03-30-2016, 19:27 | #1 (permalink) | |||
Freak Poster Join Date: May 2013 Location: Nigeria
Member: 1931004 Status: Offline Sonork: 100.1662382 Thanks Meter: 85 | LG A390, A395, C297, C299 Common: Not implemented yet:Storage not supported error I don't know where i was wrong @the_laser, Danish Shafiq & others As i read the LGE Tool update history i see that LG A390, A395, C297 & C299 where supported since v2.37 followed by Flash Firmware feature on v2.41. As you can see below: Quote:
but my problem is that any time i try to connect all the above mentioned phones failed and i end up with this error: Common: Not implemented yet:Storage not supported as you can see i even try all the below setups which some where hard to get online because link is old but still failed. where am i wrong ? i know its not issue of O.S as i try on xp,7,8.1,10 and all give same error! I even try to register on LGE Tool support because of this, i also failed, look like some thing is wrong, i cant see register on FORUM as it was described at manual. My only option is to request for help @GSM-FORUM, If any one have knowledge on how to solve this issue pls help as i waste my time and energy to solve this phones issue with LGE Tool but i end up failing multiple times. | |||
The Following 2 Users Say Thank You to binadam23 For This Useful Post: |
07-08-2016, 15:10 | #2 (permalink) | |
No Life Poster Join Date: Sep 2009 Location: BURKINA FASO
Member: 1120289 Status: Offline Thanks Meter: 148 | did you find solution for it. Quote:
Connecting with A395 loading loaders ... Disconnect battery and connect cable to the phone Protocol: getBootloaderVersion failed Connecting with A395 loading loaders ... Disconnect battery and connect cable to the phone Phone found Disabling watchdog.. Latching powerkey... Sending loader 1 Sending loader 2 Transferring control to DA Connecting to DA... Send Clock setting Detect NAND Flash Connected Common: Not implemented yet:Storage not supported | |
The Following User Says Thank You to wahablepirate For This Useful Post: |
