07-11-2012, 12:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: INDIA-TAMILNADU-TUTICORIN Age: 43
Member: 1591177 Status: Offline Thanks Meter: 85 | 2730c help urgen atf helper Processing Image File : rm578__10.47.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1395 Entry Point: 0x457E Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm578__10.47.ppm_m_a CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 339 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm578__10.47.image_m_a_black CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 768 Entry Point: 0x00C8 Page Format : -1 MAX PAGE : 0x00004000 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C800110 ID DWORD 1 : 85348E56 ID DWORD 2 : D9132AF6 ID DWORD 3 : 7192B87F ID DWORD 4 : 2A15CF13 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F ADL_SERVER: PROCESSING rm578__10.47.mcusw ADL_SERVER: ROOT_KEY_HASH MATCH FOUND ADL_SERVER: PROCESSING rm578__10.47.mcusw ADL_SERVER: CMT CERTIFICATE BLOCK FOUND ADL_SERVER: CMT DATA BLOCKS FOUND ADL_SERVER: CONSOLIDATING CMT BLOCKS ADL_SERVER: PASUBTOC BLOCK FOUND BB5 ADL Loader Start Up... (Please Wait...) ERROR: ADL Loader was not accepted PAPUB Key HASH is EMPTY or BLANK. Try "Skip ADL Check" Option or use FBUS Flashing Booting/Flashing Failed... Please Try Again... How to solve this |
07-11-2012, 12:40 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kathirmobiles Use FBUS Flashing for this phone ... ERROR: ADL Loader was not accepted PAPUB Key HASH is EMPTY or BLANK. Try "Skip ADL Check" Option or use FBUS Flashing Booting/Flashing Failed... Please Try Again... |
07-11-2012, 13:06 | #4 (permalink) | |
Member: 1591177 Status: Offline Thanks Meter: 85 | Quote:
Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C800110 ID DWORD 1 : 85348E56 ID DWORD 2 : D9132AF6 ID DWORD 3 : 7192B87F ID DWORD 4 : 2A15CF13 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum F5 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 89008289010000008900 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 9E SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned START READING RPL DATA Reading : NPC (CMT) NPC : Empty ERROR: Cannot read NPC Certificate ! NPC Certificate might have been erased or it is just temporarily unavailable... Full Flash the phone with the Newest Firmware and verify that the IMEI is not corrupted. If the IMEI is 123456787654321 then you need an RPL Backup or paid RPL to fix this problem. Failed to complete RPL backup.. | |
07-11-2012, 13:10 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kathirmobiles Somebody FULL ERASED this phone ... for sure IMEI is dead and simlocks are gone... If you did not FULL ERASE this phone yourself, then somebody else did before it arrived to your shop. Only way to fix is BUY RPL,, unless you have good backup of both rpl and pm... B.R. |
07-11-2012, 13:22 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kathirmobiles You need to try one more thing... Uncheck "BACKUP RPL" Uncheck "BACKUP Simlocks" then flash your phone... Sometimes, RPL backup will fail if mcu parts are corrupted or erased... B.R. |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
