10-19-2012, 14:09 | #1 (permalink) |
Banned Join Date: Feb 2010 Location: sonebhadra Ramgarh
Member: 1232828 Status: Offline Sonork: 100.1647663 Thanks Meter: 49 | Return to Data!! and how to Control this error? 1. Unsupported mobile CPU Like : [ 2. Driver not properly install so mobile could not find driver properly. 3. Computer CPU not compatible with the program 4. Unsupported Operating System Using with the Program 5. Mobile not connected with the software. Sometimes, you need continue Holding POWER BUTTON until Operation is finished. 5. Use lower Port if Possible (Below then 10) 6. Other unspecified Errors a . Like Mobile is MTK and you select SPD so mobile Boot File not find and mobile could not boot. b. Buggy windows (Operating System) is used We suggest you, find the corrupt CPU and try to connect with it. if the Cpu type is SPD, and you try to connect with MTK, of course there will be DATA Error!! Secondly, Check the CPU type that UCT supports or not. If not supports, there might be DATA ERROR!! Thirdly, Install Driver Properly, if driver not install properly, software could not find boot file, so there might be Data Error!! Fourthly, Be sure that the Windows has no bug. And do not use unsupported Operating System that software could not recognize to the Operating system and there might be Data Error!! Finally, Handle software properly. Check Sticky thread regularly. Search the post if you are not success to connect with the phone. And, if you not find the solution in the previous post, then post your problem as new thread with all the problem mentioned clearly with screen shots of UCT connecting windows and wait for reply. GOOD LUCK Last edited by janu_shivam; 10-19-2012 at 14:15. |
