Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > D-Unlock Suite
Old 07-18-2008, 21:33   #1 (permalink)
Member: 817424
C702 Bricked.....Please help
Hi, I used D-unlocker to unlock C702 and unfortunately it has broken my phone.
When I first used the unlocker, everything went ok although I had to use GDFS mode (hold down C key?)
The system went through its process and eventually came up with 'Job Scheduled please wait 02.54' and then phone restarting.
At this point it just hangs and then nothing. I left it connected for 15 minutes with no result then disconected and re-started the phone.
I then reconnected the phone and ran D-Unlocker again and it did the same, although now it shows:
'Remaining Credit (Supreme) : 0.00
Connecting to Baseband CPU...
Restarting Phone..'
Phone no longer boots correctly and the keypad just remains lit.
Please can you help.
Gaz.
Old 07-18-2008, 21:53   #2 (permalink)
Member: 817424
Sorry, user id is:
user_5fbfe11e
Old 07-18-2008, 22:34   #3 (permalink)
Member: 817424
Have now tried using 2.12 and get the same problem, except now last line is:
'Restarting Phone...
Choose Phone Mode (on the phone)'
Obviously the phone doesn't boot to the Mode Choice screen.
What can I do?
Gaz.
Old 07-18-2008, 23:27   #4 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
At this point disconnect phone from cable, wait 5 seconds and connect it back. If this won't help, disconnect phone, power off and then power on phone, connect phone to cable when you will see "Insert SIM card" on display.
Old 07-19-2008, 00:08   #5 (permalink)
Member: 817424
Hi, tried this. Phone will not even start up with power button now.
Only way to get a response is with C button.
Any other ideas (and thanks for your help so far!)
Gaz.
Old 07-19-2008, 10:52   #6 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
Remove battery from phone, put it back and try power it on. If not work check voltmeter if battery is ok. Until you can't power on phone, you can't finish unlock operation.
please help me to unlock N97 [ANSWERED] longgiang81 Genie Universal 2 03-30-2010 09:18
6210n unlock please help me please AVCITHETCNC MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-29-2010 18:21
CiPhone C6t Wm6.1 Bricked, Please help needle2k Chinese Models & Cloned Phones 0 02-19-2010 07:50
My Samsung Omnia is bricked! Please help! Gurkanla Samsung Flashers, Software, Firmware. 3 08-01-2009 17:19
Please help! "INSERT SIM" & "NO SIM" & Manual for Quad Band TV Dual SIM TV C702 BenGman Chinese Models & Cloned Phones 1 07-28-2008 19:22
Page generated in 0.18224 seconds with 9 queries
