Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
12-23-2002, 22:32 | #1 (permalink) |
Major Poster Join Date: Oct 2002 Age: 35
Member: 16443 Status: Offline Thanks Meter: 0 | Hot Air Station http://www.clasohlsson.com/WAG.asp?c...9&ic=N&sw=4294 |
12-24-2002, 16:34 | #3 (permalink) | |
Freak Poster Join Date: Jun 1999 Location: California Age: 50
Member: 255 Status: Offline Thanks Meter: 3 | Re: Hot Air Station Quote:
AND WHATS THIS IN ENGLISH ? CAN YOU TRANSLATE PLEASE . REGARDS | |
12-31-2002, 01:11 | #5 (permalink) |
Freak Poster Join Date: May 2002 Location: Sweden
Member: 12318 Status: Offline Thanks Meter: 5 | Hi I don´t think that will be to handy to replace Bga chip´s with Try to search something else This is definitly nothing for GSM repair unless You want to make some "grillade korv" (hot dogs) Rgs Poca |
01-04-2003, 00:14 | #7 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Europe - Poland Age: 45
Member: 14068 Status: Offline Thanks Meter: 0 | look this link: www.gsm-technology.com Hot-air station 250 euro. |
01-07-2003, 03:19 | #10 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | Czesc! wszystkiego najlepszego dla Polakow Z Australji!! From what i can see, this is a propane powered source of static hot air. it might work, but you have absolutely no control over air temperature & air strenght. You might end up ****ing every single component off the board or frying saome PCB layers. A proper hot air station has controls for air volume & temperature and also different nozzles. The only plus side is that, the burning propane flame depletes the air stream of free oxygen so the chance of corrosion is reduced. Better spend the $$$ and get the proper tools |
01-07-2003, 08:05 | #13 (permalink) |
Member: 16443 Status: Offline Thanks Meter: 0 | ska kila te skolan nu poca. 8210 funkar bättre.... signalen går ner ibland o stananr en tund eller hoppar... amplifiern lr RF switch, kan man köpa dom nånstans o fixa telefonen för gott? |
I need some advice about hot air station... | sifasli | Hardware Repair by brands | 4 | 03-02-2002 18:15 |
Hot air station | jan197 | Hardware Repair by brands | 0 | 02-25-2002 10:13 |
Hot air station to change bga? | sureshkumar13 | Hardware Repair by brands | 2 | 02-19-2002 04:44 |
Where can i buy hot air station for solder/'desolder? | Bogi | Hardware Equipments for GSM | 1 | 08-26-2001 20:07 |
Aoyue 850 or NET 850 hot air station HELP | NBG | Hardware Equipments for GSM | 0 | 07-05-2001 14:58 |
