07-05-2012, 06:56 | #1 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Angel sir Plz if i remove IMEI Then set power on after re right IMEI Then stand Nokia Logo PLZ HELP |
07-05-2012, 07:00 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Backup RPl > Reset NPC > Read Full Pm > Erase Full > Flash with latest version > Restore RPL > SX4 > Write PM Post result Br - srinibas | |
07-05-2012, 10:15 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Do this; 1. Backup Full PM and RPL 2. Full Erase phone 3. Flash with v10.10 4. Write RPL 5. Flash again with 10.65 Phone will get local mode and no more "hang on Nokia logo" Rest you know the process of repair it.. BR | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
07-06-2012, 06:02 | #5 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | plz hack sir ATF Software Version v8.95 ATF Box FBUS Flash Started... Number of Image Files: 3 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ WARNING: Simlock Backup Failed If this is a Dead Phone, just click YES to Continue with the Flash Procedure... Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0B30000F ID DWORD 1 : 34C60356 ID DWORD 2 : 8C599FE2 ID DWORD 3 : E7BA1406 ID DWORD 4 : 07ACD32B 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 36 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ============================================ OLD Protocol Detected... Using Turbo Mode... ============================================ Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539 START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) VARIANT : Empty Reading : CCC (CMT) OK Reading : HWC (CMT) OK Reading : R&D (CMT) OK Reading : PARTNERC (CMT) PARTNERC : Empty Reading : MDM_KEYS (CMT) MDM_KEYS : Empty FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\354860046624820\3548600466248 20_95431.rpl Processing Image File : G:\2690_rm_635\Nokia 2690-RM-635 10.10 Urdu Flash Files\RM-635 10.10 Urdu Flash Files\rm635__10.10.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 1165 Entry Point : 0x5047 Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0B30000F ID DWORD 1 : 34C60356 ID DWORD 2 : 8C599FE2 ID DWORD 3 : E7BA1406 ID DWORD 4 : 07ACD32B 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 36 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : VARIANT ASIC Index : CMT 0 Certificate 3 Name : R&D ASIC Index : CMT 0 Certificate 4 Name : CCC ASIC Index : CMT 0 Certificate 5 Name : HWC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x36 (54) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:59 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm635__10.10.mcusw Total blocks to write : 1165 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:49 Processing Image File : G:\2690_rm_635\Nokia 2690-RM-635 10.10 Urdu Flash Files\RM-635 10.10 Urdu Flash Files\rm635__10.10.ppm_m_c CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 198 Entry Point : 0x00B6 Page Format : 128K Maximum Page Size : 0x00004000 VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01DBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:20 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm635__10.10.ppm_m_c Total blocks to write : 198 ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:12 Processing Image File : G:\2690_rm_635\Nokia 2690-RM-635 10.10 Urdu Flash Files\RM-635 10.10 Urdu Flash Files\rm635__10.10.image_m_c_blue CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 408 Entry Point : 0x00C8 Page Format : 128K Maximum Page Size : 0x00004000 VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01DC0000-0215FFFF 1 : 02160000-03FBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:30 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm635__10.10.image_m_c_blue Total blocks to write : 408 ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:15 Total Flash Write Time (Flashing Only) : 00:01:17 Total Flashing Time (Booting + Erase + Flashing) : 00:05:08 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ |
f_loader for flash id 00898892 (5130).plz help!!!! | wonkypants | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-09-2001 19:59 |
dejan flasher:erase flash error!!! plz help | wonkypants | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-09-2001 13:33 |
8810 Hangs . HW or SW PROBLEM PLZ ?! | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-29-2001 14:31 |
Plz help with unlock NOKIA 6110 2lock | henr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:29 |
