Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
11-19-2002, 19:21 | #1 (permalink) |
Junior Member Join Date: Nov 2002 Location: Boxtel Age: 39
Member: 17926 Status: Offline Thanks Meter: 0 | [V50] How to open I want to try to fix it myself but I can't get it open. I hope you can give me a site or a tip on htis. And maybe some of you know were to dowload the schematics of this serie. V3690 or V50 thanks |
11-20-2002, 14:09 | #3 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | You can't disassemble V50 without small damages of case, if You don't have disassemble tools for V50. Anyway: 1. Remove battery 2. Remove antenna 3. Remove plastic lense (Where led lights) 4. Under battery You'll see 4 fixators (2 from left, 2 from right). Unfix it Now You disassemble 1/2 of V50!!! If You'll do this, I'll say You how to disassemble display part and remove display WBR |
11-20-2002, 18:53 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Palestine-Iraq-Afghanistan.... Age: 25
Member: 6478 Status: Offline Thanks Meter: 3 | dont you guys experiment? how can you learn without experimenting? to open v50 first important note unscreww ariel== & U must have very long thumbnails slide them thru the side gaps whilst prising @ the 4clip tabs on edge (IMEI label side)-click them 2wards the IMEI label prise open the phone carefully @same time leaving the antena top part still closed as u have to push the LED clear plastic stub out from inside the phone with a small long plastic screwdriver or sumthink like that. 2 remove the LCD (brown) clip push clip up 2ward you then carefully pull the flexistrip contact out check it reassemble - ) |
sl65 v50, how to.. | .:bono:. | S-Gold Based Phones | 0 | 04-14-2007 14:29 |
Siemens M65 v50 - how to repair? | zahyr | S-Gold Based Phones | 2 | 01-26-2006 13:50 |
M65 V50 How to unlock ? | sschn07 | S-Gold Based Phones | 1 | 10-15-2005 11:39 |
v50 - how to unlock??? | t_boaz | Phone Unlocking Codes & Maps | 0 | 09-22-2003 09:03 |
v50 - how to unlock??? | t_boaz | Motorola Old Legacy (EMMI) | 0 | 09-22-2003 08:23 |
