Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan > USB Pinfinder
Old 09-18-2010, 02:08   #1 (permalink)
Member: 1054831
Thanks Meter: 41
How to install usb pinfinder and to solve "USB NOT RECGNIZED" PROBLEM
HOW TO INSTALL PROPERLY:
This is the gadget it comes with a red alligator clip......
So what is the use of this? I search for answer....I cant find one...
It is use to modify the power cord of the spider box.....Install like this
Now lets install the chip to the spider box:
1. Disassemble the box....
2. Put the chip to pins provide in the board of the box
3.Assemble and Connect the box in your PC....Now u can see this
NOW ITS NOW READY TO USE FOR SPREADTRUM CHIP CHINAPHONES..
Old 09-18-2010, 02:17   #2 (permalink)
Member: 1054831
Thanks Meter: 41
BETA TEST FOR REMOVING A USERCODE OF 6300 W/ SPREADTRUM CHIPSET:
1.Click Connect....click spreadtrum in the tab.....choose hardware type according to the spreadtrum IC....(it is indicated at the ic)...
In my case it is (SC6600L-USB)-(Manual).
3. then search the phone......(using the Inteligent port....and the usual cable....w/ modified the red alligator clip)
HERE COMES THE TRICK:...BECAUSE WHEN YOU CLICK BOOT IT WILL BE"USB NOT RECOGNIZED" AND IT WILL NOT CONTINUE TO BOOT....AND YOU CANNOT DO ANYTHING WHEN THE PHONE DOEST BOOT...
4. After you search the phone in the usaual way...using usual cable....
YOU WILL BE NEEDING....
a. 2 mini usb cables...where one usb is cut...
b. One is put in the usb port and the other one which is cut to the board.....find the pin out.....in our case...white wire is in the RX and Green wire is the TX and the black wire is the ground.....
c. Connect the 2 usb in your PC....and supply power using the modified alligator clip that comes in the package...and it will now detect by the computer.....it can now be recognized by the computer.....
and you will be needing this Drivers: Driver.rar
install drivers
now the phone sucessfully boot
now tick user code:
try all codes.....in my case it is: 25800
now the phone is ok.....
Now let us try to format the phone.......(for testing only)
Just Click format and uncheck user define format adress
I HOPE IT WILL HELP ALL USERS HAVING PROBLEM WITH INSTALLATION AND "USB NOT RECOGNIZED WHEN BOOING THE PHONE......
The Following 6 Users Say Thank You to pats79 For This Useful Post:
Old 09-21-2010, 07:31   #3 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
It is not clear......
means..modify the power cable where????
the rad clip which is come with the box....I want to replace with the spiderman power cable
or I want to connect it to USB...
Also what about the cable which is come with spiderman...
U also solder the rx and tx...So no need to connect the cable...
Could You please take a full picture because some picture is cut..So have little problems to identify the cable.
But any how thanks for your hard work which the supporter did not know what their product is.......failed to rectify the problem.
you don't how much of money I loose because of this.......
Regards,
Old 11-14-2010, 17:23   #4 (permalink)
Mohsin_josh's Avatar
Member: 78884
Sonork: mohsin111
Thanks Meter: 92
Regards,
yes same problem here help me full picture
Old 11-16-2010, 17:31   #5 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
i can help u contact with me
Old 11-16-2010, 18:20   #6 (permalink)
Member: 1357721
Thanks Meter: 4,294,967,292
helloo Guys
i m having problem with my spiderman Box
When i connect computer find the box
software connect the box with PC
but cannot Search Phone
everythhing same like whn v connect the power with Phone it beeps
but cannot search the Phone
Solution i m having this problem since from last 1 week and i have tested many new and old ok running Phones but same problem.
Any soloution ??
Cz Spiderman team wont Reply for this as they did with other Users..
Old 11-16-2010, 18:27   #7 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
Thumbs down
hi sir i have buy a new spd card its instol buit i dot j have other read pin for power i buy also new pin but wher is cannet sir i pin inth box 5 volt or pc usb 5 volt sir ple help me
Old 11-18-2010, 18:27   #8 (permalink)
Member: 1217818
Thanks Meter: 31
HELOO BROTHER TOADY I BOUGHT USB PINFINDER CHIP BUT MY RELLER NOT PROVIDE
ANY no anay modify the power cable how to work ?
Old 02-12-2011, 12:28   #9 (permalink)
Crazy Poster
Member: 1088283
Thanks Meter: 2
bro just use your old power cable which was used with mtk cpu's .i tested it with spreadtrum cpu's
but use the latest version 2.70 full.
Old 02-17-2011, 11:01   #10 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
Could you please give me a good picture..
Or please upload someare..
Because I can not understand the picture ...
Thanks
Old 03-14-2011, 06:01   #11 (permalink)
Member: 1198348
Sonork: gulabverma
Thanks Meter: 32
it is better to go to some other box which can solve this problem easily
install drivers
now tick user code:
Old 03-14-2011, 06:03   #12 (permalink)
mobilecare.vcl's Avatar
Member: 1334005
Sonork: 100.1601457
Thanks Meter: 362
goooooooooooooooood job brotherrrrrrrrrrrrrrrrrrrr
The Following User Says Thank You to mobilecare.vcl For This Useful Post:
Old 04-11-2011, 16:28   #13 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
what is the function of red cable which comes with usb pin finder. when i bought usb pin finder it was not here i took only chip not cable .. know i am facing strange problem "usb not recognize" my main question is why this problem is coming else without red cable or others .............. i see a mini part located in centre of cable. what is this.
Old 04-11-2011, 16:35   #14 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
this is the cable which comes with usb pin finder. see a mini part coated in plastic i want the reveal what is this?? what is the function of this mini part
Old 06-22-2011, 03:47   #15 (permalink)
DEADBOOT's Avatar
Member: 467922
Sonork: 100.1612115
Thanks Meter: 215
@pat79
Sir can you tell us how to modifie the power cable or you called it RED ALLIGATOR CLIP?
please show us the picture what inside the wire of red alligator clip,or what kind of resistor of that..
see the blue circle of the picture below...
[IMG][/IMG]
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.30409 seconds with 9 queries
