06-14-2009, 14:35 | #7 (permalink) |
No Life Poster Join Date: Aug 2005 Location: EL-BALOUTE Age: 48
Member: 168513 Status: Offline Thanks Meter: 838 | MEY BE iT HAVE CRUISER PCB IN YOUR SETOOLBOX....OPEN IT AND VERIFY OR CONTACT RESELER... RUN CRUISER SOFT AND VERIFY IF YOU CAN WORK WHITH IT,??? BR.TonTonFlach |
06-15-2009, 22:49 | #8 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 38
Member: 38980 Status: Offline Sonork: 100.84054 Thanks Meter: 124 | just use mprog and write setool eeprom inside your rs232-usb cable. (electronic parts are inside the box). you cannot fuk up your smartcard so dont worry. |
06-17-2009, 19:20 | #9 (permalink) |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | Hi there, UC-10 composite device is just like the Usb to serial converter. It is an interface used to convert usb to serial. I have had many of the boxes like this. Try to install the smartcard drivers again. and replug a few times. br, GK |
06-17-2009, 20:43 | #10 (permalink) |
Freak Poster Join Date: Jun 2006 Location: ALGERIA
Member: 288754 Status: Offline Thanks Meter: 63 | even you can open your box you will find sim reader put out the sim and clean the reader then put in sim after that ré-install smartcard drivers and replug the box;try and give us result . |
05-29-2010, 17:20 | #14 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Uc-10 its generic driver for setool 3 box ftdi and dont have relation whit setool 2 software its a simple com port. If software not run, check setool smartcard whit another egate reader. |
my setools errore plz helpe me | kashig | SETool2 | 2 | 01-14-2010 08:52 |
SETool Comport Error. Need Help Unrgently | simtec | SETool2 | 3 | 01-19-2009 14:08 |
Setool 3 Need Help | dez com | SETool2 | 1 | 06-08-2008 05:35 |
pls setool i need help | godwin | Sony Ericsson | 3 | 01-11-2008 23:46 |
K600i dead after unlock with SETOOL, A NEED HELP!!!!!! | Nash_R | SETool2 | 7 | 11-15-2007 12:29 |
