Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-28-2011, 20:37 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Delhi & NCR (INDIA)
Member: 800668 Status: Offline Sonork: 100.1590720 Thanks Meter: 882 | [Guide] Samsung Galaxy Gio S5660 Hard Reset 1. Turn off the device. If its stuck then try to pullout the battery for a minute and then put it back in. 2. Press down the volume key and the power key. 3. Then release the power button. 4. Now a menu appear give you the options to Fastboot, Recovery, Clear Storage and Simlock. Select Clear Storage. use the volume down button to navigate the menu. 5. Then press and release the power button. 6. Finally wait for your device to reboot. once the Samsung Galaxy Gio Restarted it should now go back to the default factory setting. or Use this method to hard reset your Samsung Galaxy Gio S5560 phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/contacts/messages etc. to sim or make backup on your pc before full reset. Br. Shashank |
The Following 2 Users Say Thank You to shashankmobile For This Useful Post: |
07-15-2011, 14:13 | #2 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Samsung S5660Gio hard reset to remove phone code In my case power button and volume down did not work. I used menu (middle button) and power button then use volume down to select options and follow screen instructions |
The Following 3 Users Say Thank You to abakwa For This Useful Post: |
11-03-2011, 10:12 | #3 (permalink) |
Insane Poster Join Date: Nov 2006 Location: vizag
Member: 390893 Status: Offline Thanks Meter: 9 | Quote: use menu (middle button) and power button then use volume down to select |
The Following User Says Thank You to rameshbhaskar For This Useful Post: |
03-05-2012, 12:39 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Saudi Arabia Age: 45
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | Press manue key and power button its going in secret menue and then select wipe / factory set Thats IT Regards, Adnan Khaver |
09-11-2012, 09:20 | #8 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh
Member: 648277 Status: Offline Thanks Meter: 161 | Galaxy GioFrom Factory Reset Jump to: navigation, search Samsung Galaxy Gio Factory Reset 1.Turn off the device. If it is stuck then try to pull out the battery for a minute and then put it back in. 2.Press down the Volume key and the Power button. 3.Then release the Power button. 4.Now a menu appear give you the options to Fastbook, Recovery, Clear Storage, and Simlock. Select Clear Storage. Use the Volume Down button to navigate the menu. 5.Then press and release the Power button. 6.Finally wait for your device to reboot. Galaxy Gio - Factory Reset |
12-03-2013, 07:54 | #14 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Press Home Button + Power Key Press 10 Secend Hard Reset Samsung S5660 Working Fine Tested me ............... |
04-15-2014, 05:27 | #15 (permalink) |
Insane Poster Join Date: Apr 2013 Location: tamilnadu,madurai
Member: 1916112 Status: Offline Sonork: [email protected] Thanks Meter: 8 | In my case power button and volume down did not work. I used menu (middle button) and power button then use volume down to select options and follow screen instructions 100%working |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
3110 Need to Unlock & Reset | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-22-2001 08:35 |
how can you reset the life timer without using a data cable for a 5125 TDMA phone? | PiNoY_bOy204 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-23-2001 12:46 |
HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-26-2001 05:33 |
5190 patial flashes - why are they so hard to find? | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-14-2001 03:18 |
