07-19-2008, 16:00 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 593565 Status: Offline Thanks Meter: 0 | D-unlocker error? When i try to just plug the phone in without holding any buttons: Code: 16:47:14 D-Unlocker v2.12 by Cruiser Team 16:47:14 Initializing... ! 16:47:14 1. Please see the documentation first (a PDF installed with the application) ! 16:47:14 2. Make sure the appropriate phone modem drivers are installed ! 16:47:14 3. Fill in the connection settings under settings tab ! 16:47:14 4. Turn the phone ON ! 16:47:14 5. Connect the phone… 16:50:35 Connecting via SEMC USB Flash Device (USB2)… 16:50:35 Device driver version: 1.1.0.12 16:50:35 Device driver date: 9-25-2006 16:50:35 Starting communication... 16:50:35 Connecting to the baseband CPU... 16:50:35 Entering baseband CPU service mode... 16:50:36 Detected chipset: DB3150 16:50:36 Boot mode: EROM 16:50:36 Sending loader... 16:50:37 IMEI: ***** 16:50:37 OTP CID: 52 16:50:37 OTP area status: Locked 16:50:37 Product type: Retail 16:50:37 Effective color: Red 16:50:37 Sending loader... 16:50:40 Communicating with server… E 16:50:51 Error: 0xB3A47971 E 16:50:51 Error: 0xECB2CE4A E 16:50:51 Error: 0x28FF3CA4 E 16:50:51 Error: 0xA8A269DB E 16:50:51 Cable disconnect detected E 16:50:51 Failed! ! 16:50:51 Please disconnect battery and cable from the phone! ! 16:50:51 To report errors right-click this window Code: 16:51:47 D-Unlocker v2.12 by Cruiser Team 16:51:47 Initializing... ! 16:51:47 1. Please see the documentation first (a PDF installed with the application) ! 16:51:47 2. Make sure the appropriate phone modem drivers are installed ! 16:51:47 3. Fill in the connection settings under settings tab ! 16:51:47 4. Turn the phone ON ! 16:51:47 5. Connect the phone… 16:51:56 Connecting via Generic EMP USB Flash Device (USB2)… 16:51:56 Device driver version: 1.1.0.12 16:51:56 Device driver date: 9-25-2006 16:51:56 Starting communication... 16:51:56 Connecting to the baseband CPU... 16:51:56 Entering baseband CPU service mode... 16:51:56 Detected chipset: DB3150 16:51:56 Boot mode: ROM E 16:52:56 Error: 0x1854EFA1 E 16:52:56 Error: 0x2FCFDF32 E 16:52:56 Error: 0x421E0A54 E 16:52:56 Error: 0x79C16B04 E 16:52:56 Error: 0x9FFF4777 E 16:52:56 Error: 0x28FF3CA4 E 16:52:56 Error: 0xA8A269DB E 16:52:56 Cable disconnect detected E 16:52:56 Failed! ! 16:52:56 Please disconnect battery and cable from the phone! ! 16:52:57 To report errors right-click this window Code: 16:53:08 D-Unlocker v2.12 by Cruiser Team 16:53:08 Initializing... ! 16:53:08 1. Please see the documentation first (a PDF installed with the application) ! 16:53:08 2. Make sure the appropriate phone modem drivers are installed ! 16:53:08 3. Fill in the connection settings under settings tab ! 16:53:08 4. Turn the phone ON ! 16:53:08 5. Connect the phone… 16:53:31 Connecting via SEMC USB Flash Device (USB2)… 16:53:31 Device driver version: 1.1.0.12 16:53:31 Device driver date: 9-25-2006 16:53:31 Starting communication... 16:53:31 Connecting to the baseband CPU... 16:53:31 Entering baseband CPU service mode... 16:53:32 Detected chipset: DB3150 16:53:32 Boot mode: EROM 16:53:32 Sending loader... 16:53:32 IMEI: ****** 16:53:32 OTP CID: 52 16:53:32 OTP area status: Locked 16:53:32 Product type: Retail 16:53:32 Effective color: Red 16:53:33 Sending loader... 16:53:36 Communicating with server… 16:53:49 Remainig credit (supreme): 1.00 E 16:53:50 Unknown server problem [256] E 16:53:50 Error: 0x28FF3CA4 E 16:53:50 Failed! ! 16:53:50 Please disconnect battery and cable from the phone! ! 16:53:50 To report errors right-click this window Regards Last edited by cassiel; 07-19-2008 at 16:01. Reason: removed IMEI.. |
6630 unlock error & how to fix error ? | krid2005 | Universalbox | 1 | 12-21-2008 08:48 |
bb5king jaf unlocking error Error. 0x10010401 | m_naeem | BB5KING | 3 | 11-11-2008 08:36 |
6630 unlock error send ask error | krid2005 | Universalbox | 3 | 09-25-2008 17:19 |
Error unlocking! Error unlocking! Error unlocking! | smart_mobile | J.A.F. V-SPEC | 84 | 05-03-2008 21:49 |
PKEY ERROR bb5 unlock error, read here | AndreS | J.A.F. Plus | 0 | 01-21-2008 21:39 |
