04-24-2009, 12:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | UFC modified can testmode/localmode check R6, i detached one side BSI from Box and jumper it to BSI line to Bat Term, now i can do Testmode in my 6300. i think you got to check.... |
04-24-2009, 13:05 | #4 (permalink) |
Member: 1009679 Status: Offline Thanks Meter: 166 | for 6300 model.... what i did is just follow pins' position, what i mean is i used 7 pins cable and cover the 6th pin on board. so this method is applicable also to 3110c and possible the rest of BB5 units. tested personally just moments ago. so please check and try also to other units if will success...post here results |
04-24-2009, 15:08 | #5 (permalink) |
Member: 1009679 Status: Offline Thanks Meter: 166 | tested in E63 here is log JAF version 1.98.63 Detected PKEY: xxxxxxx Card life counter: 66.01% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! Booting phone... FAST PHONE detected! CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 18B00013817300528BDC67F22843712738315E04 HASH: 9A28E119033B91D14D22838C86D0D53C00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR71_08w44.1 30-10-08 RM-437 (c) Nokia HW version: 0801 PCI version: RFIC version: DSP version: Retu version: 16 Tahvo version: 22 Production serial number: M7I028539 Product code: 0569948 Module code: Basic production code: 0561985 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 359319020832250 IMEI spare to net: 3A 95 13 09 02 38 22 05 IMEI SV to net: 33 95 13 09 02 38 22 05 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-437.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0569948 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-437\ Searching for default location of ini... Checking path: \Products\RM-437\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-437\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
11-05-2009, 21:58 | #7 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
All bb5 testmode/localmode solution................ | rumenshom | Nokia Hardware & Hardware Repair | 6 | 01-19-2009 11:58 |
All bb5 testmode/localmode solution................ | rumenshom | Nokia Hardware & Hardware Repair | 0 | 01-10-2009 17:03 |
All bb5 testmode/localmode solution................ | rumenshom | Nokia Hardware & Hardware Repair | 0 | 01-07-2009 08:23 |
all bb5 testmode/localmode solution..... | rumenshom | Nokia Hardware & Hardware Repair | 2 | 01-06-2009 17:28 |
all bb5 testmode/localmode solution..... | rumenshom | Nokia Hardware & Hardware Repair | 0 | 01-06-2009 16:40 |
