Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
12-01-2001, 10:35 | #2 (permalink) |
Insane Poster Join Date: Aug 2000 Location: Russia Age: 48
Member: 1881 Status: Offline Thanks Meter: 1 | Warning - this is danger, but... if you still waiting for solution. Carefuly hot it with hot air. And push chip with tweezers up. The glue is melted then you hot it. Clean chip and pcb. |
12-02-2001, 00:49 | #3 (permalink) |
No Life Poster Join Date: Dec 2000 Location: UK
Member: 2868 Status: Offline Thanks Meter: 514 | Hi Skyfox.<br />I doubt it. The resin which is used to underfill Cobba on 3210, Ccont and RAM+Flash on 8210, also MAD2 on all models cannot be melted. I personaly managed to destroy one MAD2 (just for experiment) and did remove one Cobba, but with the PCB totaly damaged.<br />Best regards<br />Daniel |
12-02-2001, 03:24 | #4 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | yes, freestyler is right, i've already messed up some pcb and bga too, the glue can't be melted, even i've already heated it for a long time.<br />i think that the solution is that we must find some liquid or compound which could melted the glue first, some friends of mine suggest me to use amoniak, anybody ever heard about it ? |
12-03-2001, 14:39 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | The underfill "glue" , I think is called emicon. I've tried with scrap boards and was successful somehow. First, soak the board in lacquer thinner to soften the emicon then heat with large amounts of air. Not sure if it won't kill a useable board, but was successful in a scrap one. Hope this helps. Anybody with further info can chip in. |
12-07-2001, 00:18 | #6 (permalink) |
Freak Poster Join Date: Jul 2001
Member: 5364 Status: Offline Thanks Meter: 0 | Hi Guys.....maybe we r all being fooled....try freezing the board & then try breaking the glue off!!It seems to bond BETTER with more heat...hahaha...JUST AN IDEA!!Obviously i would suggest wrapping board in plastic or something....u never know,hey? |
i need bga ic glue remover | hans salim | BB5BOX | 11 | 01-29-2008 08:06 |
For All Tunisien : Bga ic glue remover and Smart clip Tp cable in Stock | The_Gorr | Main Sales Section | 0 | 10-19-2007 10:31 |
How to remove glue under Ccont in 8210? | Trier | Nokia Hardware & Hardware Repair | 12 | 11-02-2002 01:20 |
8210 glue under ccont bga ic | digipulse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2002 21:21 |
