02-09-2010, 11:50 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | problem with samsung [SOLVED] I´ve tried to unlock two pieces (s5600v and s8000); first of them says continouslly " [!] NANO-DBG.UART.Error* payload echo not received " So I´m sure that phone is in qualcomm mode and my box is installed successfully. The s8000 recived an "access address violation error" and stayed in download mode, after that doesn´t power on... so must I flash it? TIA... |
02-09-2010, 12:22 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | second error possible caused by instable windows, so try to use another clean windows about ur s8000 yes, flash it br <= The_Gorr => |
02-09-2010, 16:28 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hello, yes both Errors Above r for Communications issues Never Perform operation with USB connected to HUB always use direct To PC Also About Drivers All is written and soft tell what when to do ..so its preety Easy.. Glad your Prob solved.. Br, We the Polar Team |
02-10-2010, 09:23 | #5 (permalink) |
Member: 79485 Status: Offline Thanks Meter: 47 | SOLVED BOTH PROBLEMS: 1ST.- Most samsung s5600 are old protections so can be unlocked selecting any standard qualcomm device if process fails when new protections selected. Be carefull managing com port conections because a lot of times windows give high com port values, so that causes most of problems on comunication. Of course reinstall last drivers for qualcomm phones. 2ND.- Some s8000 versions not supported (yet?) if it hangs on download mode can be flashed without any problems with support flashes (very intuitive,secure and comfortable flash procedure using this box). Happy with my new toy. |
The Following User Says Thank You to petermov For This Useful Post: |
02-10-2010, 09:48 | #6 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hello thankx for Reply for the first i will say any software can easily finds the COM ports Available in range of 1-20 So yes it better always to select under this selection..drivers r first priority YES S8000 well new version i did not know..the ones not supported ETC |
How to solve this problems with Samsung? | BackSlash_cu | Z3X-Team Products | 5 | 12-23-2009 05:06 |
problem with samsung T819 ::: SOLVED ::: | julio05 | PolarBox 3 | 3 | 05-31-2009 20:59 |
Problem with attachement Solved :) | The_Gorr | Redbox | 3 | 06-01-2006 11:18 |
Problem with attachement Solved :) | The_Gorr | SwS_SaG_BoX | 0 | 05-30-2006 16:39 |
