Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GPG-Setool3
Old 04-21-2016, 09:47   #121 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 247
Wink
Originally Posted by ask4moon View Post
Samsung Galaxy Mini GT 5570 Successfully Unlocked
ask4moon
should we just forget this tool.i was every good tool
Old 05-08-2016, 17:34   #122 (permalink)
Member: 2266626
Thanks Meter: 40
w580i orange unlock done.
SPEED: 921600
LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
FLASH ID: 897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35344802304699 CERT:RED
ACTIVE CID: 52 COLOR: RED
Model (from GDFS): W580i
Brand: ORANGE F
MAPP CXC article: R8BE001 prgCXC1123474_ORANGE_LA
MAPP CXC version: R8BE001
Language Package: ORANGE_GEN
CDA article: CDA102774/19
CDA version: R14A
Default article: cxc1123364
Default version: R8BE001
NETWORK LOCKED
PROVIDER: 208-01F
PROVIDER: 340-01F
PROVIDER: 647-00F
SECURITY UNITS BACKUP CREATED
llbug: read error: "Le périphérique ne reconnaît pas la commande"
Elapsed: 15 seconds
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000000000
ChipID: 9900, EMP protocol: 0301
BOOTROM MODE DETECTED
SPEED: 921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35344xxxxxxxx
CURRENT CID: 52 COLOR: RED
FLASH ID: 897E
Downgrading security ...
DETACH CABLE FROM PHONE, THEN
CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
SPEED: 921600
RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
GOT SEED: 476763BA2380A86425B0634A
P96 AUTH PASSED
Restarting ...
SPEED: 921600
LDR: DB2020 LOADER FOR SETOOL2
CURRENT CID: 49 COLOR: BROWN
Setting up GDFS ...
WRITING CLEAR SIMLOCK UNITS ...
SIMLOCK CODES SET TO "47012777"
SIGNING ...
Unlock DONE
Elapsed: 59 seconds
Old 06-01-2016, 15:50   #123 (permalink)
ikram tabassum1's Avatar
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
SUCCESSFULLY UNLOCK LG H220 WITH LGTOOL
Connecting with H220
Action cancelled
Connected
Receiving phone info
Getting phone info
Model: H220
Platform: LG Qualcomm
Software Platform: Android
SDRAM Size: 512 MB
NAND Flash Size: 4 GB
CPU: MSM8210
Firmware Released: Oct 15 2015 13:10:13
Firmware Compiled: Dec 30 2014 03:00:00
Firmware Version: WX_PROJE/M8610B-AAAANAZM-1.0.6063
IMEI: 359531-06-082137-9
Connect mode: Normal
Info received
Unlocking phone
Unlock: Start
Backuping NVM to file: Backups\H220_nvm_359531060821379_2016-6-1_19-39-32.sbf
Dump NVM: Start
Getting phone info...
Getting phone info: OK
Switching to NVM mode...
Switching to NVM mode: OK
Dumping NVM...
Dumping NVM: OK
Switching to normal mode...
Switching to normal mode: OK
Dump NVM: Finish
Backuping EFS to file: Backups\H220_efs_359531060821379_2016-6-1_19-44-50.sbf
Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes
Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes
Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes
Downloading file /nv/item_files/conf/cgps_me.conf 1.14 Kb
Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes
Downloading file /nv/item_files/conf/cgps_pe.conf 113 bytes
Downloading file /nv/item_files/conf/cgps_sm.conf 638 bytes
Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 710 bytes
Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.10 Kb
Downloading file /nv/item_files/conf/data_config_info.conf 1.38 Kb
Downloading file /nv/item_files/conf/geran.conf 379 bytes
Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes
Downloading file /nv/item_files/conf/mcfg.conf 176 bytes
Downloading file /nv/item_files/conf/mcpm.conf 101 bytes
Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes
Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 4.44 Kb
Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 466 bytes
Downloading file /nv/item_files/conf/mcs_trm.conf 43 bytes
Downloading file /nv/item_files/conf/mmgsdi.conf 1.32 Kb
Downloading file /nv/item_files/conf/mmode.conf 1.15 Kb
Downloading file /nv/item_files/conf/nas_mm.conf 690 bytes
Downloading file /nv/item_files/conf/pbm.conf 238 bytes
Downloading file /nv/item_files/conf/ps_config_info.conf 316 bytes
Downloading file /nv/item_files/conf/qmi_data.conf 43 bytes
Downloading file /nv/item_files/conf/reg.conf 603 bytes
Downloading file /nv/item_files/conf/rrc_feature.conf 43 bytes
Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes
Downloading file /nv/item_files/conf/uimdrv.conf 542 bytes
Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 480 bytes
Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 18 bytes
Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 0 bytes
Downloading file /nv/item_files/conf/wl1_cme.conf 171 bytes
Downloading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes
Downloading file /nv/item_files/conf/wl1_fet.conf 41 bytes
Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes
Downloading file /nv/item_files/conf/wl1ul.conf 40 bytes
Downloading file /nv/item_files/conf/wms.conf 410 bytes
Downloading file /nv/item_files/mcs/cxm/coex_config_data 384 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/1x_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/default_tech_ddr_freq_plan 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm1_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm2_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/hdr_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/lte_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/tdscdma_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/ddr/wcdma_victim_ddr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_1x_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_gsm2_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_gsm2_victim_tdscdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes
Downloading file /nv/item_files/mcs/tcxomgr/ft_table 768 bytes
Downloading file /nv/item_files/modem/mmode/sd/loc_base_bsr_mcc_list 204 bytes
Downloading file /nv/item_files/modem/mmode/sd/sdssscr_timers 204 bytes
Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes
Downloading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes
Downloading file /nv/item_files/modem/uim/gstk/rat_priority_config 26 bytes
Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes
Downloading file /nv/item_files/modem/uim/uimdrv/uim_sys_info 256 bytes
Downloading file /nv/item_files/rfnv/00022975 491 bytes
Downloading file /nv/item_files/rfnv/00022976 505 bytes
Downloading file /nv/item_files/rfnv/00022978 502 bytes
Downloading file /nv/item_files/rfnv/00022979 449 bytes
Downloading file /nv/item_files/rfnv/00022982 529 bytes
Downloading file /nv/item_files/rfnv/00024964 193 bytes
Downloading file /nv/item_files/rfnv/00024965 193 bytes
Downloading file /nv/item_files/rfnv/00024966 193 bytes
Downloading file /nv/item_files/rfnv/00024967 193 bytes
Downloading file /nv/item_files/rfnv/00024972 2.97 Kb
Downloading file /nv/item_files/rfnv/00024973 2.97 Kb
Downloading file /nv/item_files/rfnv/00024974 2.49 Kb
Downloading file /nv/item_files/rfnv/00024975 2.49 Kb
Downloading file /nv/item_files/rfnv/00025004 192 bytes
Downloading file /nv/item_files/rfnv/00025005 192 bytes
Downloading file /nv/item_files/rfnv/00025006 192 bytes
Downloading file /nv/item_files/rfnv/00025007 192 bytes
Downloading file /nv/item_files/rfnv/00025044 160 bytes
Downloading file /nv/item_files/rfnv/00025045 160 bytes
Downloading file /nv/item_files/rfnv/00025046 160 bytes
Downloading file /nv/item_files/rfnv/00025047 160 bytes
Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes
Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes
Checking Emergency Mode...
Mode: Normal
Switching to Emergency Mode...
Mode: Emergency
Checking connect in LAF-Emergency Mode...
Checking...
Checking connect in LAF-Emergency Mode: OK
Imei: 359531060821379
Pid: CH31S150718003024
ModelName: LG-H220
BatteryLevel: 43%
DeviceSwVersion: H22010k
DeviceFactoryVersion: LGH220AT-02-V10d-234-30-VUK-OCT-15-2015+0
ChipsetPlatform: msm8610
HardwareRevision: rev_10
LafSwVersion: 1.0
DeviceFactoryOutVersion: LGH220AT-00-V10k-OP1-SI-OCT-15-2015+0
Dumping Security Backup...
Reading modemst1 [26c00, 1800]
Reading modemst1: OK
Reading modemst2 [28400, 1800]
Reading modemst2: OK
Backuping Security to file: Backups\H220_security_359531060821379_2016-6-1_19-45-48.sbf
Writing security to file...
Writing security to file: OK
Dumping Security Backup: OK
Flashing Patched Security...
Writing modemst1 [26c00, 1800]
Writing modemst1: OK
Writing modemst2 [28400, 1800]
Writing modemst2: OK
Flashing Patched Security: OK
Writing NVM-Backup from file: Backups\H220_nvm_359531060821379_2016-6-1_19-39-32.sbf
Flash NVM: Start
Flashing NVM...
Flashing NVM: OK
Flash NVM: Finish
Writing EFS-Backup from file: Backups\H220_efs_359531060821379_2016-6-1_19-44-50.sbf
Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes
Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes
Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes
Uploading file /nv/item_files/conf/cgps_me.conf 1.14 Kb
Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes
Uploading file /nv/item_files/conf/cgps_pe.conf 113 bytes
Uploading file /nv/item_files/conf/cgps_sm.conf 638 bytes
Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 710 bytes
Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.10 Kb
Uploading file /nv/item_files/conf/data_config_info.conf 1.38 Kb
Uploading file /nv/item_files/conf/geran.conf 379 bytes
Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes
Uploading file /nv/item_files/conf/mcfg.conf 176 bytes
Uploading file /nv/item_files/conf/mcpm.conf 101 bytes
Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes
Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 4.44 Kb
Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 466 bytes
Uploading file /nv/item_files/conf/mcs_trm.conf 43 bytes
Uploading file /nv/item_files/conf/mmgsdi.conf 1.32 Kb
Uploading file /nv/item_files/conf/mmode.conf 1.15 Kb
Uploading file /nv/item_files/conf/nas_mm.conf 690 bytes
Uploading file /nv/item_files/conf/pbm.conf 238 bytes
Uploading file /nv/item_files/conf/ps_config_info.conf 316 bytes
Uploading file /nv/item_files/conf/qmi_data.conf 43 bytes
Uploading file /nv/item_files/conf/reg.conf 603 bytes
Uploading file /nv/item_files/conf/rrc_feature.conf 43 bytes
Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes
Uploading file /nv/item_files/conf/uimdrv.conf 542 bytes
Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 480 bytes
Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 18 bytes
Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 0 bytes
Uploading file /nv/item_files/conf/wl1_cme.conf 171 bytes
Uploading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes
Uploading file /nv/item_files/conf/wl1_fet.conf 41 bytes
Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes
Uploading file /nv/item_files/conf/wl1ul.conf 40 bytes
Uploading file /nv/item_files/conf/wms.conf 410 bytes
Uploading file /nv/item_files/mcs/cxm/coex_config_data 384 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/1x_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/default_tech_ddr_freq_plan 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm1_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/gsm2_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/hdr_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/lte_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/tdscdma_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/ddr/wcdma_victim_ddr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_1x_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_gsm2_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_gsm2_victim_tdscdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes
Uploading file /nv/item_files/mcs/tcxomgr/ft_table 768 bytes
Uploading file /nv/item_files/modem/mmode/sd/loc_base_bsr_mcc_list 204 bytes
Uploading file /nv/item_files/modem/mmode/sd/sdssscr_timers 204 bytes
Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes
Uploading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes
Uploading file /nv/item_files/modem/uim/gstk/rat_priority_config 26 bytes
Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes
Uploading file /nv/item_files/modem/uim/uimdrv/uim_sys_info 256 bytes
Uploading file /nv/item_files/rfnv/00022975 491 bytes
Uploading file /nv/item_files/rfnv/00022976 505 bytes
Uploading file /nv/item_files/rfnv/00022978 502 bytes
Uploading file /nv/item_files/rfnv/00022979 449 bytes
Uploading file /nv/item_files/rfnv/00022982 529 bytes
Uploading file /nv/item_files/rfnv/00024964 193 bytes
Uploading file /nv/item_files/rfnv/00024965 193 bytes
Uploading file /nv/item_files/rfnv/00024966 193 bytes
Uploading file /nv/item_files/rfnv/00024967 193 bytes
Uploading file /nv/item_files/rfnv/00024972 2.97 Kb
Uploading file /nv/item_files/rfnv/00024973 2.97 Kb
Uploading file /nv/item_files/rfnv/00024974 2.49 Kb
Uploading file /nv/item_files/rfnv/00024975 2.49 Kb
Uploading file /nv/item_files/rfnv/00025004 192 bytes
Uploading file /nv/item_files/rfnv/00025005 192 bytes
Uploading file /nv/item_files/rfnv/00025006 192 bytes
Uploading file /nv/item_files/rfnv/00025007 192 bytes
Uploading file /nv/item_files/rfnv/00025044 160 bytes
Uploading file /nv/item_files/rfnv/00025045 160 bytes
Uploading file /nv/item_files/rfnv/00025046 160 bytes
Uploading file /nv/item_files/rfnv/00025047 160 bytes
Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes
Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes
Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything).
Unlock: Finish
Phone successfully unlocked
Old 06-13-2016, 14:20   #124 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
LG LS995 Unlock
Unlocking phone Installing apn launcher
 Apn launcher installed. You can edit apns with this program
 Mode: Normal
 Mode: Emergency
 Checking...
 Initializing connection
 making apn list
 Unlocking...
 Unlocking done
 Dumping security zone
 Unlocking carrier
 Unlocking carrier done
 Resetting to normal mode
 Getting Extra Info...
 Getting Proto Version...
 Getting...
 Getting Proto Version...OK:5
 Getting Extra Info: OK
Old 06-14-2016, 09:50   #125 (permalink)
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
Successfuly unlocked lg h631 with lgtool thanks lgtool
Connecting with H631TN
Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled".
Please select MTP in USB Connection Dialog on phone.
Connected
Getting phone info
Model: H631TN
SDRAM Size: 1 GB
NAND Flash Size: 8 GB
CPU: MSM8916
Firmware Released: Sep 1 2015 15:50:18
Firmware Compiled: Apr 22 2015 05:00:00
Firmware Version: EAAAANVZd/MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1
IMEI: 358387-06-428781-5
Info received
Unlocking phone
Unlock: Start
Backuping NVM to file: Backups\H631TN_nvm_358387064287815_2016-6-14_13-35-47.sbf
Dump NVM: Start
Dumping NVM...
Dumping NVM: OK
Dump NVM: Finish
Backuping EFS to file: Backups\H631TN_efs_358387064287815_2016-6-14_13-40-46.sbf
Downloading file /nv/item_files/conf/cgps_me.conf 1.74 Kb
Downloading file /nv/item_files/conf/cgps_pe.conf 272 bytes
Downloading file /nv/item_files/conf/cgps_sdp.conf 53 bytes
Downloading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb
Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes
Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb
Downloading file /nv/item_files/conf/data_config_info.conf 5.06 Kb
Downloading file /nv/item_files/conf/geran.conf 1.35 Kb
Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes
Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes
Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes
Downloading file /nv/item_files/conf/ims.conf 3.08 Kb
Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes
Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes
Downloading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb
Downloading file /nv/item_files/conf/mc.conf 888 bytes
Downloading file /nv/item_files/conf/mcfg.conf 216 bytes
Downloading file /nv/item_files/conf/mcpm.conf 154 bytes
Downloading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes
Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb
Downloading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes
Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes
Downloading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb
Downloading file /nv/item_files/conf/mmode.conf 2.39 Kb
Downloading file /nv/item_files/conf/nas_mm.conf 1.42 Kb
Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes
Downloading file /nv/item_files/conf/onex_srch.conf 266 bytes
Downloading file /nv/item_files/conf/ps_config_info.conf 491 bytes
Downloading file /nv/item_files/conf/qmi_data.conf 88 bytes
Downloading file /nv/item_files/conf/reg.conf 1.38 Kb
Downloading file /nv/item_files/conf/uimdrv.conf 513 bytes
Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes
Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb
Downloading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes
Downloading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes
Downloading file /nv/item_files/conf/wl1_cme.conf 210 bytes
Downloading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes
Downloading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes
Downloading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes
Downloading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes
Downloading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes
Downloading file /nv/item_files/conf/wms.conf 558 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes
Downloading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes
Downloading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes
Downloading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes
Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes
Downloading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes
Downloading file /nv/item_files/rfnv/00023759 150 bytes
Downloading file /nv/item_files/rfnv/00023761 150 bytes
Downloading file /nv/item_files/rfnv/00024227 768 bytes
Downloading file /nv/item_files/rfnv/00024229 792 bytes
Downloading file /nv/item_files/rfnv/00024237 752 bytes
Downloading file /nv/item_files/rfnv/00024252 753 bytes
Downloading file /nv/item_files/rfnv/00024253 803 bytes
Downloading file /nv/item_files/rfnv/00024254 779 bytes
Downloading file /nv/item_files/rfnv/00024255 759 bytes
Downloading file /nv/item_files/rfnv/00024972 2.49 Kb
Downloading file /nv/item_files/rfnv/00024973 2.49 Kb
Downloading file /nv/item_files/rfnv/00025532 225 bytes
Downloading file /nv/item_files/rfnv/00025533 225 bytes
Downloading file /nv/item_files/rfnv/00025535 225 bytes
Downloading file /nv/item_files/rfnv/00025536 225 bytes
Downloading file /nv/item_files/rfnv/00025543 225 bytes
Downloading file /nv/item_files/rfnv/00026696 193 bytes
Downloading file /nv/item_files/rfnv/00026699 193 bytes
Downloading file /nv/item_files/rfnv/00027473 131 bytes
Downloading file /nv/item_files/rfnv/00027474 131 bytes
Downloading file /nv/item_files/rfnv/00027475 131 bytes
Downloading file /nv/item_files/rfnv/00027476 131 bytes
Downloading file /nv/item_files/rfnv/00027477 131 bytes
Downloading file /nv/item_files/rfnv/00027478 131 bytes
Downloading file /nv/item_files/rfnv/00027479 131 bytes
Downloading file /nv/item_files/rfnv/00027481 131 bytes
Downloading file /nv/item_files/rfnv/00027482 131 bytes
Downloading file /nv/reg_files/conf/policyman.conf 172 bytes
Downloading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes
Mode: Normal
Mode: Emergency
Checking...
Imei: 358387064287815
Pid: CT01S150722002329
ModelName: LG-H631
BatteryLevel: 20%
DeviceSwVersion: H63110j
DeviceFactoryVersion: LGH631AT-01-V10j-310-260-SEP-01-2015-ARB01+0
ChipsetPlatform: msm8916
LafSwVersion: 1.1
DeviceFactoryOutVersion: LGH631AT-00-V10j-TMO-US-SEP-01-2015-ARB01+0
Reading modemst1 [15400, c00]
Reading modemst2 [16000, c00]
Backuping Security to file: Backups\H631TN_security_358387064287815_2016-6-14_13-42-30.sbf
Writing modemst1 [15400, c00]
Writing modemst2 [16000, c00]
Writing NVM-Backup from file: Backups\H631TN_nvm_358387064287815_2016-6-14_13-35-47.sbf
Flash NVM: Start
Flashing NVM...
Flashing NVM: OK
Flash NVM: Finish
Writing EFS-Backup from file: Backups\H631TN_efs_358387064287815_2016-6-14_13-40-46.sbf
Uploading file /nv/item_files/conf/cgps_me.conf 1.74 Kb
Uploading file /nv/item_files/conf/cgps_pe.conf 272 bytes
Uploading file /nv/item_files/conf/cgps_sdp.conf 53 bytes
Uploading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb
Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes
Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb
Uploading file /nv/item_files/conf/data_config_info.conf 5.06 Kb
Uploading file /nv/item_files/conf/geran.conf 1.35 Kb
Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes
Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes
Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes
Uploading file /nv/item_files/conf/ims.conf 3.08 Kb
Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes
Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes
Uploading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb
Uploading file /nv/item_files/conf/mc.conf 888 bytes
Uploading file /nv/item_files/conf/mcfg.conf 216 bytes
Uploading file /nv/item_files/conf/mcpm.conf 154 bytes
Uploading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes
Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb
Uploading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes
Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes
Uploading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb
Uploading file /nv/item_files/conf/mmode.conf 2.39 Kb
Uploading file /nv/item_files/conf/nas_mm.conf 1.42 Kb
Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes
Uploading file /nv/item_files/conf/onex_srch.conf 266 bytes
Uploading file /nv/item_files/conf/ps_config_info.conf 491 bytes
Uploading file /nv/item_files/conf/qmi_data.conf 88 bytes
Uploading file /nv/item_files/conf/reg.conf 1.38 Kb
Uploading file /nv/item_files/conf/uimdrv.conf 513 bytes
Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes
Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb
Uploading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes
Uploading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes
Uploading file /nv/item_files/conf/wl1_cme.conf 210 bytes
Uploading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes
Uploading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes
Uploading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes
Uploading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes
Uploading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes
Uploading file /nv/item_files/conf/wms.conf 558 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes
Uploading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes
Uploading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes
Uploading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes
Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes
Uploading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes
Uploading file /nv/item_files/rfnv/00023759 150 bytes
Uploading file /nv/item_files/rfnv/00023761 150 bytes
Uploading file /nv/item_files/rfnv/00024227 768 bytes
Uploading file /nv/item_files/rfnv/00024229 792 bytes
Uploading file /nv/item_files/rfnv/00024237 752 bytes
Uploading file /nv/item_files/rfnv/00024252 753 bytes
Uploading file /nv/item_files/rfnv/00024253 803 bytes
Uploading file /nv/item_files/rfnv/00024254 779 bytes
Uploading file /nv/item_files/rfnv/00024255 759 bytes
Uploading file /nv/item_files/rfnv/00024972 2.49 Kb
Uploading file /nv/item_files/rfnv/00024973 2.49 Kb
Uploading file /nv/item_files/rfnv/00025532 225 bytes
Uploading file /nv/item_files/rfnv/00025533 225 bytes
Uploading file /nv/item_files/rfnv/00025535 225 bytes
Uploading file /nv/item_files/rfnv/00025536 225 bytes
Uploading file /nv/item_files/rfnv/00025543 225 bytes
Uploading file /nv/item_files/rfnv/00026696 193 bytes
Uploading file /nv/item_files/rfnv/00026699 193 bytes
Uploading file /nv/item_files/rfnv/00027473 131 bytes
Uploading file /nv/item_files/rfnv/00027474 131 bytes
Uploading file /nv/item_files/rfnv/00027475 131 bytes
Uploading file /nv/item_files/rfnv/00027476 131 bytes
Uploading file /nv/item_files/rfnv/00027477 131 bytes
Uploading file /nv/item_files/rfnv/00027478 131 bytes
Uploading file /nv/item_files/rfnv/00027479 131 bytes
Uploading file /nv/item_files/rfnv/00027481 131 bytes
Uploading file /nv/item_files/rfnv/00027482 131 bytes
Uploading file /nv/reg_files/conf/policyman.conf 172 bytes
Uploading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes
Unlock: Finish
Old 06-21-2016, 06:41   #126 (permalink)
Member: 1930279
Sonork: 100.1663273
Thanks Meter: 113
Thumbs up Lg e425f flash done.
Old 06-21-2016, 06:45   #127 (permalink)
Member: 1930279
Sonork: 100.1663273
Thanks Meter: 113
Thumbs up Lg d686 flash done.
Old 07-20-2016, 19:58   #128 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
LG LS990 Unlock
Connecting with LS990 The diag com-port is not found
 If diag mode is already enabled check that the "USB PC Connection" is set to charge phone.
 Waiting for device...
 Device Found: LGLS9908a956aa6
 Checking root ...
 If you see a "SU grant request" window on screen click "Grant" button
 In window that will appear. Set DiagMode to "Enable"
 Also set connection mode to "Charge only" in USB PC Connection
 Getting...
 Getting...
 Firmware Version: LS990ZV8
 Connected
 Getting...
 Firmware Released: 01:00:00
 Firmware Compiled: 18:05:01
 SPC: 891789
 MEID: 35259606231384
 Mobile ESN: 80E0FC1D
 Phone Number(MDN): 0000008932
 min1: 0008932
 min2: 000
 SID/NID: 4139/65535
 SSD_A: BA76E0F67432FB48
 SSD_B: E3513FE06151B2CF
 AKEY: 12962056506502036995
 OTKSL: 904221
 User Lock Code: 8932
 MCC: 310
 MNC: 0
 Info received
 Unlocking phone
 Mode: Normal
 Mode: Emergency
 Checking...
 making apn list
 Unlocking carrier
 Getting...
Old 07-23-2016, 17:37   #129 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
LG LS990 Unlock
 Device Found: LGLS990fd09490
 Checking root ...
 Getting...
 Getting...
 Connected
 Getting...
 SPC: 778808
 MEID: 35259606042928
 Mobile ESN: 80749633
 SSD_A: 0000000000000000
 SSD_B: 0000000000000000
 AKEY: 00971809132018435278
 OTKSL: 781672
 User Lock Code: 2856
 Info received
 Unlocking phone
 Mode: Normal
 Mode: Emergency
 Checking...
 Checking...
 making apn list
 Unlocking carrier
 Getting...
Old 10-10-2016, 12:42   #130 (permalink)
Member: 1826863
Thanks Meter: 32
lg g4 h812 unlock done
Universal Tool version: 2.59
OS Version: Windows NT 6.2
Administrative privileges: yes
Locale: UnitedKingdom / English
CPU frequency: 2992 MHz
Total memory: 1977 MB
Free memory: 770 MB
Free space on system disk C:\: 26.00 GB
Free space on disk D:\: 154.00 GB
Connecting with H812
For Android 5.X: Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled".
For Android 6.X: Please type *#546368#*812# and select "SVC menu" -> "Port Check Test" -> "Enabled".
Connected
Getting phone info
Model: H812
SDRAM Size: 3 GB
NAND Flash Size: 32 GB
CPU: MSM8992
Firmware Released: Dec 4 2015 17:22:16
Firmware Compiled: Apr 23 2015 18:00:00
Firmware Version: LGH812ATd/MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1
IMEI: 359803-06-513911-9
Info received
Getting phone info
Model: H812
SDRAM Size: 3 GB
CPU: MSM8992
Info received
Unlocking phone
Unlock: Start
Backuping NVM to file: Backups\H812_nvm_359803065139119_2016-10-10_15-57-58.sbf
Dump NVM: Start
Dumping NVM...
Dumping NVM: OK
Dump NVM: Finish
Backuping EFS to file: Backups\H812_efs_359803065139119_2016-10-10_16-4-32.sbf
Downloading file /nv/item_files/conf/cgps_common.conf 56 bytes
Downloading file /nv/item_files/conf/cgps_me.conf 3.53 Kb
Downloading file /nv/item_files/conf/cgps_pe.conf 478 bytes
Downloading file /nv/item_files/conf/cgps_sm.conf 1.57 Kb
Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 1.00 Kb
Downloading file /nv/item_files/conf/data_config_info.conf 5.40 Kb
Downloading file /nv/item_files/conf/data_profile.conf 154 bytes
Downloading file /nv/item_files/conf/dpm_config_info.conf 62 bytes
Downloading file /nv/item_files/conf/geran.conf 1.85 Kb
Downloading file /nv/item_files/conf/hdrmultirat_config_info.conf 48 bytes
Downloading file /nv/item_files/conf/ipa.conf 424 bytes
Downloading file /nv/item_files/conf/lte_ml1_ant_switch_dr_dsds.conf 53 bytes
Downloading file /nv/item_files/conf/lte_ml1_ca_dynamic_cfg.conf 49 bytes
Downloading file /nv/item_files/conf/lte_ml1_debug_cfg.conf 47 bytes
Downloading file /nv/item_files/conf/lte_ml1_tput_test_cfg.conf 47 bytes
Downloading file /nv/item_files/conf/mc.conf 988 bytes
Downloading file /nv/item_files/conf/mcpm.conf 246 bytes
Downloading file /nv/item_files/conf/mcs_as_div.conf 43 bytes
Downloading file /nv/item_files/conf/mcs_cfcm.conf 288 bytes
Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.09 Kb
Downloading file /nv/item_files/conf/mmgsdi.conf 3.92 Kb
Downloading file /nv/item_files/conf/mmode.conf 2.74 Kb
Downloading file /nv/item_files/conf/nas_mm.conf 1.59 Kb
Downloading file /nv/item_files/conf/onex_srch.conf 303 bytes
Downloading file /nv/item_files/conf/pbm.conf 278 bytes
Downloading file /nv/item_files/conf/ps_config_info.conf 664 bytes
Downloading file /nv/item_files/conf/qmi_data.conf 135 bytes
Downloading file /nv/item_files/conf/reg.conf 1.68 Kb
Downloading file /nv/item_files/conf/tdscdma_l1.conf 1.96 Kb
Downloading file /nv/item_files/conf/tdscdma_rrc.conf 2.18 Kb
Downloading file /nv/item_files/conf/uimdrv.conf 407 bytes
Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 2.12 Kb
Downloading file /nv/item_files/mcs/cfcm/cfcm_config_cpu_dne_efs 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/coex_simulation_input 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/disable_sw_mitigation 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gps_victim_1x_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm2_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm3_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm1_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm3_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm1_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm2_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_tdscdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_wcdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/hdr_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_hdr_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_lte_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/lte_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/tdscdma_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/wcdma_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/force_filter_path 0 bytes
Downloading file /nv/item_files/rfnv/00022982 484 bytes
Downloading file /nv/item_files/rfnv/00023760 150 bytes
Downloading file /nv/item_files/rfnv/00023761 149 bytes
Downloading file /nv/item_files/rfnv/00023762 149 bytes
Downloading file /nv/item_files/rfnv/00024227 661 bytes
Downloading file /nv/item_files/rfnv/00024229 722 bytes
Downloading file /nv/item_files/rfnv/00024230 650 bytes
Downloading file /nv/item_files/rfnv/00024232 736 bytes
Downloading file /nv/item_files/rfnv/00024237 653 bytes
Downloading file /nv/item_files/rfnv/00024238 758 bytes
Downloading file /nv/item_files/rfnv/00024240 711 bytes
Downloading file /nv/item_files/rfnv/00024252 648 bytes
Downloading file /nv/item_files/rfnv/00024253 643 bytes
Downloading file /nv/item_files/rfnv/00024254 628 bytes
Downloading file /nv/item_files/rfnv/00024255 645 bytes
Downloading file /nv/item_files/rfnv/00026650 1.54 Kb
Downloading file /nv/item_files/rfnv/00026652 1.54 Kb
Downloading file /nv/item_files/rfnv/00026654 1.54 Kb
Downloading file /nv/item_files/rfnv/00026656 1.54 Kb
Downloading file /nv/item_files/rfnv/00026658 805 bytes
Downloading file /nv/item_files/rfnv/00026660 1.54 Kb
Downloading file /nv/item_files/rfnv/00026664 805 bytes
Downloading file /nv/item_files/rfnv/00026666 805 bytes
Downloading file /nv/item_files/rfnv/00026674 1.54 Kb
Downloading file /nv/item_files/rfnv/00026698 193 bytes
Downloading file /nv/item_files/rfnv/00026865 805 bytes
Downloading file /nv/item_files/rfnv/00026867 805 bytes
Downloading file /nv/item_files/rfnv/00026871 805 bytes
Downloading file /nv/item_files/rfnv/00026873 805 bytes
Downloading file /nv/item_files/rfnv/00027157 131 bytes
Downloading file /nv/item_files/rfnv/00027158 131 bytes
Downloading file /nv/item_files/rfnv/00027159 131 bytes
Downloading file /nv/item_files/rfnv/00027183 805 bytes
Downloading file /nv/item_files/rfnv/00027224 150 bytes
Downloading file /nv/item_files/rfnv/00027225 150 bytes
Downloading file /nv/item_files/rfnv/00027345 129 bytes
Downloading file /nv/item_files/rfnv/00027346 129 bytes
Downloading file /nv/item_files/rfnv/00027348 129 bytes
Downloading file /nv/item_files/rfnv/00027349 129 bytes
Downloading file /nv/item_files/rfnv/00027391 129 bytes
Downloading file /nv/item_files/rfnv/00027392 129 bytes
Downloading file /nv/item_files/rfnv/00027393 129 bytes
Downloading file /nv/item_files/rfnv/00027394 129 bytes
Downloading file /nv/item_files/rfnv/00027395 129 bytes
Downloading file /nv/item_files/rfnv/00027397 129 bytes
Downloading file /nv/item_files/rfnv/00027402 129 bytes
Downloading file /nv/item_files/rfnv/00027403 129 bytes
Downloading file /nv/item_files/rfnv/00027405 129 bytes
Downloading file /nv/item_files/rfnv/00027411 129 bytes
Downloading file /nv/item_files/rfnv/00027480 131 bytes
Downloading file /nv/item_files/rfnv/00028049 403 bytes
Downloading file /nv/item_files/rfnv/00028050 425 bytes
Downloading file /nv/item_files/rfnv/00028051 393 bytes
Downloading file /nv/item_files/rfnv/00028052 439 bytes
Downloading file /nv/item_files/rfnv/00028053 416 bytes
Downloading file /nv/item_files/rfnv/00028055 354 bytes
Downloading file /nv/item_files/rfnv/00028060 395 bytes
Downloading file /nv/item_files/rfnv/00028061 355 bytes
Downloading file /nv/item_files/rfnv/00028065 352 bytes
Downloading file /nv/item_files/rfnv/00028073 433 bytes
Downloading file /nv/item_files/rfnv/00028148 400 bytes
Downloading file /nv/item_files/rfnv/00028156 383 bytes
Downloading file /nv/item_files/rfnv/00028158 410 bytes
Downloading file /nv/item_files/rfnv/00028160 420 bytes
Downloading file /nv/item_files/rfnv/00028170 344 bytes
Downloading file /nv/item_files/rfnv/00028171 359 bytes
Downloading file /nv/item_files/rfnv/00028172 354 bytes
Downloading file /nv/item_files/rfnv/00028173 350 bytes
Downloading file /nv/item_files/rfnv/00028174 140 bytes
Downloading file /nv/item_files/rfnv/00028176 351 bytes
Downloading file /nv/item_files/rfnv/00028181 155 bytes
Downloading file /nv/item_files/rfnv/00028182 130 bytes
Downloading file /nv/item_files/rfnv/00028184 146 bytes
Downloading file /nv/item_files/rfnv/00028190 402 bytes
Downloading file /nv/item_files/rfnv/00028216 192 bytes
Downloading file /nv/item_files/rfnv/00028217 190 bytes
Downloading file /nv/item_files/rfnv/00028219 190 bytes
Downloading file /nv/item_files/rfnv/00028220 157 bytes
Downloading file /nv/item_files/rfnv/00028494 214 bytes
Downloading file /nv/item_files/rfnv/00028496 209 bytes
Downloading file /nv/item_files/rfnv/00028497 111 bytes
Downloading file /nv/item_files/rfnv/00028499 212 bytes
Downloading file /nv/item_files/rfnv/00028504 111 bytes
Downloading file /nv/item_files/rfnv/00028505 111 bytes
Downloading file /nv/item_files/rfnv/00028507 111 bytes
Downloading file /nv/reg_files/conf/policyman.conf 197 bytes
Backuping SNV [1] to file: Backups\H812_snv1_359803065139119_2016-10-10_16-5-21.sbf
Dump SNV [1]: Start
Switching to SNV mode...
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Switching to SNV mode: OK
Dumping SNV [1]...
Dumping SNV [1]: OK
Dump SNV [1]: Finish
Backuping SNV [2] to file: Backups\H812_snv2_359803065139119_2016-10-10_16-8-6.sbf
Dump SNV [2]: Start
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Dumping SNV [2]...
Dumping SNV [2]: OK
Dump SNV [2]: Finish
Mode: Normal
Mode: Emergency
Checking...
Getting...
Imei: 359803065139119
Pid: PT01S151221003261
ModelName: LG-H812
BatteryLevel: 84%
DeviceSwVersion: H81210n
DeviceFactoryVersion: LGH812AT-01-V10n-302-720-DEC-04-2015+0
ChipsetPlatform: msm8992
LafSwVersion: 1.1
DeviceFactoryOutVersion: LGH812AT-00-V10n-RGS-CA-DEC-04-2015+0
Reading modemst1 [58000, c00]
Reading modemst2 [58c00, c00]
Backuping Security to file: Backups\H812_security_359803065139119_2016-10-10_16-11-34.sbf
Writing modemst1 [58000, c00]
Writing modemst2 [58c00, c00]
Writing NVM-Backup from file: Backups\H812_nvm_359803065139119_2016-10-10_15-57-58.sbf
Flash NVM: Start
Trying reconnect...
Flashing NVM...
Flashing NVM: OK
Flash NVM: Finish
Writing EFS-Backup from file: Backups\H812_efs_359803065139119_2016-10-10_16-4-32.sbf
Uploading file /nv/item_files/conf/cgps_common.conf 56 bytes
Uploading file /nv/item_files/conf/cgps_me.conf 3.53 Kb
Uploading file /nv/item_files/conf/cgps_pe.conf 478 bytes
Uploading file /nv/item_files/conf/cgps_sm.conf 1.57 Kb
Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 1.00 Kb
Uploading file /nv/item_files/conf/data_config_info.conf 5.40 Kb
Uploading file /nv/item_files/conf/data_profile.conf 154 bytes
Uploading file /nv/item_files/conf/dpm_config_info.conf 62 bytes
Uploading file /nv/item_files/conf/geran.conf 1.85 Kb
Uploading file /nv/item_files/conf/hdrmultirat_config_info.conf 48 bytes
Uploading file /nv/item_files/conf/ipa.conf 424 bytes
Uploading file /nv/item_files/conf/lte_ml1_ant_switch_dr_dsds.conf 53 bytes
Uploading file /nv/item_files/conf/lte_ml1_ca_dynamic_cfg.conf 49 bytes
Uploading file /nv/item_files/conf/lte_ml1_debug_cfg.conf 47 bytes
Uploading file /nv/item_files/conf/lte_ml1_tput_test_cfg.conf 47 bytes
Uploading file /nv/item_files/conf/mc.conf 988 bytes
Uploading file /nv/item_files/conf/mcpm.conf 246 bytes
Uploading file /nv/item_files/conf/mcs_as_div.conf 43 bytes
Uploading file /nv/item_files/conf/mcs_cfcm.conf 288 bytes
Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.09 Kb
Uploading file /nv/item_files/conf/mmgsdi.conf 3.92 Kb
Uploading file /nv/item_files/conf/mmode.conf 2.74 Kb
Uploading file /nv/item_files/conf/nas_mm.conf 1.59 Kb
Uploading file /nv/item_files/conf/onex_srch.conf 303 bytes
Uploading file /nv/item_files/conf/pbm.conf 278 bytes
Uploading file /nv/item_files/conf/ps_config_info.conf 664 bytes
Uploading file /nv/item_files/conf/qmi_data.conf 135 bytes
Uploading file /nv/item_files/conf/reg.conf 1.68 Kb
Uploading file /nv/item_files/conf/tdscdma_l1.conf 1.96 Kb
Uploading file /nv/item_files/conf/tdscdma_rrc.conf 2.18 Kb
Uploading file /nv/item_files/conf/uimdrv.conf 407 bytes
Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 2.12 Kb
Uploading file /nv/item_files/mcs/cfcm/cfcm_config_cpu_dne_efs 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/coex_simulation_input 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/disable_sw_mitigation 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gps_victim_1x_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm2_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm3_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm1_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm3_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm1_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm2_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_tdscdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_wcdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/hdr_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_hdr_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_lte_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/lte_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/tdscdma_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/wcdma_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/force_filter_path 0 bytes
Uploading file /nv/item_files/rfnv/00022982 484 bytes
Uploading file /nv/item_files/rfnv/00023760 150 bytes
Uploading file /nv/item_files/rfnv/00023761 149 bytes
Uploading file /nv/item_files/rfnv/00023762 149 bytes
Uploading file /nv/item_files/rfnv/00024227 661 bytes
Uploading file /nv/item_files/rfnv/00024229 722 bytes
Uploading file /nv/item_files/rfnv/00024230 650 bytes
Uploading file /nv/item_files/rfnv/00024232 736 bytes
Uploading file /nv/item_files/rfnv/00024237 653 bytes
Uploading file /nv/item_files/rfnv/00024238 758 bytes
Uploading file /nv/item_files/rfnv/00024240 711 bytes
Uploading file /nv/item_files/rfnv/00024252 648 bytes
Uploading file /nv/item_files/rfnv/00024253 643 bytes
Uploading file /nv/item_files/rfnv/00024254 628 bytes
Uploading file /nv/item_files/rfnv/00024255 645 bytes
Uploading file /nv/item_files/rfnv/00026650 1.54 Kb
Uploading file /nv/item_files/rfnv/00026652 1.54 Kb
Uploading file /nv/item_files/rfnv/00026654 1.54 Kb
Uploading file /nv/item_files/rfnv/00026656 1.54 Kb
Uploading file /nv/item_files/rfnv/00026658 805 bytes
Uploading file /nv/item_files/rfnv/00026660 1.54 Kb
Uploading file /nv/item_files/rfnv/00026664 805 bytes
Uploading file /nv/item_files/rfnv/00026666 805 bytes
Uploading file /nv/item_files/rfnv/00026674 1.54 Kb
Uploading file /nv/item_files/rfnv/00026698 193 bytes
Uploading file /nv/item_files/rfnv/00026865 805 bytes
Uploading file /nv/item_files/rfnv/00026867 805 bytes
Uploading file /nv/item_files/rfnv/00026871 805 bytes
Uploading file /nv/item_files/rfnv/00026873 805 bytes
Uploading file /nv/item_files/rfnv/00027157 131 bytes
Uploading file /nv/item_files/rfnv/00027158 131 bytes
Uploading file /nv/item_files/rfnv/00027159 131 bytes
Uploading file /nv/item_files/rfnv/00027183 805 bytes
Uploading file /nv/item_files/rfnv/00027224 150 bytes
Uploading file /nv/item_files/rfnv/00027225 150 bytes
Uploading file /nv/item_files/rfnv/00027345 129 bytes
Uploading file /nv/item_files/rfnv/00027346 129 bytes
Uploading file /nv/item_files/rfnv/00027348 129 bytes
Uploading file /nv/item_files/rfnv/00027349 129 bytes
Uploading file /nv/item_files/rfnv/00027391 129 bytes
Uploading file /nv/item_files/rfnv/00027392 129 bytes
Uploading file /nv/item_files/rfnv/00027393 129 bytes
Uploading file /nv/item_files/rfnv/00027394 129 bytes
Uploading file /nv/item_files/rfnv/00027395 129 bytes
Uploading file /nv/item_files/rfnv/00027397 129 bytes
Uploading file /nv/item_files/rfnv/00027402 129 bytes
Uploading file /nv/item_files/rfnv/00027403 129 bytes
Uploading file /nv/item_files/rfnv/00027405 129 bytes
Uploading file /nv/item_files/rfnv/00027411 129 bytes
Uploading file /nv/item_files/rfnv/00027480 131 bytes
Uploading file /nv/item_files/rfnv/00028049 403 bytes
Uploading file /nv/item_files/rfnv/00028050 425 bytes
Uploading file /nv/item_files/rfnv/00028051 393 bytes
Uploading file /nv/item_files/rfnv/00028052 439 bytes
Uploading file /nv/item_files/rfnv/00028053 416 bytes
Uploading file /nv/item_files/rfnv/00028055 354 bytes
Uploading file /nv/item_files/rfnv/00028060 395 bytes
Uploading file /nv/item_files/rfnv/00028061 355 bytes
Uploading file /nv/item_files/rfnv/00028065 352 bytes
Uploading file /nv/item_files/rfnv/00028073 433 bytes
Uploading file /nv/item_files/rfnv/00028148 400 bytes
Uploading file /nv/item_files/rfnv/00028156 383 bytes
Uploading file /nv/item_files/rfnv/00028158 410 bytes
Uploading file /nv/item_files/rfnv/00028160 420 bytes
Uploading file /nv/item_files/rfnv/00028170 344 bytes
Uploading file /nv/item_files/rfnv/00028171 359 bytes
Uploading file /nv/item_files/rfnv/00028172 354 bytes
Uploading file /nv/item_files/rfnv/00028173 350 bytes
Uploading file /nv/item_files/rfnv/00028174 140 bytes
Uploading file /nv/item_files/rfnv/00028176 351 bytes
Uploading file /nv/item_files/rfnv/00028181 155 bytes
Uploading file /nv/item_files/rfnv/00028182 130 bytes
Uploading file /nv/item_files/rfnv/00028184 146 bytes
Uploading file /nv/item_files/rfnv/00028190 402 bytes
Uploading file /nv/item_files/rfnv/00028216 192 bytes
Uploading file /nv/item_files/rfnv/00028217 190 bytes
Uploading file /nv/item_files/rfnv/00028219 190 bytes
Uploading file /nv/item_files/rfnv/00028220 157 bytes
Uploading file /nv/item_files/rfnv/00028494 214 bytes
Uploading file /nv/item_files/rfnv/00028496 209 bytes
Uploading file /nv/item_files/rfnv/00028497 111 bytes
Uploading file /nv/item_files/rfnv/00028499 212 bytes
Uploading file /nv/item_files/rfnv/00028504 111 bytes
Uploading file /nv/item_files/rfnv/00028505 111 bytes
Uploading file /nv/item_files/rfnv/00028507 111 bytes
Uploading file /nv/reg_files/conf/policyman.conf 197 bytes
Writing SNV-Backup [1] from file: Backups\H812_snv1_359803065139119_2016-10-10_16-5-21.sbf
Flash SNV [1]: Start
Getting phone info...
Getting phone info: OK
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Flashing SNV [1]...
Flashing SNV [1]: OK
Switching to normal mode...
Switching to normal mode: OK
Flash SNV [1]: Finish
Writing SNV-Backup [2] from file: Backups\H812_snv2_359803065139119_2016-10-10_16-8-6.sbf
Flash SNV [2]: Start
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Flashing SNV [2]...
Flashing SNV [2]: OK
Flash SNV [2]: Finish
Unlock: Finish
Disconnected
Old 12-17-2016, 10:51   #131 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 193
LG LU6200 Unlock Done by LG TOOL
Connecting with SU640
In order to connect with phone you should do the following:
1. Enable Android Debug Mode
2. Reconnect USB cable
Connected
Receiving phone info
Getting phone info
Model: SU640
Platform: LG Qualcomm
Software Platform: Android
SDRAM Size: 1 GB
NAND Flash Size: 4 GB
CPU: APQ8060 + MDM9200
Firmware Released: May 18 2012 16:47:11
Firmware Compiled: May 18 2012 16:47:11
Firmware Version: SCAQSVZQd/M9600B-SCAQSVZD-3.1.61007F
IMEI: 990000-72-672551-0
Connect mode: Normal
Info received
Unlocking phone
Unlock: Start
Preparing NVM...
Switching to NVM mode...
Switching to NVM mode: OK
Preparing NVM: OK
Patching NVM...
Patching NVM: OK
Flashing NVM...
Can't flash nvm page
Flashing NVM: OK
Unlock: Finish
Old 04-05-2017, 19:49   #132 (permalink)
Member: 732601
Thanks Meter: 9
I am unlocking free phones with my lgtool license, just put your IMEI and ask for codes! with confidence!
My card info: S/N is 00163944
PMs are welcomed
Old 02-17-2018, 19:15   #133 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 453
Cool Xperia-c c2305
XPERIA-C -C2305 FLASHING DONE PROBLEM HANG ON LOGO
RUNNING S1_BOOT VER "2.14.J.2.13"
ACTIVE_COMP_AID : 0001
HWCONF_AID : 0001
LOADER_AID : 0001
BOOT_AID : 0001
[ llcomm: 00080000,00080000 ]
DEVICE ID: B0DACA5047B9C28F
FLASH ID: "0090/014A0086"
LOADER VERSION: MT6589_12
PHONE IMEI : 3*******
writing "H:\hy\setool\xperia-c-c2305\16_0_B_2_16.APP_SW_Pelican_GENERIC_1275_5177_S1_SW_LIVE_BB35_PID1_0002_MMC.zip"
Processing package
Testing package integrity ...
PROCESSING: partition-image_S1-SW-LIVE-BB35-PID1-0002-MBR.sin
PROCESSING: cache-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
SKIP: lk-sign_S1-BOOT-LIVE-BB35-PID1-0001-MMC.sin
PROCESSING: recovery-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
PROCESSING: EBR1-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
PROCESSING: EBR2-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
PROCESSING: logo-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
PROCESSING: MBR-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
PROCESSING: boot-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
SKIP: S1SBL-sign_S1-BOOT-LIVE-BB35-PID1-0001-MMC.sin
PROCESSING: secro-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
SKIP: partition-image_S1-SW-LIVE-BB35-PID1-0002-MBR.sin
SKIP: preloader_arima89_we_s_jb2_S1-BOOT-LIVE-BB35-PID1-0001-MMC.sin
writing "H:\hy\setool\xperia-c-c2305\16_0_B_2_16.FSP_Pelican_WORLD_i_1277_6019_S1_SW_LIVE_BB35_PID1_0002_MMC.R2A.zip"
Processing package
PROCESSING: userdata-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
PROCESSING: system-sign_S1-SW-LIVE-BB35-PID1-0002-MMC.sin
Processing UPDATE files
SKIP: simlock.ta
Elapsed: 1186 seconds
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.61660 seconds with 10 queries
