Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-19-2015, 02:52   #16 (permalink)
dharyadi's Avatar
Member: 369678
Thanks Meter: 192
I need pinout for samsung s6810 please
Old 02-20-2015, 11:49   #17 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Ceck if is supported CPU then finfd by yourself Pinout with new update
http://forum.gsmhosting.com/vbb/f609...orial-1908984/
allumts
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 04-04-2015, 09:59   #18 (permalink)
Member: 164754
Help.
Need SM-T211, T210 emmc repair files.
Old 04-04-2015, 13:55   #19 (permalink)
Member: 925389
Thanks Meter: 32
need I9100 pinout for direct conection.thx
Old 04-04-2015, 15:25   #20 (permalink)
allumts's Avatar
Member: 1564612
@ali1803,
Search button get Miracle...use and find Thread about this I9100
Old 04-05-2015, 15:52   #21 (permalink)
Member: 925389
Thanks Meter: 32
i cant finde it.any one helpe me?thx
Old 04-07-2015, 20:49   #22 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 156
Originally Posted by .::GSMUnlock::. View Post
need i9515 tp pic........
i need also blease share if you have i9515
Old 04-10-2015, 03:12   #23 (permalink)
Member: 758655
need file emmc i8190
Hiiii. i need emmc file for i8190 for atf. Please share this file. Thanks
Old 04-27-2015, 15:13   #24 (permalink)
Member: 1418143
Thanks Meter: 353
as proof , I did one by .TAR's way .
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 15010038574D42335200AC0363FA41D7
CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Boot Information
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3072 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 7818182656 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 512 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : 8WMB3R
Product Rev : 0.0
Product SN : AC0363FA
Manufactured : January 1998
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
15010038574D42335200AC0363FA41D7.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Start Writing Flash Images...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
Partition Selected: USER AREA
Total Elapsed Time 00:00:00
Write Success!
Flash Image: PIT
Start Writing 0x00000009 Blocks at 0x00000022
Write Success!
Flash Image: SGPT
Start Writing 0x00000021 Blocks at 0x00E8FFDF
Write Success!
Flash Image: aboot.mbn
Start Writing 0x00001000 Blocks at 0x00022280
Total Elapsed Time 00:00:03
Write Success!
Flash Image: sbl1.mbn
Start Writing 0x00000400 Blocks at 0x00021E00
Total Elapsed Time 00:00:01
Write Success!
Flash Image: rpm.mbn
Start Writing 0x00000400 Blocks at 0x00023280
Write Success!
Flash Image: tz.mbn
Start Writing 0x00000400 Blocks at 0x00023680
Write Success!
Flash Image: sdi.mbn
Start Writing 0x00000040 Blocks at 0x00022200
Write Success!
Flash Image: non-hlos.bin
Start Writing 0x00007000 Blocks at 0x00002000
Total Elapsed Time 00:00:24
Write Success!
Flash Image: boot.img
Start Writing 0x00005000 Blocks at 0x00033280
Total Elapsed Time 00:00:18
Write Success!
Flash Image: recovery.img
Start Writing 0x00005000 Blocks at 0x00038280
Write Success!
Warning: EXT3/4 Image Detected
Skipping system.img.ext4...
Flash Image: modem.bin
Start Writing 0x00018E00 Blocks at 0x00009000
Total Elapsed Time 00:01:25
Write Success!
Skipping cache.img.ext4...
Skipping hidden.img.ext4...
Total Images Written: 9
Process Done!
Old 04-29-2015, 07:16   #25 (permalink)
Member: 636569
Thanks Meter: 192
Unhappy
need firmware rom boot 1,rom bot 2 and rom boot 3 samsung P5100...help
Old 04-29-2015, 10:53   #26 (permalink)
Member: 1418143
Thanks Meter: 353
use .tar no need wait some body to give file
Old 05-08-2015, 13:59   #27 (permalink)
Member: 103844
Thanks Meter: 21
can i use this file g7102 for G7105L?
Old 05-09-2015, 09:37   #28 (permalink)
allumts's Avatar
Member: 1564612
But how can think only that (not specific what file), you can use the same file, connection itc... for 2 Totally Different phone?...
Read always carefully all Stycky Thread and F.A.Q. first of post these thinghs.
Old 05-29-2015, 17:14   #29 (permalink)
jupizet's Avatar
Member: 154427
Thanks Meter: 61
After write *.tar phone can boot normal or need flash again with odin?
Old 07-23-2015, 05:44   #30 (permalink)
Member: 2085670
Thanks Meter: 35
Dear sir ,
i have samsung sm-n9005 imei is nilll and basband in unkow aney solution on ATF box?
Page generated in 0.23199 seconds with 8 queries
