03-31-2010, 08:25 | #16 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: Delphi XE2
Member: 1004812 Status: Offline Thanks Meter: 152 | Quote:
but if there is a need more explanation I will give key mx logs and log UB MX KEY LOG Code: ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001A2317:3B8ADA60 ASIC type: 11 UEM Imei: 35194903234887 Flash Imei: 35194903234887 MasterCode: 1461317611 RPL saved to "C:\mobileEx\3.3\data\backup\35194903234887_BACK.rpl" Phone Type: RM-512 (Nokia 2330c-2) SW Version: V 08.20 30-06-09 RM-512 (c) Nokia Imei plain: 35194903234887-5 Imei OTP: 35194903234887 Product Code: 0572703 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: X Language Pack: - not available. Imei net: 35194903234887 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Code: MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing phone... Output power at Line1 3.61V is in range of: 4.00V ±10.0% Phone powered. Reading Info... MCU Version: V 08.20 Date: 30-06-09 Type: RM-512 (2330C-2) Additional_1: (c) Nokia [Nokia 2330C-2 CABLE 2330] PPM Version: V 08.20 Date: 30-06-09 Type: RM-512 (2330C-2) Additional_1: (c) Nokia Pack: X Product code: 0572703 Production serial: DJP160654 Hardware version: 1000 Original IMEI: 351949-03-******** IMEI: 351949-03-******** Asic type: 11 Profile bits: 000000000003000B Lockinfo: 0010100000000000 Lock version: 3 SIMLock service: SIMLOCK SERVER [01000B07091C] I,M USING GPG PRO KABEL BR | |
03-31-2010, 08:43 | #18 (permalink) | |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | Quote:
THEY ARE NOT ATF'S LOGS.. put in right room.. here ATF ROOM BR ASWANCAMEL | |
03-31-2010, 08:47 | #19 (permalink) |
No Life Poster Join Date: May 2008 Location: bhakkar Age: 38
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | dear ATF BOX TEAM i buy today ATF BOX but i need your little hellp you tell me when you add sal3 unlocking ?and nokia 1202 1661 5030?unlocking becouse this time need your box .but i hoop that you do this very soon |
03-31-2010, 09:17 | #22 (permalink) | |
use easy kabel Code: ImageFile:C:\Program Files\Nokia\Phoenix\Products\rm-512\rm512__08.20.mcusw PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 > 3168 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 192 Entry Point: 0x00D8 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - Type not in database ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - Type not in database ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : E5 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 84E7BE6E0560D24E74CDD5AE8A DecodedMSID: 842C40BAE9001A2317A8000000 EncodedFAID: 6B3CB93835A4B151A0D52C20 Authentication : SUCCESSFULL Erasing address: >> 01000000 : 0101FFFF >> 01020000 : 01CFFFFF Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:38 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Making delay between files for 1500ms ImageFile:C:\Program Files\Nokia\Phoenix\Products\rm-512\rm512__08.20.ppm_x PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 > 3168 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 45 Entry Point: 0x00D4 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - Type not in database ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - Type not in database ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : E5 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia FAILED... Flashing FAILED... Flashing ERROR Time Elapse : 00:00:00 | |
03-31-2010, 11:04 | #24 (permalink) |
Insane Poster Join Date: Aug 2008 Location: india Age: 41
Member: 848740 Status: Offline Thanks Meter: 13 | Reading Phone Information... MCU: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294017847590 Product code : 0539276 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 58 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED Reading Phone Information... MCU: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294017847590 Product code : 0539276 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 58 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED Reading PM from 0 - 400 PM File SAVED TO : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\356294017847590\3562940178475 90_0-400_32922.pm Read PM End.. Time Taken to Read PM : 00:00:33 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.30.10 Software Version : v4.70 AdvanceBox SN : F16E579CBB2AB072D5D9C17F BOX Status : ACTIVATED INIT : OK Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100701 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : B9E87557 ID DWORD 1 : 40AA37F9 ID DWORD 2 : 96A3A642 ID DWORD 3 : 05763745 ID DWORD 4 : 9A0F2C2C 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 2C 05 36 9F 57 CC 3C 4C F9 E7 83 E8 3D 9B 51 2B 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : AB5E4ADB CRC 1 : 27A06946 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01002200 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 8 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 14200111 ID DWORD 1 : AC795D51 ID DWORD 2 : 30A244BB ID DWORD 3 : F84B1C2B ID DWORD 4 : 7494A7D9 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : CEA7B19D Checksum 38 BootCodeLen : A5 Send Loader... Custom Loader Running! VBATT OFF ... VBATT ON Setting VBATT Done!... Reading Phone Information... MCU: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294017847590 Product code : 0539276 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 58 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED Please wait until finished.. Step one.. Changing MODE : FLASH connecting to server.. Connection GOOD! Sending data to server... STEP 2 >>>>>>>>> Changing MODE : FLASH connecting to server.. Connection GOOD! Sending data to server... >>> : SX4 Auth Successfull Reading Phone Information... MCU: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294017847590 Product code : 0539276 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 58 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED Reading PM Important DATA Important PM Data saved to : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\356294017847590\imp_356294017 847590_33057.pm Time Taken to Read Important PM : 00:00:06 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.30.10 Software Version : v4.70 AdvanceBox SN : F16E579CBB2AB072D5D9C17F BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.30.10 Software Version : v4.70 AdvanceBox SN : F16E579CBB2AB072D5D9C17F BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.30.10 Software Version : v4.70 AdvanceBox SN : F16E579CBB2AB072D5D9C17F BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.30.10 Software Version : v4.70 AdvanceBox SN : F16E579CBB2AB072D5D9C17F BOX Status : ACTIVATED INIT : OK Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100701 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : B9E87557 ID DWORD 1 : 40AA37F9 ID DWORD 2 : 96A3A642 ID DWORD 3 : 05763745 ID DWORD 4 : 9A0F2C2C 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 2C 05 36 9F 57 CC 3C 4C F9 E7 83 E8 3D 9B 51 2B 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : AB5E4ADB CRC 1 : 27A06946 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01002200 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 8 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 14200111 ID DWORD 1 : AC795D51 ID DWORD 2 : 30A244BB ID DWORD 3 : F84B1C2B ID DWORD 4 : 7494A7D9 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : CEA7B19D Checksum 38 BootCodeLen : A5 Send Loader... Custom Loader Running! Restarting phone, please wait .. . VBATT OFF ... VBATT ON Setting VBATT Done!... Reading Phone Information... MCU: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294017847590 Product code : 0539276 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 58 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED connecting to server.. Connection GOOD! Sending data to server... Detected Sp type: SL2 (SL20) -> OK: Simlock RPL accepted VBATT OFF ... VBATT ON Setting VBATT Done!... Reading Phone Information... MCU: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294017847590 Product code : 0539276 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER VERSION 58 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED Successfully done. |
03-31-2010, 11:56 | #25 (permalink) |
Product Supporter Join Date: Sep 2004 Location: PHILIPPINES Age: 46
Member: 81952 Status: Offline Sonork: 1597268 Thanks Meter: 2,364 | If you are having some problem in activation and init, Please download Fixed Installer ATF DOWNLOAD SITE - powered by Advance Team select: ATFSetup_v4.70_fixed.exe br, ulymar |
The Following 2 Users Say Thank You to ulymar For This Useful Post: |
03-31-2010, 12:36 | #26 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Processing Image File : C:\Uni\Files\Nokia\BB5\5220.RM-411\06.51\rm411__06.51.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1287 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : C:\Uni\Files\Nokia\BB5\5220.RM-411\06.51\rm411__06.51.ppm_x CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 498 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : C:\Uni\Files\Nokia\BB5\5220.RM-411\06.51\rm411__06.51.image_x_blue CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 832 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1EC00112 ID DWORD 1 : 94465750 ID DWORD 2 : EAE8320B ID DWORD 3 : 75DB0C26 ID DWORD 4 : 48D311CB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum AC BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : FFFFFFFFFFFFFFFFFFFF 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 61 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... No partition info.... No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF ERASE_REQUEST_BB5 : 5001123300000000000000000006BF000006C00001FFFF0004 0000000BFFFF000C00000013FFFF001400000137FFFF013800 000151FFFF32 Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01DBFFFF ERASE_REQUEST_BB5 : 5001120B0000000152000001DBFFFFB4 Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds >> Time Elapsed 45 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01DC0000-0215FFFF 1 : 02160000-03FBFFFF ERASE_REQUEST_BB5 : 5001121300000001DC00000215FFFF0216000003FBFFFFD3 Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds >> Time Elapsed 45 seconds >> Time Elapsed 50 seconds >> Time Elapsed 55 seconds >> Time Elapsed 60 seconds >> Time Elapsed 65 seconds >> Time Elapsed 70 seconds >> Time Elapsed 75 seconds >> Time Elapsed 80 seconds >> Time Elapsed 85 seconds >> Time Elapsed 90 seconds >> Time Elapsed 95 seconds >> Time Elapsed 100 seconds >> Time Elapsed 105 seconds >> Time Elapsed 110 seconds >> Time Elapsed 115 seconds >> Time Elapsed 120 seconds >> Time Elapsed 125 seconds >> Time Elapsed 130 seconds >> Time Elapsed 135 seconds >> Time Elapsed 140 seconds >> Time Elapsed 145 seconds >> Time Elapsed 150 seconds >> Time Elapsed 155 seconds >> Time Elapsed 160 seconds >> Time Elapsed 165 seconds >> Time Elapsed 170 seconds >> Time Elapsed 175 seconds >> Time Elapsed 180 seconds >> Time Elapsed 185 seconds >> Time Elapsed 190 seconds >> Time Elapsed 195 seconds >> Time Elapsed 200 seconds >> Time Elapsed 205 seconds >> Time Elapsed 210 seconds >> Time Elapsed 215 seconds >> Time Elapsed 220 seconds >> Time Elapsed 225 seconds >> Time Elapsed 230 seconds >> Time Elapsed 235 seconds >> Time Elapsed 240 seconds >> Time Elapsed 245 seconds >> Time Elapsed 250 seconds >> Time Elapsed 255 seconds >> Time Elapsed 260 seconds >> Time Elapsed 265 seconds >> Time Elapsed 270 seconds >> Time Elapsed 275 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:05:23 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : rm411__06.51.mcusw Total blocks to write : 1287 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Processing : rm411__06.51.ppm_x Total blocks to write : 498 Processing : rm411__06.51.image_x_blue Total blocks to write : 832 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:46 Total Flashing Time (Booting + Erase + Flashing) : 00:07:13 |
03-31-2010, 15:30 | #28 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @baldev Yes, you need to press "init box" This is not a problem,,, new firmware 3.30.10 need to be initialized before you can use it. This is 100% Normal |
The Following User Says Thank You to X-Shadow For This Useful Post: |
03-31-2010, 18:26 | #30 (permalink) |
Freak Poster Join Date: Jul 2006 Location: UAE
Member: 314698 Status: Offline Thanks Meter: 47 | E72 RM-530 V23. Successfully Flashed ATF V 4.70 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 12500214 ID DWORD 1 : 96730344 ID DWORD 2 : 5689FA95 ID DWORD 3 : A3AD81C0 ID DWORD 4 : 5A4A2873 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA Checksum DB BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0058 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0058 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0058 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00020000 (131072) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0E780000-1F13FFFF ERASE_REQUEST_BB5 : 5001120B0003000E7800001F13FFFF28 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:02 Is Flashing CLOCK AUTO : -1 Processing : rm530_023.002_U000.000_prd.uda.fpsx Total blocks to write : 19 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:06 Making delay between files for 1500ms Total Flashing Time (Booting + Erase + Flashing) : 00:02:52 |
ATF v12.70 Update!! 31 MAR 2017!! | gsmfun | Advance-Box | 79 | 03-31-2017 15:31 |
ATF [Advance Turbo Flasher] version v2010.0.1.21 discussion thread | gsmfun | Advance-Box | 32 | 07-24-2010 19:09 |
ATF [Advance Turbo Flasher] Version 4.60 update Discussion | Javajohn | Advance-Box | 23 | 03-30-2010 22:51 |
ATF [Advance Turbo Flasher] Version 4.50 update[old thread] | Javajohn | Advance-Box | 27 | 03-21-2010 21:43 |
ATF [Advance Turbo Flasher] Version 4.50 update!! 21 Mar 2010 | gsmfun | Service Products News & Updates | 0 | 03-20-2010 19:45 |
