:33  SE S1 Flasher & Unlocker v2.13 by Cruiser Team
  10:37:33  Initializing...
! 10:37:33  1. Choose the phone model
! 10:37:33  2. For flashing, select flash files and additional options
! 10:37:33  3. Double-click on the appropriate device (serial cable)
! 10:37:33  - or connect the phone via USB while holding its C button
  10:37:39  Connecting via TMS Cable (COM4)…
  10:37:39  Device driver version: 1.0.2154.0
  10:37:39  Device driver date: 4-16-2004
! 10:37:39  Connect the phone now
  10:37:39  Connecting to the baseband CPU...
  10:37:42  Entering baseband CPU service mode...
  10:37:43  Phone type: T303
  10:37:43  CDA info: 1222-5379 R1A
  10:37:44  Phone software: 1209-8242 R2DA004
  10:37:44  IMEI: 3537900xxxxxxx
  10:37:44  Sending loader...
  10:38:04  Reading TA…
  10:38:07  Communicating with server…
  10:38:11  Remainig credit (supreme): 8.31
E 10:38:12  Unknown server problem [256]
E 10:38:12  Error: 0x16D3BA97
E 10:38:12  Error: 0x834ACC0E
E 10:38:12  Error: 0x07F5EFDA
E 10:38:12  Error: 0x51A411A0
E 10:38:12  Error: 0xB8C71F93
E 10:38:12  Error: 0x1850F89E
E 10:38:12  Error: 0xCA02941A
E 10:38:12  Failed!
! 10:38:12  Please disconnect battery and cable from the phone!
! 10:38:12  To report errors right-click this window
The Following User Says Thank You to sjakie For This Useful Post:
Old 10-26-2009, 10:47   #2 (permalink)
Member: 367723
Thanks Meter: 346
same problem for me
15:10:41 SE Ultimate Unlocker v4.10 by Cruiser Team
15:10:41 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
15:10:41 Initializing...
! 15:10:42 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 15:10:42 2. Choose the phone model
! 15:10:42 3. Select the desired options
! 15:10:42 4. Please connect the phone either via USB while holding 2-5…
! 15:10:42 - or via a serial cable and double-click on it in the device list
15:10:51 Selected phone: S500
15:10:51 Connecting via Cruiser UC-20 Cable (COM4)…
15:10:51 Device driver version: 2.4.6.0
15:10:51 Device driver date: 3-13-2008
15:10:54 Connecting to the baseband CPU...
15:10:54 Entering baseband CPU service mode...
15:10:54 Detected chipset: DB2020
15:10:54 Boot mode: ROM
15:10:54 Sending loader...
15:10:55 IMEI: 35344702570087
15:10:55 OTP CID: 51
15:10:55 Effective CID: 52
15:10:55 Restarting phone …
15:10:58 Sending loader...
15:10:58 Communicating with server…
! 15:11:00 News: Your credit consumption policy: Level 4 (Senior)
15:11:01 Remainig credit (supreme): 8.37
E 15:11:01 Error: 0xF62DDDA4
E 15:11:01 Error: 0x16D3BA97
E 15:11:01 Error: 0x834ACC0E
E 15:11:01 Error: 0x51A411A0
E 15:11:01 Error: 0x78E56923
E 15:11:01 Error: 0x5C5AEBE3
E 15:11:01 Error: 0x3D35EAF1
E 15:11:01 Error: 0x07F5EFDA
E 15:11:01 Unknown server problem [256]
E 15:11:01 Failed!
! 15:11:01 To report errors right-click this window
Old 10-26-2009, 10:51   #3 (permalink)
I_sumo's Avatar
Member: 38103
Sonork: 100.100782
Thanks Meter: 165
I think something wrong at server end. Me too getting same error.
  15:18:07  SE Ultimate Unlocker v4.01 by Cruiser Team
  15:18:07  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  15:18:07  Initializing...
! 15:18:07  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 15:18:07  2. Choose the phone model
! 15:18:07  3. Select the desired options
! 15:18:07  4. Please connect the phone either via USB while holding 2-5…
! 15:18:07  - or via a serial cable and double-click on it in the device list
  15:18:10  Selected phone: W580
  15:18:10  Connecting via Cruiser UC-10 Cable (COM3)…
  15:18:10  Device driver version: 1.0.2154.0
  15:18:10  Device driver date: 4-16-2004
  15:18:11  Connecting to the baseband CPU...
  15:18:11  Entering baseband CPU service mode...
  15:18:11  Detected chipset: DB2020
  15:18:11  Boot mode: ROM
  15:18:11  Sending loader...
  15:18:12  IMEI: 011572006XXXXX
  15:18:12  OTP CID: 51
  15:18:12  Effective CID: 52
  15:18:12  Restarting phone …
  15:18:14  Sending loader...
  15:18:15  Communicating with server…
! 15:18:19  News: Your credit consumption policy: Level 4 (Senior)
  15:18:19  Remainig credit (supreme): XX.09
E 15:18:20  Error: 0xE1E2479D
E 15:18:20  Error: 0x16D3BA97
E 15:18:20  Error: 0x834ACC0E
E 15:18:20  Error: 0x07F5EFDA
E 15:18:20  Error: 0x51A411A0
E 15:18:20  Error: 0x78E56923
E 15:18:20  Error: 0x5C5AEBE3
E 15:18:20  Error: 0x3D35EAF1
E 15:18:20  Unknown server problem [256]
E 15:18:20  Failed!
! 15:18:20  To report errors right-click this window
Some cruiser admin reply eagerly awaited.
br
Old 10-26-2009, 11:03   #4 (permalink)
Member: 367723
Thanks Meter: 346
waiting for reply................
Old 10-26-2009, 11:34   #5 (permalink)
Gsm2Extreme's Avatar
Member: 58493
Thanks Meter: 24
same error here.................
Old 10-26-2009, 12:06   #6 (permalink)
Member: 670274
Thanks Meter: 165
server...
The problem has been fixed.
(There was a server issue from 9:08 to 10:46 UTC today)
GLaDOS
Old 10-26-2009, 12:51   #7 (permalink)
Member: 367723
Thanks Meter: 346
problem solved.thanku cruiser team
17:15:00 SE Ultimate Unlocker v4.10 by Cruiser Team
17:15:00 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
17:15:00 Initializing...
! 17:15:01 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:15:01 2. Choose the phone model
! 17:15:01 3. Select the desired options
! 17:15:01 4. Please connect the phone either via USB while holding 2-5…
! 17:15:01 - or via a serial cable and double-click on it in the device list
17:15:21 Selected phone: S500
17:15:21 Connecting via Generic EMP USB Flash Device (USB1)…
17:15:21 Device driver version: 2.2.0.5
17:15:21 Device driver date: 4-1-2009
17:15:22 Connecting to the baseband CPU...
17:15:22 Entering baseband CPU service mode...
17:15:22 Detected chipset: DB2020
17:15:22 Boot mode: ROM
17:15:22 Sending loader...
17:15:23 IMEI: 35344702570087
17:15:23 OTP CID: 51
17:15:23 Effective CID: 52
17:15:25 Please reconnect the phone (disconnect, connect while holding 2-5)
17:15:30 Sending loader...
17:15:30 Communicating with server…
! 17:15:32 News: Your credit consumption policy: Level 4 (Senior)
17:15:32 Remainig credit (supreme): 8.37
17:15:34 Remainig credit (supreme): 8.22
17:15:37 Please reconnect the phone (disconnect, connect while holding 2-5)
17:15:41 Sending loader...
17:15:44 Writing flash…
17:15:46 Turning off the phone...
17:15:48 Done.
Old 05-13-2010, 00:31   #8 (permalink)
Member: 593565
got error while unlocking T715
  01:27:19  SE Ultimate Unlocker v5.04 by Cruiser Team
  01:27:19  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  01:27:19  Initializing...
! 01:27:19  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 01:27:19  2. Choose the phone model
! 01:27:19  3. Select the desired options
! 01:27:19  4. Please connect the phone either via USB while holding 2-5…
! 01:27:19  - or via a serial cable and double-click on it in the device list
  01:27:32  Selected phone: T715
  01:27:32  Connecting via Generic EMP USB Flash Device (USB1)…
  01:27:32  Device driver version: 2.2.0.0
  01:27:33  Device driver date: 9-18-2008
  01:27:33  Connecting to the baseband CPU...
  01:27:33  Entering baseband CPU service mode...
  01:27:34  Detected chipset: DB3210 P2A
  01:27:34  Boot mode: ROM
  01:27:35  IMEI: ****
  01:27:35  OTP CID: 53
  01:27:35  Product type: Retail
  01:27:35  Effective color: Red
  01:27:35  Sending loader...
  01:27:40  Communicating with server…
! 01:27:46  News: New pricing policies started.
! 01:27:46  News: Users with 1 or more credits and cruiser dongle have all operations for free.
! 01:27:47  News: Full pricing can be found on http://www.ultimate-unlocker.com/web/uu/buy#70
! 01:27:47  News: Your consumption level is: Level 1 (Novice)
  01:27:48  Remainig credit (supreme): 1.01
E 01:27:51  Error: 0xF62DDDA4
E 01:27:51  Error: 0x16D3BA97
E 01:27:51  Error: 0xBB357BB6
E 01:27:51  Error: 0xA6D1769F
E 01:27:51  Error: 0x66A44ED1
E 01:27:51  Error: 0x99C5BD51
E 01:27:51  Error: 0x3D35EAF1
E 01:27:51  Error: 0x07F5EFDA
E 01:27:51  Error: 0xF984FBBB
E 01:27:51  Error data: 0xF984FBBB - 00000004:E3030000
E 01:27:51  Unknown server problem [256]
E 01:27:51  Failed!
! 01:27:51  To report errors right-click this window
not supported or just server error?
Old 05-13-2010, 01:04   #9 (permalink)
Member: 105625
Thanks Meter: 44
same problem here...
Old 05-13-2010, 02:13   #10 (permalink)
Member: 577377
Thanks Meter: 12
same problem
same problem and error
Old 05-13-2010, 02:26   #11 (permalink)
Member: 254830
Thanks Meter: 13
error 256
hi. same problem same error problem in server?
Old 05-13-2010, 08:05   #12 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Server, again.
  08:57:50  SE S1 Flasher & Unlocker v3.00 by Cruiser Team
  08:57:50  Initializing...
! 08:57:50  1. Choose the phone model
! 08:57:50  2. For flashing, select flash files and additional options
! 08:57:50  3. Double-click on the appropriate device (serial cable)
! 08:57:50  - or connect the phone via USB while holding its C button
  08:57:59  Connecting via Cruiser UC-10 Cable (COM3)…
  08:57:59  Device driver version: 2.4.6.0
  08:57:59  Device driver date: 3-13-2008
! 08:57:59  Connect the phone now
  08:58:00  Connecting to the baseband CPU...
  08:58:04  Entering baseband CPU service mode...
  08:58:05  Phone type: W395
  08:58:05  CDA info: 1221-2958 R6A
  08:58:05  Phone software: 12175564 R1CB009
  08:58:05  IMEI: 35236203189688
  08:58:05  Sending loader...
  08:58:16  Reading TA…
  08:58:22  Communicating with server…
! 08:58:27  News: New pricing policies started.
! 08:58:27  News: Users with 1 or more credits and cruiser dongle have all operations for free.
! 08:58:27  News: Full pricing can be found on http://www.ultimate-unlocker.com/web/uu/buy#70
! 08:58:28  News: Your consumption level is: Level 5 (Expert)
  08:58:29  Remainig credit (supreme): 4.46
E 08:58:31  Unknown server problem [256]
E 08:58:31  Error: 0xF62DDDA4
E 08:58:31  Error: 0x16D3BA97
E 08:58:31  Error: 0x834ACC0E
E 08:58:31  Error: 0x51A411A0
E 08:58:31  Error: 0xB8C71F93
E 08:58:31  Error: 0x1850F89E
E 08:58:31  Error: 0xCA02941A
E 08:58:31  Error: 0x07F5EFDA
E 08:58:31  Failed!
! 08:58:31  Please disconnect battery and cable from the phone!
! 08:58:31  To report errors right-click this window
Old 05-13-2010, 08:31   #13 (permalink)
Alinus's Avatar
Member: 14279
Thanks Meter: 35
same here. please fix it.
Old 05-13-2010, 15:38   #14 (permalink)
antoniolcrd's Avatar
Member: 283943
Thanks Meter: 124
Server error
Hi sir,
same error here:
11:32:08 SE Ultimate Unlocker v5.04 by Cruiser Team
11:32:08 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
11:32:08 Initializing...
! 11:32:08 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 11:32:08 2. Choose the phone model
! 11:32:08 3. Select the desired options
! 11:32:08 4. Please connect the phone either via USB while holding 2-5…
! 11:32:08 - or via a serial cable and double-click on it in the device list
11:32:23 Selected phone: W580
11:32:23 Connecting via Generic FTDI Cable (COM6)…
11:32:23 Device driver version: 1.0.2176.0
11:32:23 Device driver date: 12-12-2005
11:32:24 Connecting to the baseband CPU...
11:32:29 Entering baseband CPU service mode...
11:32:29 Detected chipset: DB2020
11:32:29 Boot mode: ROM
11:32:29 Sending loader...
11:32:30 IMEI: 35383202310984
11:32:30 OTP CID: 51
11:32:30 Effective CID: 52
11:32:30 Restarting phone …
11:32:32 Sending loader...
11:32:33 Communicating with server…
! 11:32:38 News: New pricing policies started.
! 11:32:39 News: Users with 1 or more credits and cruiser dongle have all operations for free.
! 11:32:39 News: Full pricing can be found on Buy - Ultimate Unlockers
! 11:32:40 News: Your consumption level is: Level 4 (Senior)
11:32:41 Remainig credit (supreme): 1.27
E 11:32:43 Error: 0xE1E2479D
E 11:32:43 Error: 0xF62DDDA4
E 11:32:43 Error: 0x16D3BA97
E 11:32:43 Error: 0x834ACC0E
E 11:32:44 Error: 0x51A411A0
E 11:32:44 Error: 0x78E56923
E 11:32:44 Error: 0x5C5AEBE3
E 11:32:44 Error: 0x3D35EAF1
E 11:32:44 Error: 0x07F5EFDA
E 11:32:44 Unknown server problem [256]
E 11:32:44 Failed!
! 11:32:44 To report errors right-click this window
Pls fix it and advise.
Rgds,
Old 05-13-2010, 15:41   #15 (permalink)
Member: 65183
Stil problem with serwer
Unknown server problem [256] chikubie Cruiser Suite 11 07-19-2010 21:00
help: Unknown server problem [129] ssa D-Unlock Suite 1 05-31-2009 11:43
Problem to Unlock SE P1i with D unlocker -Unknown server problem [129] ahsotelo D-Unlock Suite 1 04-24-2009 13:45
Unknown server problem [129] nalkhal D-Unlock Suite 12 03-17-2009 00:35
Unknown server problem [256] prasadni Cruiser Suite 33 11-25-2008 23:10
Page generated in 0.27689 seconds with 9 queries
