07-18-2008, 21:33 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 817424 Status: Offline Thanks Meter: 0 | C702 Bricked.....Please help When I first used the unlocker, everything went ok although I had to use GDFS mode (hold down C key?) The system went through its process and eventually came up with 'Job Scheduled please wait 02.54' and then phone restarting. At this point it just hangs and then nothing. I left it connected for 15 minutes with no result then disconected and re-started the phone. I then reconnected the phone and ran D-Unlocker again and it did the same, although now it shows: 'Remaining Credit (Supreme) : 0.00 Connecting to Baseband CPU... Restarting Phone..' Phone no longer boots correctly and the keypad just remains lit. Please can you help. Gaz. |
07-18-2008, 22:34 | #3 (permalink) |
Member: 817424 Status: Offline Thanks Meter: 0 | Have now tried using 2.12 and get the same problem, except now last line is: 'Restarting Phone... Choose Phone Mode (on the phone)' Obviously the phone doesn't boot to the Mode Choice screen. What can I do? Gaz. |
07-18-2008, 23:27 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | At this point disconnect phone from cable, wait 5 seconds and connect it back. If this won't help, disconnect phone, power off and then power on phone, connect phone to cable when you will see "Insert SIM card" on display. |
07-19-2008, 10:52 | #6 (permalink) |
Member: 25671 Status: Offline Thanks Meter: 719 | Remove battery from phone, put it back and try power it on. If not work check voltmeter if battery is ok. Until you can't power on phone, you can't finish unlock operation. |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
6210n unlock please help me please | AVCITHETCNC | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 18:21 |
CiPhone C6t Wm6.1 Bricked, Please help | needle2k | Chinese Models & Cloned Phones | 0 | 02-19-2010 07:50 |
My Samsung Omnia is bricked! Please help! | Gurkanla | Samsung Flashers, Software, Firmware. | 3 | 08-01-2009 17:19 |
Please help! "INSERT SIM" & "NO SIM" & Manual for Quad Band TV Dual SIM TV C702 | BenGman | Chinese Models & Cloned Phones | 1 | 07-28-2008 19:22 |
