02-27-2006, 04:38 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Are you able to post a debug log? No one has posted one yet, looking at it might help solve the problem. I very much doubt I'll be able to help, but perhaps Lead might. I don't mean a log of attaching to/flash the phone. I mean the "debug log" in the Extra's menu. Once you've select this, with the problem phone powered off plug it into Cruiser, power it on and use it as normal. Make the phone hang, wait at least a minute or two then stop the debug log. Zip it up and attach it here. |
02-27-2006, 06:43 | #5 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Malaysia Age: 44
Member: 10977 Status: Offline Thanks Meter: 55 | here the log file about the bluetooth hang w550 Version 9.18 gamma ready! Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Phone hardware initialized OK Flash file: "W550c_CXC1250086_China_R4BA041_Brown49.cw55sw " Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Programming flash... Time: 00:06:28 Flash process done. Flash file: "W550c_CXC1250032_China_R4BA041_Brown49.cw55fs " Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:03:52 Flash process done. Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Sending CS applet... Initializing CS applet... Baudrate = 921600Bd Starting up GDFS service... Starting up filesystem, please wait... Building customization... Customizing phone... Done. Writing CDA Article MS string... Done. Writing CDA Version MS string... Done. Writing Default Article MS string... Done. Writing Default Version MS string... Done. Writing langpack string... Done. Writing country... Done. Uploading certificates... Certificates uploaded successfuly. Turning off phone... GDFS access terminated. Phone automatically detached. |
02-27-2006, 06:55 | #6 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | Please re-read what I posted here. That is not the log I ment, I ment a debug log. Edit: I have added an image, hopefully you'll see what I mean Last edited by muppet; 02-27-2006 at 07:03. Reason: Added Image |
02-27-2006, 08:42 | #7 (permalink) |
Member: 10977 Status: Offline Thanks Meter: 55 | @muppet...i try to get debug log but when i connect the phone...nothing happen.....simply press power on bottun...the phone goes on...cannot detect at all....but i attach phone no problem |
02-27-2006, 08:42 | #8 (permalink) |
02-27-2006, 09:20 | #9 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | @danielkhaw: Steps To Create Debug Log 1) Power OFF the phone to be debugged. 2) Open Cruiser. 3) Open the COM Window to be used for debug, click on "Debug Log" and find somewhere to save the file. 4) Plug the phone to the cable. 5) Power ON the phone. 6) NOTHING WILL HAPPEN in Cruiser. No display, no messages. The phone will power on though and messages will be logged. 7) Use and make it lock up/freeze/**** up. Once you've crashed the phone, wait a few minutes then close Cruiser. 8) Open up the debug log in a text file, you should notice there's lots of information. Zip up the file, attach it here. |
05-10-2006, 08:55 | #13 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | w550 has GDFS problem because of bluetooth, k750i wouldn so shure because of software :/ or if you played with software and network lost.... B.R. Alkapone |
05-16-2006, 10:20 | #14 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | what r these and how used it??? Quote:
what r these and how used it??? | |
w550i bluetooth not working ? | harish35200 | Sony Ericsson | 2 | 12-18-2006 12:31 |
w550i bluetooth not conected | atulgsm | Cruiser Suite | 0 | 11-01-2006 18:42 |
W550i bluetooth proplem | simply-cy | Cruiser Suite | 1 | 01-19-2006 12:35 |
@ Lead -> W550i Bluetooth problem | rjsoo7 | Cruiser Suite | 3 | 01-09-2006 07:28 |
W550i .. Bluetooth problem | rjsoo7 | Cruiser Suite | 0 | 01-03-2006 23:35 |
