Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPGIndustries Cables > GPGUFC - The best Universal Fbus Cables ever made
Old 11-28-2008, 20:56   #1 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Is UFC compatible with MT-Box?
As I ask in the title is it compatible with MT-box?
Old 11-28-2008, 21:04   #2 (permalink)
kaligola's Avatar
Member: 239318
Thanks Meter: 51
there is version 7 pin and mt version 10 pin
i use it and is very helpful
Old 12-12-2008, 12:33   #3 (permalink)
Bharat Dhingra's Avatar
Member: 620594
Thanks Meter: 38
Just wanna make sure
Is this cable is Compatible with JAF and MTBOX ????
Or
There are some models which are not supported by this cable for MTBOX.. Coz as it's description it is clear that this cable 100 % worked for JAF.
And what about RAPID0 phones like N95 which need 10k resistance. Is this compatible with that as well ??
Plz Reply Supporters
Thanks !!!
The Following User Says Thank You to Bharat Dhingra For This Useful Post:
Old 12-15-2008, 05:12   #4 (permalink)
GPGIndustries's Avatar
Member: 34016
Sonork: 100.67372
Thanks Meter: 24,594
Kinldy check this link will introduce to our UFC Special MT edition
http://www.unifbuscable.com/gallery.php?page=Gallery
More over our selector include 10K resistors so will be fully compatible
The Following User Says Thank You to GPGIndustries For This Useful Post:
Old 12-15-2008, 16:14   #5 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
u should check this link.
N82, N95, E90 can't local mode with UFC MT edition,
maybe should get some revision in next product,
give selection 15K and 68K ohms between BSI line and ground,
also diode in BSI line, or some 8-10K on BSI line.
here's pic of cable that tested to flashing and local mode N95,N82 with MTbox,
cable scheme provided at GTI forum, and we need to put NOKIA CHARGER ACP12 on MTbox device to make local mode stable.
i think it's should be workin on E90 too...
N82
N95
please make again new workin cable, the most important for MTbox user is for RAPIDO phone.
br,
kevin168
UFC cable compatibility with CYCLONE BOX... BEST SOLUTION FOR LOCAL MODE PROBLEM!! Hell-GSM Cyclonebox 29 02-23-2010 15:08
MT Box (Nokia) Activated with MT Box (Siemens) Functions & BB5Act & BB5+ & MT Box (SE IPMART ipmart WebShop 0 05-23-2009 04:00
MT Box (Nokia) Activated with MT Box (Siemens) Functions & BB5Act + 6 pcs MT Box (SE) IPMART ipmart WebShop 0 11-17-2008 13:10
New 10Pin 26 In 1 Cable Set Compatible For MT Box (exclusive 68pcs MT Box cables) IPMART ipmart WebShop 0 11-05-2008 14:50
Page generated in 0.16066 seconds with 9 queries
