07-05-2012, 21:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Inside you
Member: 204827 Status: Offline Thanks Meter: 46 | Another N9 flash problem (Mass Memory File Detected) Processing Image File : DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO Processing Image File : DFL61_HARMATTAN_30.2012.07-1.LTA_EMMC_LTA.bin CMT Type : MAEMO/MEEGO D:\ATF\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin E:\Universal Box\Files\Nokia\BB5\N9.RM-696\30.2012.7.1\059M661\ D:\ATF\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin -F DFL61_HARMATTAN_30.2012.07-1.LTA_EMMC_LTA.bin E:\Universal Box\Files\Nokia\BB5\N9.RM-696\30.2012.7.1\059M661\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Booting/Flashing Failed... Please Try Again... Im using latest nokia usb drivers, press flash then connect the phone also with phone connected before press flash there is no way for me to flash this phone using ATF |
07-06-2012, 02:01 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... If you follow the steps above, then you will be able to flash the phone. |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
