Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-28-2011, 20:37   #1 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
[Guide] Samsung Galaxy Gio S5660 Hard Reset
1. Turn off the device. If its stuck then try to pullout the battery for a minute and then put it back in.
2. Press down the volume key and the power key.
3. Then release the power button.
4. Now a menu appear give you the options to Fastboot, Recovery, Clear Storage and Simlock. Select Clear Storage. use the volume down button to navigate the menu.
5. Then press and release the power button.
6. Finally wait for your device to reboot.
once the Samsung Galaxy Gio Restarted it should now go back to the default factory setting.
or
Use this method to hard reset your Samsung Galaxy Gio S5560 phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/contacts/messages etc. to sim or make backup on your pc before full reset.
Br.
Shashank
The Following 2 Users Say Thank You to shashankmobile For This Useful Post:
Old 07-15-2011, 14:13   #2 (permalink)
abakwa's Avatar
Member: 69269
Thanks Meter: 175
Samsung S5660Gio hard reset to remove phone code
In my case power button and volume down did not work. I used menu (middle button) and power button then use volume down to select options and follow screen instructions
The Following 3 Users Say Thank You to abakwa For This Useful Post:
Old 11-03-2011, 10:12   #3 (permalink)
Member: 390893
Thanks Meter: 9
or
Br.
Shashank
not working
use menu (middle button) and power button then use volume down to select
The Following User Says Thank You to rameshbhaskar For This Useful Post:
Old 11-03-2011, 10:14   #4 (permalink)
Member: 390893
Thanks Meter: 9
s5660 hard reset
GT-S5660 Hard Reset - YouTube
Old 11-03-2011, 10:21   #5 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 143
http://forum.gsmhosting.com/vbb/f662...4/#post7856975
The Following User Says Thank You to sanjayvikas For This Useful Post:
Old 03-05-2012, 12:39   #6 (permalink)
adnan_taeki's Avatar
Member: 417778
Sonork: 100.1603326
Thanks Meter: 116
Press manue key and power button
its going in secret menue and then select wipe / factory set
Thats IT
Regards,
Adnan Khaver
Old 07-04-2012, 20:22   #7 (permalink)
Member: 237131
Thanks Meter: 3
format s5660 ok
pres hom+powr format ok %100
Old 09-11-2012, 09:20   #8 (permalink)
ripon111's Avatar
Member: 648277
Thanks Meter: 161
Galaxy GioFrom Factory Reset
Jump to: navigation, search
Samsung Galaxy Gio Factory Reset 1.Turn off the device. If it is stuck then try to pull out the battery for a minute and then put it back in.
2.Press down the Volume key and the Power button.
3.Then release the Power button.
4.Now a menu appear give you the options to Fastbook, Recovery, Clear Storage, and Simlock. Select Clear Storage. Use the Volume Down button to navigate the menu.
5.Then press and release the Power button.
6.Finally wait for your device to reboot.
Galaxy Gio - Factory Reset
Old 01-12-2013, 09:00   #9 (permalink)
Member: 622484
Thanks Meter: 5
fake solution..............not work.....
The Following User Says Thank You to iqbalmobile For This Useful Post:
Old 01-12-2013, 12:04   #10 (permalink)
Member: 40984
Thanks Meter: 2
working solution:
Home+Power button
The Following User Says Thank You to my7010107 For This Useful Post:
Old 02-26-2013, 16:49   #11 (permalink)
Member: 355898
Thanks Meter: 2
hold Home + power = simple solution 100% working
The Following User Says Thank You to tonton manso For This Useful Post:
Old 09-23-2013, 12:41   #12 (permalink)
Member: 881294
Thanks Meter: 13
hold Home + power = simple solution 100% working[/QUOTE]
The Following User Says Thank You to rkhatri307 For This Useful Post:
Old 10-11-2013, 17:18   #13 (permalink)
Member: 1965879
Sonork: fun
home+power buttons 100%working
Old 12-03-2013, 07:54   #14 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 465
Press Home Button + Power Key Press 10 Secend Hard Reset Samsung S5660 Working Fine Tested me ...............
Old 04-15-2014, 05:27   #15 (permalink)
Member: 1916112
Thanks Meter: 8
In my case power button and volume down did not work. I used menu (middle button) and power button then use volume down to select options and follow screen instructions 100%working
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
3110 Need to Unlock & Reset ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-22-2001 08:35
how can you reset the life timer without using a data cable for a 5125 TDMA phone? PiNoY_bOy204 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-23-2001 12:46
HOW TO RESET SECURITY CODE IN NOKIA 6210 ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-26-2001 05:33
5190 patial flashes - why are they so hard to find? Bads Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 04-14-2001 03:18
Page generated in 0.29039 seconds with 9 queries
