07-03-2012, 13:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: INDIA
Member: 466182 Status: Offline Sonork: 100.1604458 Thanks Meter: 88 | 3110c Blinking Problem Problem - Blinking Log.... Code: ATF Software Version v8.95 ATF Box FBUS Flash Started... Number of Image Files: 3 ================================================ Basic Phone Information ================================================ WARNING: Simlock Backup Failed If this is a Dead Phone, just click YES to Continue with the Flash Procedure... Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07400118 ID DWORD 1 : AB450052 ID DWORD 2 : 8E1EF203 ID DWORD 3 : C293E344 ID DWORD 4 : 61648279 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 90 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request Failed to complete RPL backup.. Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.30.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 945 Entry Point : 0x453C Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07400118 ID DWORD 1 : AB450052 ID DWORD 2 : 8E1EF203 ID DWORD 3 : C293E344 ID DWORD 4 : 61648279 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 90 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request Operations Failed.... Br |
07-03-2012, 14:01 | #2 (permalink) | |
Freak Poster Join Date: Mar 2012 Location: Big Ben Age: 30
Member: 1728389 Status: Offline Sonork: 100.1617627 Thanks Meter: 57 | Quote:
07-03-2012, 15:32 | #3 (permalink) |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | @ debsden bro flash ur set again with usb cable. and also check ur files Click on Check buttton... +MCU +PPM +CNT Clear CHECK <----- this button. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
