11-17-2008, 20:19 | #1 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | ::Phones tested with UniFbus & working:: Waiting your experience BR Luskao |
11-18-2008, 22:32 | #2 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | JAF version 1.98.56 Detected PKEY: 9000000 Card life counter: 96.38% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-1 (c) Nokia. HW version: 6220 PCI version: RFIC version: 150a160f DSP version: pb04w47v26 Retu version: 32 Tahvo version: 52 Production serial number: UB3747833 Product code: 0532844 Module code: Basic production code: 0600395 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352259011283153 IMEI spare to net: 3A 25 52 09 11 82 13 05 IMEI SV to net: 33 25 52 09 11 82 13 65 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140100000000000 Provider: Vodafone / Airtel Movil;Spain Key Code count: 1, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 21401F Block 2: Lock 1: CLOSED -> Lock Data: 21401F Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-1.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0532844 INI file 0532844.ini is missing. Continue searching for second ini type... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! UNLOCKING NOW Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\352259011283153_CRT_ba ckup_21361811.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140100000000000 Provider: Vodafone / Airtel Movil;Spain Key Code count: 1, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 21401F Block 2: Lock 1: CLOSED -> Lock Data: 21401F Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Unlock Codes: #pw+206195161371459+7# #pw+123303646687887+6# #pw+266393359106365+5# #pw+075823918209867+4# #pw+775287119020925+3# #pw+442617981367342+2# #pw+364211766100542+1# Uploading code to phone... Reseting phone... Waiting for phone... Reading soft info... Unlocking... Reseting phone.... Waiting for phone... Reading soft info... Reading simlock data... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140100000000000 Provider: Vodafone / Airtel Movil;Spain Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Done! 6630 succesfully unlocked through JAF and UNIFBUS CABLE. I used cable 3 and 5.1 Tomorrow N81 and N95 |
12-04-2008, 04:24 | #5 (permalink) |
No Life Poster Join Date: Jun 2002 Location: *Portugal* Lisbon* Age: 45
Member: 13223 Status: Offline Thanks Meter: 59 | MT-Box n95 Flash-unlock Tested and ok n95-8gb Flash-unlock Tested and ok N81- Flash-unlock Tested and ok 5200- Flash-unlock Tested and ok 5300- Flash-unlock Tested and ok n70- Flash-unlock Tested and ok n91 Flash-unlock Tested and ok 6110 Flash-unlock Tested and ok 6280- Flash-unlock Tested and ok 6288- Flash-unlock Tested and ok n73- Flash-unlock Tested and ok |
12-04-2008, 15:23 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | JAF-Box 1112 , 1208 , 1208b , 2310 , 2626 , 6030b , 7070 dct4+ tested OK 2760 , 2630 dct4++ tested OK 3500c , 6131 , 5200 , 5300 , 6234 , E65 , N80 , N95 BB5 tested OK br elcapitel |
05-29-2009, 14:35 | #8 (permalink) |
Insane Poster Join Date: May 2009
Member: 1040508 Status: Offline Thanks Meter: 4 | This program to choice Resistance etc. is really **** and programm on www, too for example N95 can get local mode only with resitance 3.5 in JAF, 7.5 doesn't work!! MTBOX the same and you have to got power in (APC-12) VCC, GND and BSI is wrong too on photos and in programm, correct is at baterry + - 0 (GND in the middle) |
05-29-2009, 14:49 | #9 (permalink) | |
Member: 1040508 Status: Offline Thanks Meter: 4 | Quote:
06-03-2009, 03:44 | #10 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Thailand
Member: 191096 Status: Offline Sonork: 1610034 Thanks Meter: 475 | Tested on N1202 RH-112 many time. Both JAF and UFS. Here is JAF LOG. Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini FILES SET FOR FLASHING: MCU Flash file: F:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100 PPM Flash file: F:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mc CNT Flash file: F:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mc ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Thailand Done! MCU: F:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100 Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG(SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 84E579C92A784F27EAC0305BE8 MSID decoded: 3E4EBAE9000F2BFFA8000000 FAID: AC7C44BE19737B334F3A9A22 Operation took 0 minutes 10 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 26 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 14 seconds... Restarting MCU... PPM: F:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10mc Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG(SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 84E579C92A784F27EAC0305BE8 MSID decoded: 3E4EBAE9000F2BFFA8000000 FAID: AC7C44BE19737B334F3A9A22 Operation took 0 minutes 10 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 8 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... CNT: F:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10mc Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG(SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 84E579C92A784F27EAC0305BE8 MSID decoded: 3E4EBAE9000F2BFFA8000000 FAID: AC7C44BE19737B334F3A9A22 Operation took 0 minutes 10 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 1 minutes 33 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-112, Software version: 03.10 IMEI: 35193xxxxxxxxxx Product Code: 0562273 Resetting PPC... Done! |
07-01-2009, 09:57 | #13 (permalink) |
Member: 1040508 Status: Offline Thanks Meter: 4 | Hi, I use 9w1 (black cable fot MT, and red for JAF) and I need adapter cable, too? I put black (10 pin) into mtbox and bsi 3.3K, 5K etc. and doesn't work. Maybe I should put adapter between this 9w1 adapter and phone, not box and phone. I don't know ;-) |
W08 Watch Phone With Bluetooth & Camera & Waterproof - black with silver banding | IPMART | ipmart WebShop | 0 | 11-06-2008 07:00 |
tested E65 with unifbus from GPG | UHK | BB5KING for (BB5BOX) | 0 | 11-03-2008 16:21 |
Cracked DIV 8.1 Testing Result With T610 & T68i | kennyli | Sony Ericsson | 25 | 09-01-2003 12:34 |
TESTING SIM CLONING WITH 6310i & 6510 | cut_r2000 | Sim Cloning and Scaning | 0 | 06-09-2002 10:52 |
