05-29-2006, 20:19 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 51
Member: 170494 Status: Offline Thanks Meter: 9 | K750i CID 49 RED WITH THE NEW FLASHFILES R1CA021 dont work i have a k750i cid 49 red dead. with the tp i changed it to brown 49. but when i flashed with the new flashfiles R1CAO21 then i cant cusumize fs. becouse the customize fs and the file system is not active. if i flashed with this Flash file: "DB2010_W810_EROMBrown49_signed_by_Brown49.ero m4" then the customize fs and the filesystem is active and i can flash the ARM and RAW FS but when i want to customize fs then i get this message. Could not start GDFS service i have need your help and the costomer want his phone buck. his phone is about 3 weeks with me and i cant make it good. Version 9.71 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Secondary certificate not found. GDFS configuration not found. OSE configuration not found. TestProgram configuration not found. Done. RSA protection is normal. Phone hardware initialized OK when i customize fs then it stop on starting up gdfs service.... [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Sending CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V23 Initializing CS applet... Applet ID: 060118 0312 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V23 Baudrate = 921600Bd Starting up GDFS service... i tink i need the red or brown gdfs for k750i thanks Last edited by Shoja; 05-29-2006 at 20:55. |
05-29-2006, 21:10 | #3 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | hi hallo, if i change it to red cid 49 then i cant flash it then i git the following error. Error flashing block at address: 0x44022400 Script error: Flash error [9.71.75] and this is the log Version 9.71 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... [ --- Detach Phone --- ] All threads terminated. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "K750i_CXC125952_EU1_R1CA021_Red49.ck75sw" Waiting for flash file to load... Preparing to program flash... Baudrate = 921600Bd Programming flash... thanks |
05-29-2006, 21:13 | #4 (permalink) | |
Freak Poster Join Date: Jun 2005 Age: 54
Member: 151343 Status: Offline Thanks Meter: 3 | Quote:
BUT BEFORE THAT READ MANUAL!!! If you had done that before, you would know now what to do... | |
05-29-2006, 21:24 | #6 (permalink) | |
05-29-2006, 21:29 | #7 (permalink) | |
Member: 170494 Status: Offline Thanks Meter: 9 | hi Quote:
convert to red cid 49 doesnt need testpoint. and i hove deed it without testpoint and now the phone is red cid 49 as you say. thaks | |
05-29-2006, 21:33 | #8 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Stockholm www.sumpansmobil.se Age: 57
Member: 79724 Status: Offline Thanks Meter: 15 | Quote:
Just attach to phone and unlock RSA. Take battery out, attach to phone Do direct unlock. Attach again and flash Main FW and RAW FS and costomize. Or flash Main FW Unlock RSA Flash RAW FS and costomize. Then do a Firmware Restore, "Button beside unlock RSA" BR Nizze | |
05-29-2006, 21:35 | #9 (permalink) |
Member: 151343 Status: Offline Thanks Meter: 3 | OK Then now attach to phone, unlock RSA, remove batterie as cruiser ask you, attach again, unlock, flash FS, FS flash main, customize. This should work. GOOD LUCK!!! Please post results. EDIT: HI NIZZE, you were faster... |
05-29-2006, 22:01 | #10 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | hi i deed as you. no result. i unlocked the RSA and i cant direct unlock and i get this massege. [ --- Direct Unlock --- ] Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. i cant unlock it becouse it is going and going. and if i want to flash the raw fs then it is going too 1% then i get this massege. Error flashing block at address: 0x45420000 Script error: Flash error [9.71.75] restore files aslo doesnt help and hangt with a error. i dont know what i to do. thaks |
05-29-2006, 22:17 | #12 (permalink) | |
do you hove another idea please. thanks | |
05-29-2006, 23:33 | #13 (permalink) | |
If it don't work then, please post here again. Good night Nizze | |
05-30-2006, 00:17 | #14 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 248353 Status: Offline Thanks Meter: 3 | convert it back to brown49 and repair erom flash with brown49 flashs W600i_CXC1123106_EU1_R7B039_Brown49.rar W600i_CXC1123107_All-in-One_CustomV1_R7B039_Brown49.rar custolise fs shutdown fs if phone is blinking than flash fota_useragent |
05-30-2006, 13:30 | #15 (permalink) | |
i can flahs but i cant customized fs (gdfs starting failid or something lick that) i need ather solution thanks | |
Need K750i Cid 49 Red Flashing Step By Step | sanjeewa57 | Cruiser Suite | 18 | 10-11-2006 11:01 |
K750i CID 49 RED | Shoja | Cruiser Suite | 32 | 09-28-2006 12:32 |
k750i cid 49 red R1AA008 how to unlock | mily2 | Cruiser Suite | 7 | 09-02-2006 13:27 |
K750i cid 49 red not working | fra356 | Sony Ericsson | 6 | 08-25-2006 16:09 |
K750i Cid 49 Red Unlock Rsa Again And Again | Shoja | Cruiser Suite | 10 | 07-06-2006 19:59 |
