07-29-2009, 12:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 78421 Status: Offline Thanks Meter: 987 | Martech Analyzer update on 29/07/2009 - ability of battery regenerating added - chineese Manual It looks as following: 1. you connect the battery 2. you select proper settings from menu 3. you start the process.......... and it's ready a detailed description is to be found in the manual - In English: http://martech.pl/download/ANALYZER/..._manual_en.pdf - In Polish: http://martech.pl/download/ANALYZER/..._manual_pl.pdf - IN China: http://martech.pl/download/ANALYZER/...al_chinese.pdf Martech Shop: http://martech.pl/eshop/ Sales department contact: [email protected] Icq: 471764678 sonork 100.110305 http://martech.pl/download/ALC/ALC.zip http://martech.pl/download/ALC/ALC2.zip http://martech.pl/download/MDM/MDM.zip http://martech.pl/download/SIEM/SIEM.zip http://martech.pl/download/VSZ/VSZ.zip http://martech.pl/download/RCD/rcd.zip Martech Team www.martech.pl |
07-31-2009, 15:37 | #2 (permalink) |
Freak Poster Join Date: Apr 2002 Location: poland Age: 45
Member: 11400 Status: Offline Sonork: 100.110305 Thanks Meter: 310 | Martech Analyzer Updates - in this topic Martech Analyzer Update - 31.07.2009 New functions added: - Analyzer Print Client (APC) released. This is special PC application which allow to print test directly from PC. APC works with PB232 Analyzer, supporting printing test raports and summaries. Currently supported two modes for printing : - printing test from the function which analyze link resistance (this consist from electrical resistance of link and its ionic resistance) - printing test from regenerate / forming process Other options: - printing tests is improved - special functions to add company name on print test header - APC is available in English and Polish (more will come, if you havel questions then feel free to contact technical support at [email protected]). APC is available in English and Polish language. We will add special module to induce Li-Jon batteries soon. Firwmare Updater new version: - corrected bug connected to unstable measurement on external temperature driver - the range of initial charge and discharge current is increased - regenerate function is amplified to PreForming and PostForming APC v1.0 EN: http://martech.pl/download/ANALYZER/APC_v10_EN.exe APC v1.0 PL: http://martech.pl/download/ANALYZER/APC_v10_PL.exe Firmware Updater : http://martech.pl/download/ANALYZER/...43_0003_EN.exe We are waiting for comments and replies. Be READY ! For next BIG updates Martech Team |
The Following 3 Users Say Thank You to Holden For This Useful Post: |
08-06-2009, 12:57 | #3 (permalink) |
Member: 78421 Status: Offline Thanks Meter: 987 | Adapter XC1 for Martech 06/08/2009 Adapter XC1 for Martech Analyzer it's battery adapter for new released power supply/battery tester from Martech that allows you easy and fast connect any battery for performing regneration procvess, charge, test or discharge batetry. Adapter was created with coolaboration with Martech Team and are fully supported with PB243 device - using dedicated temperature control unit for measure battery temperature while process running to not allow overload and burn battery. Specification: - build in temperature control unit for Martech Anaylzer - cage for battery are easly adjusted to match yoru batteries - max size of battery tested (cage dimmension): 85mm x 85mm - max height of battery tested (cage dimmension): 28mm NOTE: Height as lenght of battery can be bigger that adapter area - int this situation it will be over workign area of adapter. This can happend while testign big batteries as camera unit etc. http://www.multi-com.pl/index.php/en...ategories.html |
08-07-2009, 15:32 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Poland Jasło Age: 48
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer V00.04 07/08/2009 Firmware v 00.04 has been supplemented with: - amendments in energy governing PowerDown mode_ - amendments within Discharge Mode - functions of evoking Lit battery chemistry (Review) in the area of Charging Mode - Batteries of Lit chemistry are fitted with supervising links work electronics - Those systems, among others protect the lin ks against their discharging It is stated that allowed discharging threshold is 3V per one link- - after exceeding this threshold, the battery electronics disconects the battery exit, which results as a zero voltage of such a battery Some batteries have got electronics which limits the link possibilities which results strongly lowered initial voltage. Such batteries are able to stillbe used, they sould only be stimulated in a proper way. How do the stimulating links functions work?- Reviev in PB243: PB 243 Analyzer as a standard, after detecting too low amperage or lack of battery, shows the following info:"Too Low Battery Voltage" "Check Battery Connection"- in case of connecting battery with cramps in incorrect way or " Discharging Error"Check Battery Settings"- in cas eof coonecting wrong battery type In a lowe verse of alerts: "Press Flash to Reviev..." "Press Esc to exit mode..." The same messages may appear if we have the battery demanding stimulation At this point, if we are not sure of correct battery connection as well as correct settings, we press the upper button with a charging icon (Flash)- and the process of stimulation will start, which is going to be confirmed with a message ""Reviving Process". The reviving proces take splace until the battery voltage reaches the value of at least 3V/ link with an amperage between the range of 50...250mA. The reviving process has been qdeveloped due to links security. After reaching the voltage threshold, the analyzer will conduct the usual charging cycle with the parameters declared in Settings window. Empirical research show that the whole reviving process is different and it depends on links condition, although it has never lasted longer than 12 minutes. We advise against the battery reviving using" short connection" method, uncontrolled electricity results in ofen damages of battery chemistry. Because we owe a limited amount of damaged batteries, we ask for opinions regarding analyzer functioning. All your remarks as well as suggestions ae welcomed at [email protected] or at a suitable section on our forum Best Regards Martech Team |
The Following User Says Thank You to Tech mobil For This Useful Post: |
08-28-2009, 10:36 | #5 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer Update - 28.08.2009 Martech Analyzer Update - 28.08.2009 New functions added: New Firmware V 00.05 with following possibilites: 1. Added directly managing from PC (BatteryCharger mode) for application PB243_manager 2. Corrected service of cooling driver by using HOME functions (PowerSupply mode) 3. Added information about firmware veresion after first connecting 4. Fixed HOME functions - parameters reset PB243 Analyzer Manager v1.0: Battery Analyzer Manager – function description: - Battery Analyzer Manager added easy database for individual details of batteries and cells - Adding field works by typing into Battery Description field and choosing parameters - Removing works by selecting desired field and clicking on „Remove Battery From Database” button - Changing parameters and saving it is possible by clicking on „Approve Changes” v1.0 is beta version, we are waiting for users feedbacks on [email protected] Latest firmware: http://martech.pl/download/ANALYZER/...43_0005_EN.rar Latest version of PB243 Manager: http://martech.pl/download/ANALYZER/...10_Beta_EN.rar |
09-03-2009, 10:05 | #6 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer V00.06 03/09/2009 Martech Analyzer Update - 03.09.2009 New functions added: New Firmware V 00.06 with following possibilites: 1. Discharge process is optimized 2. Added Polish language in Analyzer Menu Latest PB243 firmware (English) : http://martech.pl/download/ANALYZER/...43_0006_EN.rar Latest PB243 firmware (Polish) : http://martech.pl/download/ANALYZER/...43_0006_PL.rar For end users and resellers: We can add all possible languages for desired country (arabic alphabet only). Best regards Martech Team |
09-03-2009, 16:54 | #7 (permalink) |
No Life Poster Join Date: Jul 2006 Location: <<SearcH EnginE>>
Member: 307373 Status: Offline Sonork: paypal.me/div859 Thanks Meter: 590 | great update good team.............................. |
The Following User Says Thank You to div_859 For This Useful Post: |
09-18-2009, 17:07 | #8 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer Big Upadate 18.09.2009 Martech Analyzer Update - 18.09.2009 New functions added: New Firmware V 00.07 with following possibilites: 1. From this firmware it's possible to transmit measurement data directly to PC. You can receive and watch it via PB234 Manager. 2. PB243 Manager version v11 with additional modules : - Ubatt = f(t), battery voltage in time function (Charging, Discharging, Regeneration modes) - Ibatt = f(t), battery current in time function (Charging, Discharging, Regeneration modes) - Tbatt = f(t), battery temperature in time function (Charging, Discharging, Regeneration modes) You can do zoom in on graphic diagram to see more detailed part of characteristic. We will add more function like printing diagrams, saving it and opening from files. We look forward for comments and feedbacks on [email protected] Public Support http://martech.pl/support/ Forum English http://martech.pl/forum/viewforum.ph...0814100c00c2a8 Forum Polisch http://martech.pl/forum/viewforum.ph...0814100c00c2a8 Forum Rusian http://martech.pl/forum/viewforum.ph...0814100c00c2a8 Forum French http://martech.pl/forum/viewforum.ph...0814100c00c2a8 Forum Spanisch http://martech.pl/forum/viewforum.ph...0814100c00c2a8 Forum Arabic http://martech.pl/forum/viewforum.ph...0814100c00c2a8 Latest PB243 firmware (English) : http://martech.pl/download/ANALYZER/...43_0007_EN.zip Latest PB243 firmware (Polish) : http://martech.pl/download/ANALYZER/...43_0007_PL.zip Latest PB234 Manager: http://martech.pl/download/ANALYZER/...r_v11_Beta.zip Best regards Martech Team |
09-23-2009, 18:36 | #9 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer Update - 23.09.2009 Martech Analyzer Update - 23.09.2009 New functions added: Martech Analyzer Manager V1.2 - new option for printing characteristics. Graphic diagrams are placed on one common sheet. Scaling on sheet is prepared in special way, it's optimized independently of size and direction. The area of characetistic presentation is optimized also. Next update will allow to save and read measurement data. We look forward for comments and feedbacks on [email protected] Latest PB234 Manager: http://martech.pl/support/Martech%20...r_v12_Beta.exe Best regards Martech Team |
10-02-2009, 11:04 | #10 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer Update - 02.10.2009 Martech Analyzer Update - 02.10.2009 New functions: Analyzer Manager v13 is udpated for new possibilites: - Reading registration data via AM WIth this function you get check registration, serial number, hardware version and analyzer firmware - Cleaning function for diagram windows - Turning on/off measurement data in process of graphic analysis - Saving data to file from charging, discharging, regenerate process - Reading data from file - Animated process of : charging, discharging, regenerate by using data from file Since now you can analyse whole process in time function ! Animation function are selected in special way, you will see whole process saved before. We look forward for comments and feedbacks on [email protected] Latest PB234 Manager: PB243_Manager_v13_Beta Best regards Martech Team |
10-02-2009, 11:09 | #11 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: X-Sol
Member: 954575 Status: Offline Thanks Meter: 244 | Quote:
go martech team.... | |
10-07-2009, 16:33 | #12 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Analyzer Update: 07/10/2009 Analyzer Update: 07/10/2009 - PB243 Manager v14 Corrected saving function and user registration. SBS Tools is free for all Analyzer owners (tool for resetting charging cycles and production date). Public Support http://martech.pl/support/ English Forum http://martech.pl/forum/viewforum.php?f=2 Polish Forum http://martech.pl/forum/viewforum.php?f=9 Russian Forum http://martech.pl/forum/viewforum.php?f=6 Frenh Forum http://martech.pl/forum/viewforum.php?f=26 Spanish Forum http://martech.pl/forum/viewforum.php?f=25 Arabic Forum http://martech.pl/forum/viewforum.php?f=27 Turkish Forum http://martech.pl/forum/viewforum.php?f=29 Be READY ! For next BIG updates Martech Team www.martech.pl www.martech.pl/shop/ www.martech.pl/forum/ www.martech.pl/server/ |
11-03-2009, 07:13 | #13 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer Update 03/11/2009 Martech Analyzer Update 02/11/2009 Firmware v00.08: - the correction of electricity measurement presentation mistake in Powe Supply mode -possibility of firmware changing within the sae firmware version (earlier versions have blocked that possibility) Manager database- Nokia, Samsung batteries added - special thanks to Wojtek Góralczyk (wgmmmx) |
12-15-2009, 20:23 | #15 (permalink) |
Member: 186466 Status: Offline Sonork: 100.112959 Thanks Meter: 9,125 | Martech Analyzer Update - 15.12.2009 Martech Analyzer Update - 15.12.2009 New functions added: Firmware v00.09 Major changes in update: - Exit/Cancel charging mode is improved - Stabilization of charger mode - Charging function is increased Marginal changes: - Code optimisation regarding call out procedures - Braeaks process optimisation We look forward for comments and feedbacks on [email protected] Latest PB243 firmware (English) : http://martech.pl/download/ANALYZER/...43_0009_EN.zip Latest PB243 firmware (Polish) : http://martech.pl/download/ANALYZER/...43_0009_PL.exe Best regards Martech Team |
RCD / DST / SQM Tools - updates in this topic | MARTECH | MARTECH CARS Category | 263 | 10-08-2020 13:53 |
VSZ Service Tools - updates in this topic | Holden | VSZ Service Tools | 101 | 09-20-2010 11:31 |
Martech Analyzer Update 31.07.2009 | Holden | Service Products News & Updates | 0 | 07-31-2009 14:57 |
Martech Analyzer Update - printing tests | Tech mobil | Service Products News & Updates | 0 | 07-25-2009 09:46 |
