J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010 |
03-09-2012, 19:57 | #81 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | for change user and pass, contact me per email. for 64bit support, i cant help you now... i have all systems installed with 32 bit win versions. i will see if i have one computer free to install 64 bit to make tests. |
03-20-2012, 19:41 | #83 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 396 | Blackberry 8520 prd 30001-156 (not found) needs to add this prd. after search i got mep is MEP-09292-004 |
The Following User Says Thank You to mojee For This Useful Post: |
03-20-2012, 20:28 | #85 (permalink) | |
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
if you read out one phone direct per cable, it will auto addjust new prd to database if it is not in it.. after every unlock per cable, it checks if prd is in prd database, if yes it will skip saving, if not, it will save it to prd database. database is just a normal ini file and can be found in jau directory, you can easy addjust your needed prdīs by just open ini file with notepad. | |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
03-22-2012, 00:01 | #87 (permalink) | |
Member: 629391 Status: Offline Thanks Meter: 396 | Quote:
I added this prd, really it was so easy thanks | |
Post here any problem about Nokia keypad - key, and let me give you the solution | stefani | Nokia Repair Guide and FAQ | 850 | 08-22-2013 12:05 |
Hello....Post here any problem about Nokia | dharmdev | Nokia Hardware & Hardware Repair | 3 | 08-17-2013 06:07 |
Post Here Any Problem About Advance Cdma.. | ch mobiles | Advance Cdma Products | 1 | 03-06-2010 15:26 |
bugs and things to do pls post here any problem on 1.28 | shoktong | MSS Box II | 1 | 12-08-2009 01:26 |
Post here any problem with Nsdongle v3.11.6 | the new | NSPRO | 95 | 04-27-2006 20:06 |
