Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
05-23-2002, 05:22 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Ukraine Age: 52
Member: 9893 Status: Offline Thanks Meter: 2 | Er T29 with unstable access to network I have Er T29 with unstable access to network. Sometimes PA not start or start and working unstable. Replacing PA - not help. Replacing 13 Meg cristal - not help. Any idea? Help please! |
05-23-2002, 05:46 | #2 (permalink) |
Guest
Posts: n/a
Member: | Damaged PCB. I have one T20 which was in same problems, and it was "repaired" but died after 2 hours of work. I've opened phone and checked visualy - Anntena connector was changed, Buzzer was removed and soldered again, but PCB is damaged, PA is also changed, now phone works only with external power.(With loud crackling from audio) So, i think there is problem with PCB below PA - if PA ****s it can damage PCB, and there is no repair solution. But in your case, you may change anntena connestor, it may help you. |
05-24-2002, 14:39 | #3 (permalink) |
No Life Poster Join Date: Apr 2000 Location: near you Age: 60
Member: 1196 Status: Offline Thanks Meter: 6 | also I have no network problem with T29 ,,,,T20 ,,,T28,,,, R310 ,,,I change everythink is possible in RF section and also 1011102 and reflow with hot air multi mode adapter ,,,change new signal processor ,,,filters also changed ,,,but nothing signal is 0 ,,, and always zero ,,and after few minutes ,,no network found |
W550 no access to network ? | yestelecom | Sony Ericsson Hardware Repair | 1 | 11-25-2011 07:40 |
K750i 'No access to Network | dons005 | Sony Ericsson Hardware Repair | 0 | 05-18-2007 10:30 |
plz help p900 no signal, no access to network.... | sniper01 | Sony Ericsson Hardware Repair | 0 | 09-05-2006 06:43 |
for cruiser w810i no access to network | ahmedmarten | Cruiser Suite | 0 | 08-29-2006 09:58 |
nok1100 no access to network | ovie sanco | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 06-17-2005 19:24 |
