Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
10-25-2002, 20:41 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: asia Age: 53
Member: 11742 Status: Offline Thanks Meter: 1 | t -28 without pa works 80% few months back, pa ic for t28 was not avalibel for replace, i was experementing with some other pa , solderd thin wires to each pad [pa removed], fited main board with display to matalic chaises,i insert sim and power on the phone ,phone boots serches for net work and ,,,,,amazungly it rigesters to net work,i just make a call and yes,, it was connected,,,,,,,strange ,,decided to find out how it happens, keeping in mind there is a drive stage for main tx amp,,,,one of the wires i had been soldred to the pads,,,was working as a tx an****a [I THINKS]. i removed wires one by one and find 1 wire acts as tx power , packed phone with this wire coiled inside ,but not touching to other part,,,,,does not work, then i decided to feed this wire directly to anttena ...and it works great...... the active wire and pad is 2nd from left bottom,,,,and to 2nd from the right bottom,,,,, it is for 900mhz works 80%,, when u r in basement or in a large coverd aera,it may not work properly,,,for 1800mhz ,,,it is 2nd pad from upper left to 2nd pad upper right side ,,,,, [NOT TESTED 1800MHZ] well i m not an expert some1 will explain how it works.... |
10-26-2002, 01:52 | #3 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | hi you can find your solution here http://groups.yahoo.com/group/wes_na...sson/Hardware/ goodluck wesam |
10-26-2002, 02:05 | #4 (permalink) |
Freak Poster Join Date: Feb 2001 Location: ...... Age: 52
Member: 3477 Status: Offline Thanks Meter: 3 | thanks man and here u can find my best solution i was test it with many more phones http://photos.groups.yahoo.com/group/dounlock/lst hope if it can help both of u best regards |
10-28-2002, 13:18 | #6 (permalink) |
Member: 3477 Status: Offline Thanks Meter: 3 | noooooo the short(wire) u will mad ...will mack a call 100% chick it again resize the pic .. and see the red line . dont lock only to the resistor we desolder. if u dont see the short i mad ..tell me ..i will mad it black for u . best regards |
10-29-2002, 03:49 | #9 (permalink) |
Member: 3477 Status: Offline Thanks Meter: 3 | i was upload new one now when the phone dead if u desolder r051 and the phone up .... (then the phone no axcess) so its ok ... keep r051 over ...and conect the link u will find on the pic . try to connect . its ok and working .. tested with over than 20 unit ... sucsses 80% ..for me at least . post resalt here please best regards |
10-29-2002, 19:29 | #10 (permalink) |
Member: 11742 Status: Offline Thanks Meter: 1 | t-28 hi pplz, this solution is specialy for those dead phones du to shortage of pa.if u check a dead t-28 with a multi meter connected to battery terminals and it shows full continuity on both polarity,,,,,just remove ' pa',,,,,, after removing pa u can see the solder pads where the pa was soldered,,,,,u will see 5 points[pads] on left vertical line and five on the right side ,,,,u have to solder a thin wire 2nd pad from bottom on the left line to 2nd pad from bottom in right side line,,,,,,i dont have any link to up load a picture but i am arranging ,and will upload .and give u the link... |
10-30-2002, 14:28 | #12 (permalink) |
Member: 11742 Status: Offline Thanks Meter: 1 | t-28 image. hi friends, i have just upload jpg image for t-28 without pa ,to the visar mato 's group u can see the link in above post by visar mato,just join the group, open ericsson files and there is t-28 rar image, use a jumper wire on red line for 900 mhz and for 1800 mhz use blu line link..... |
10-30-2002, 22:52 | #13 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: sk Age: 39
Member: 4128 Status: Offline Thanks Meter: 0 | Re: t-28 image. Quote:
thanks for interesting solution. I have little redrawed (resized, changed contrast, etc...) that picture posted by you, and uploaded it to same directory. Its now much smaller (only 60k). I hope its ok for you... Regards, BrainMAN | |
how to unlock iphone 2.2 with 2.28 - without wifi? | Boshko_Alfa | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 06-19-2009 10:08 |
GOT_MOTO v0034 - FREE unlock V3 RAZR (black) BL 08.28 without TP - FIRST in world | gotsupport | GOT Motorola | 44 | 01-28-2008 15:34 |
scdr II 28.04 not working | ayubalikhan | SCDR II | 0 | 12-05-2007 07:17 |
..:: Unlock without Testpoint - work or not work? ::.. | fingusio | Smart-Clip | 84 | 12-19-2006 18:22 |
Pa Working System | sevgigsm | Hardware Equipments for GSM | 0 | 12-31-2005 22:00 |
