Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > D-Unlock Suite
Old 12-11-2008, 23:50   #1 (permalink)
Member: 417229
Red face D-UltimateUnlocker "please boot via ROM"
k770, db2020 cid53. trying to downgrade to cid52 using ultimate unlocker.
connects but i get the errors 'unsupported boot mode' 'please boot via rom'. this is mentioned in a few threads on various forums without any confirmed resolution.
have tried v1.03 & 3.06 beta - same result both times.
also tried the following key combinations:
2 + 5
2 + *
5 + *
8 + *
please help, or if the answer is available just tell me to keep searching.
many thanks to anyone who can help.
22:43:46 D-Ultimate Unlocker v3.06 (Beta) by Cruiser Team
22:43:46 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
22:43:46 Initializing...
! 22:43:46 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 22:43:46 2. Choose the phone model
! 22:43:46 3. Select the desired options
! 22:43:46 4. Please connect the phone either via USB while holding 2-5…
! 22:43:46 - or via a serial cable and double-click on it in the device list
22:43:58 Selected phone: K770
22:43:58 Connecting via SEMC USB Flash Device (USB1)…
22:43:58 Device driver version: 2.0.0.4
22:43:58 Device driver date: 9-12-2007
22:43:58 Connecting to the baseband CPU...
22:43:58 Entering baseband CPU service mode...
22:43:59 Detected chipset: DB2020
22:43:59 Boot mode: EROM
22:43:59 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB
E 22:43:59 Error: 0x889C690F
E 22:43:59 Unsupported boot mode
! 22:43:59 Please boot via ROM
E 22:43:59 Failed!
! 22:43:59 To report errors right-click this window
Old 12-18-2008, 20:27   #2 (permalink)
Member: 787574
dude i got the same problem as you do, i'm wondering if someone from here could have the right answer for this problem..
thanks in advance!
Old 12-19-2008, 10:52   #3 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
there is nothing else as wrong connecting of phone. Hold on phone together keys 2 and 5 and then connect cable to phone, check in device manager if driver is installed. Be sure you are holding as first key 5 and then hold also key 2, so you will holding both keys at same time.
Old 01-20-2009, 18:03   #4 (permalink)
Member: 951884
Same problem
i have the same problem with that error message, have you figured it out? i really need help, im doing all the instructions correctly
Old 01-21-2009, 09:23   #5 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
Even my previous message don't help you ? If not, post your full log.
Old 01-22-2009, 14:50   #6 (permalink)
Member: 951884
This is the error i am now getting? what does this mean and how can i correct it
  13:48:13  D-Ultimate Unlocker v3.04 by Cruiser Team
  13:48:13  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:48:13  Initializing...
! 13:48:13  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:48:13  2. Choose the phone model
! 13:48:13  3. Select the desired options
! 13:48:13  4. Please connect the phone either via USB while holding 2-5…
! 13:48:13  - or via a serial cable and double-click on it in the device list
  13:48:43  Selected phone: K800
  13:48:43  Connecting via Generic EMP USB Flash Device (USB2)…
  13:48:43  Device driver version: 2.2.0.0
  13:48:43  Device driver date: 9-18-2008
  13:48:44  Connecting to the baseband CPU...
  13:48:44  Entering baseband CPU service mode...
  13:48:44  Detected chipset: DB2020
  13:48:44  Boot mode: ROM
  13:48:44  Sending loader...
  13:48:44  IMEI: 35731501476053
  13:48:44  OTP CID: 51
  13:48:44  Effective CID: 53
  13:48:46  Please reconnect the phone (disconnect, connect while holding 2-5)
  13:49:27  Sending loader...
  13:49:27  Communicating with server…
E 13:49:31  Error: 0xD0EA59C1
E 13:49:31  Error: 0x41F19ADB
E 13:49:31  Error: 0x07F5EFDA
E 13:49:31  Error: 0x51A411A0
E 13:49:31  Error: 0x78E56923
E 13:49:31  Error: 0x5C5AEBE3
E 13:49:31  Error: 0x3D35EAF1
E 13:49:31  User name not registered on the server
E 13:49:31  Login to server failed
Old 01-24-2009, 15:12   #7 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
@jonesry
did you bought D-Ultimate Unlocker logs ? Or you think it's free? It's not.
Old 04-20-2009, 11:07   #8 (permalink)
Member: 852035
Red face w880
hello i have tried evry combinatin you have written but it dont work please check log
  12:05:42  D-Ultimate Unlocker v3.07 by Cruiser Team
  12:05:42  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  12:05:42  Initializing...
! 12:05:42  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 12:05:42  2. Choose the phone model
! 12:05:42  3. Select the desired options
! 12:05:42  4. Please connect the phone either via USB while holding 2-5…
! 12:05:42  - or via a serial cable and double-click on it in the device list
! 12:05:49  - for W880/W888 phone, connect it while holding 2-* instead of 2-5
  12:06:12  Selected phone: W880/W888
  12:06:12  Connecting via SEMC USB Flash Device (USB1)…
  12:06:12  Device driver version: 2.2.0.2
  12:06:12  Device driver date: 12-5-2008
  12:06:13  Connecting to the baseband CPU...
  12:06:13  Entering baseband CPU service mode...
  12:06:13  Detected chipset: DB2020
  12:06:13  Boot mode: EROM
  12:06:13  EROM version: R3A016      prgCXC1250614_EROM_DB2020_AI_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
E 12:06:13  Error: 0x889C690F
E 12:06:13  Unsupported boot mode
! 12:06:13  Please boot via ROM
E 12:06:13  Failed!
! 12:06:13  To report errors right-click this window
Old 04-20-2009, 15:21   #9 (permalink)
Member: 14392
Thanks Meter: 9
connect while holding down 2 and *
Old 04-20-2009, 22:23   #10 (permalink)
Member: 852035
Red face w880
i have tried 2+* *+2 2+5 5+2 c+2 nothing works its a problem with d-ultimate unlocker and cid 53 and w880
Old 04-20-2009, 23:30   #11 (permalink)
Member: 852035
Wink w880
please aadd to the program that phones keyflex may be moved
because the problem was that i hade to press around the keys too make it work not direktly om the key but allso arond the key thanks for the help and im sorry fo my bad english
Old 04-21-2009, 10:26   #12 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
The right combination is: power off phone, hold together keys 2 and * and connect USB cable to phone. If you have problems, open Device manager in windows, check if you have driver installed.
Old 05-31-2010, 11:25   #13 (permalink)
Member: 29652
Thanks Meter: 43
  12:25:21  SE Ultimate Unlocker v5.04 by Cruiser Team
  12:25:21  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  12:25:21  Initializing...
! 12:25:21  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 12:25:21  2. Choose the phone model
! 12:25:21  3. Select the desired options
! 12:25:21  4. Please connect the phone either via USB while holding 2-5…
! 12:25:21  - or via a serial cable and double-click on it in the device list
  12:25:36  Selected phone: K320
  12:25:36  Connecting via SEMC USB Flash Device (USB3)…
  12:25:36  Device driver version: 2.2.0.5
  12:25:36  Device driver date: 1-29-2010
  12:25:37  Connecting to the baseband CPU...
  12:25:37  Entering baseband CPU service mode...
  12:25:37  Detected chipset: DB2012
  12:25:37  Boot mode: EROM
  12:25:37  EROM version: R3A017      prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB
E 12:25:37  Error: 0x889C690F
E 12:25:37  Error: 0xF984FBBB
E 12:25:37  Error data: 0xF984FBBB - 00000004:E3030000
E 12:25:38  Unsupported boot mode
! 12:25:38  Please boot via ROM
E 12:25:38  Failed!
! 12:25:38  To report errors right-click this window
Old 07-14-2010, 08:37   #14 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
holding * and then 2 is working for me
The Following User Says Thank You to shachash For This Useful Post:
k510i, k310i, booting via rom ashrafi580 Cruiser Suite 6 02-19-2009 02:51
k510 booting via rom flasdf Sony Ericsson Hardware Repair 0 10-10-2008 04:21
boot via DCU-60 failed eggwisher MT-BOX 1 12-17-2007 23:32
k310i boot via S.SHANTHIKUMAR Cruiser Suite 1 06-02-2007 03:55
A50 won't boot via testpoint HELP NEEDED Xflame DreamBox 4 07-31-2006 12:30
Page generated in 0.21934 seconds with 9 queries
