10-10-2004, 12:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Z200 R6A keybad not working any solution to repair this fone or is there any flash for R6A ? |
10-10-2004, 13:52 | #7 (permalink) |
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | fone has no hardware problem .. actual version was R6A .. i flash it with R6C ... after this keypad is not working .. i already tried CXC125718 and Z200_decustomization_v2_correct_cda.flp |
10-10-2004, 13:56 | #8 (permalink) |
Guest
Posts: n/a
Member: | Removes customized operator settings, enables Italian and Chinese languages, enables Ciphering Indication and clears the NVRAM area. The file "Z200_decustomization_v2_correct_cda.flp" has to be flashed into the ARM flash of the Z200 phone. The phone turns then automatically on. Never remove the battery, first you have to turn the phone off using the power-button. (Otherwise unpredictable behaviour will occur - it may be partially repaired using the NVRAM clean file). Use only with Fighter version 4.10.. hmmmm ... |
10-13-2004, 17:33 | #9 (permalink) |
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | how to remove Removes customized operator settings and i already write Z200_decustomization_v2_correct_cda.flp and follow the steps all same !!! keypads are still not wworking |
X200 keybad not work after water | tabas47 | Samsung Hardware Repair | 17 | 08-09-2011 10:03 |
c100 keybad not work after water | mobile star | Samsung Hardware Repair | 27 | 06-11-2008 08:55 |
v3x keybad not working except number8 | amira77 | Motorola P2k | 2 | 05-21-2008 04:36 |
v200 keybad not work after water | magic 75 | Samsung Hardware Repair | 0 | 03-10-2006 17:19 |
n620 keybad not work | mobile star | Samsung Hardware Repair | 3 | 02-28-2004 08:10 |
