07-07-2012, 10:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india up.
Member: 599228 Status: Offline Thanks Meter: 112 | 5130c dade .............. - [SOLVED] ATF Box FBUS Flash Started... Number of Image Files: 3 Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16700217 ID DWORD 1 : 38F08A56 ID DWORD 2 : 40654835 ID DWORD 3 : 6C553E2B ID DWORD 4 : 5A5FC2DB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 5C SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 01 SubBlocks : 01 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected ============================================ Please Check Phone PCB for Problems... ============================================ ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ WARNING: Simlock Backup Failed If this is a Dead Phone, just click YES to Continue with the Flash Procedure... Changing MODE : FLASH Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16700217 ID DWORD 1 : 38F08A56 ID DWORD 2 : 40654835 ID DWORD 3 : 6C553E2B ID DWORD 4 : 5A5FC2DB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 5C SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 01 SubBlocks : 01 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected ============================================ Please Check Phone PCB for Problems... ============================================ Failed to complete RPL backup.. Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 1178 Entry Point : 0x5057 Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16700217 ID DWORD 1 : 38F08A56 ID DWORD 2 : 40654835 ID DWORD 3 : 6C553E2B ID DWORD 4 : 5A5FC2DB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 5C SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 01 SubBlocks : 01 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected ============================================ Please Check Phone PCB for Problems... ============================================ Operations Failed.... |
07-07-2012, 10:37 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, ATF Software already tells you where is the problem: Code: 1 Sub Block ID : 32 UNKNOWN Block Length : 06 BB ASIC Index : CMT 00 Device Type : HDD 02 Device Index : FF Data : FFFFFF Checksum : C8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: Flash Chip is NOT Detected============================================ Please Check Phone PCB for Problems... |
Help solve an argument !! | zeaster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-10-2001 13:11 |
how do you solve no signal - 5110? | philipal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-29-2001 03:27 |
SOLVED THE FREEZE PROBLEM IN 8850!!!!! Please post below your observations.. | jsp_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-14-2001 19:52 |
3210 atmel solved | bone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 03-18-2001 12:11 |
PROBLEM SOLVED (Flasher error tx=0 tx=1...) | lanzar | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-30-2000 15:47 |
