02-04-2010, 06:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 36
Member: 112131 Status: Offline Sonork: 1582257 Thanks Meter: 80 | UFC cable compatibility with CYCLONE BOX... BEST SOLUTION FOR LOCAL MODE PROBLEM!! I want to buy: http://www.gsmserver.com/shop/cables..._12_cables.php or http://www.gsmserver.com/shop/cables...box_cables.php I have a modified TX2 adapter so I want to get rid of it if I can.. because he works but not as STABLE as I want to!!!! The questions are???? 1. Could someone answer me if this cables WORKS on CycloneBox without TX2 Adapter??????? http://www.gsmserver.com/shop/cables..._12_cables.php If the answer is YES.. 2. Then How I connect this cables to the PHONE because I only see two Cables for the battery. VCC and GND(GROUND) the BSI cable is just a PIN cable son how you connect this??? I have UFC cables from IPMART... 3. Does this solves every problem with HIGH-POWER phones such as N95-8Gb and 5800d?????? 4. I need to connect an external Nokia charger to the power socket????? 5. Give me a solution please I i have a TX2 adapter modified and witch of this cables do you recommend me to buy: http://www.gsmserver.com/shop/cables..._12_cables.php or http://www.gsmserver.com/shop/cables...box_cables.php Try giving serious answers and try to effort as much as you can to explain!!! PLEASE!!!!!! THANKS IN ADVANCE HeLL-GSM!!! |
02-04-2010, 07:28 | #2 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Rep Dom Age: 38
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | The cables I use the yellow wire without bringing the cyclone are these http://www.ipmart.com/contents/products/P140000/140658/pic_wp.jpg these work great to me. |
02-04-2010, 07:33 | #3 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | Here I leave a small tutorial on how to use them http://rapidshare.com/files/34565937...point.pdf.html I this one for you to know that resistance value selected for each model. http://rapidshare.com/files/345660273/nokia_testpoint_and_resistance_for_UFC_V2.pdf.html |
The Following User Says Thank You to boliargsm For This Useful Post: |
02-04-2010, 07:41 | #4 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | This package brings cable wires only VBAT and bsi and works perfectly for the cyclone, the VBAT is placed on the positive of the telephone, and in the neutral bsi I use it without the yellow wire that brings the cyclone and it works very well |
02-04-2010, 14:45 | #5 (permalink) | |
Member: 112131 Status: Offline Sonork: 1582257 Thanks Meter: 80 | Quote:
http://www.ipmart.com/main/product/i...hp?prod=140658 2. Thanks for the tutorial does the GND (ground) cable that I see in the tutorial came with the COMBO Cable???... I dont see it anywhere in IPMART Pictures http://www.ipmart.com/contents/produ...pic/extra3.jpg 3. I also red in the IPMART shop this: "# CYCLONE BOX (need use JAF / UFS Adapter Cable For Cyclone Box) " 4. Does it fix the NOT ENTERING TEST MODE problem??? Without the use of TMA Adapter?? THANKS!!! | |
02-04-2010, 17:00 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Hi Harold, I use always the TX2 adapter with the TMA adapter or the cyclone V2 adapter when working with the BB5 mobiles. The UFC cables are made on the jaf pinouts so don't have the pinout conversion needed by Cyclone for the bb5 mobiles. BR Alex |
The Following 2 Users Say Thank You to moulnisky For This Useful Post: |
02-04-2010, 19:40 | #7 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | hello all, @Hell-GSM I have one TMA and this is work verry good with my Cyclone box, but from some time (after use about 5 month) no the TMA don't work, I don't know if it's bad product or no, you see my message here so if some one can advice me an other product for put BB5 in local mode and best from TMA ? Best Regards, JAVA Good. |
02-04-2010, 20:27 | #8 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | I use the TMA since 2 months before it was on the market (My one is a prototipe still in red color, not in blue) Never had problems with it.. may be you should check the RJ45 side Cable for any soldering loose As well I use the Cyclone V2 adapter (This one as well prototipe lol) and it works perfect as well BR Alex |
02-04-2010, 22:17 | #9 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | and can I buy this prototype from some place, or realy prototype and don't have in marcket ? and they have other good product for put Nokia in Local Mode ? Best Regards, JAVA Good. |
02-05-2010, 02:58 | #11 (permalink) |
Member: 112131 Status: Offline Sonork: 1582257 Thanks Meter: 80 | @JAVA Good it is the TX2 adapter... Of course, I use the Schematics in this post http://forum.gsmhosting.com/vbb/showthread.php?t=747969 Read from TOP to Bottom!!! And find the best one for you!! I did it and I have LOCAL MODE for difficult phones. But it is not that easy to get, sometimes I have to try many times... I am looking for a Solution to this problem!!!! Buying this new UFC V2 Cable but only with this cable I am ok???? If you find some solution just tell me!! Thanks!!! |
02-05-2010, 10:36 | #12 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | tks for your reply, about me with TMA is verry easy to put the phone in Local mode, I unlock the RM-320 in the first time all the time, but now because my TMA not work, I am like a baby, some time I use HWK Micro with anny Fbus cable and rival software, and the phone to Local mode like a charme with out TMA, but now I have one RM-320 in my hand, and can't unlock it, all the time have error : Failed to Boot / Prepare Phone I see one time on Ipart web site I think have a product for put the Nokia in Local mode in 5 second, now need know if this product is realy good or no. Best Regards, JAVA Good. |
02-05-2010, 11:36 | #13 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | The SMA adapter of IP mart is just a clone of the TMA evolution.. nothing more then this You can use the Cyclone V2 adapter which, with the selector on DCT4 position, works perfect with all the other boxes with JAF/UFS pinouts It has as well the BSI correction and the Power Gestion as the TMA Evo BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
02-05-2010, 15:33 | #14 (permalink) |
Member: 112131 Status: Offline Sonork: 1582257 Thanks Meter: 80 | THE BEST SOLUTION I FOUND IS THE FALLOWING!!!! JUST BUY A NEW CYCLONE v2 ADAPTER from GSMSERVER!!!! http://www.gsmserver.com/shop/cables..._0_adapter.php MY FBUS cable set is working great... But I like this one much more!!! http://www.gsmserver.com/shop/cables..._12_cables.php It should work to... right??? With the UFCV2??? No need to buy anything extra???? BEST OF REGARDS!!!!!!!!!!! |
02-05-2010, 16:55 | #15 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hello all and tks for your reply, I solve my probleme on my RM-320 with my UFC v2, but anny one can tell me pls what is the roll of Rx2, MBus needle ? they have also one Mt Box VPP needle maybe this one for MTBox ? and what is the role also of USB connector pls ? maybe today get 1 or 2 hours for read all this thread Best Regards, JAVA Good. |
cyclone box can't change to main mode [SOLVED - Thanks HRCO] | banalven1 | Cyclonebox | 5 | 03-29-2010 09:34 |
Mt-box cables use with cyclone box! | unterulmen | Cyclonebox | 1 | 01-31-2010 00:32 |
Problem with CYCLONE BOX It connects As Boot-laoder Mode But doesnt change Mode... | malikzahidawan | Cyclonebox | 3 | 09-06-2009 22:22 |
solution for local mode | blackson | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-09-2008 13:08 |
