09-26-2014, 23:37 | #3 (permalink) |
Junior Member Join Date: Mar 2009
Member: 985727 Status: Offline Sonork: raoji Thanks Meter: 0 | i have same problem ,disable anti virus , intall new windows change pc , also i tried new ftd drivers but problem is remain same any one have authentic solution or its ATF box problem ..........help needed BR |
09-27-2014, 06:00 | #6 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Esam Telecom Age: 43
Member: 696206 Status: Offline Sonork: 100.1597401 Thanks Meter: 262 | bro: im not use Antivirus Difference old ATF box working but New ATF not working Last edited by mdmosheur; 09-27-2014 at 06:06. |
10-03-2014, 07:09 | #9 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1776947 Status: Offline Sonork: 100.1659966:tjjxxs Thanks Meter: 74 | ATF server connection error s symble solution first install 11.60 then replace 11.70 to ATF folder THEN the file to atf folder download link OPEN_SSL_32_BIT - Download - 4shared |
10-03-2014, 08:15 | #10 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
10-03-2014, 08:46 | #11 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Bangladesh
Member: 1292009 Status: Offline Sonork: 100.1586379 Thanks Meter: 802 | easy solution just setup 11.70 version Here is link ATF_v11.70_Full_Installer - Download - 4shared - Linus Hernandez Tested by me many box |
10-03-2014, 11:48 | #12 (permalink) | |
No Life Poster Join Date: May 2007 Location: *** TUNISIA *** Age: 41
Member: 506993 Status: Offline Sonork: 100.1580692 Thanks Meter: 1,003 | Quote:
ok .... soved by copying dll from DLL_32-BIT to main soft folder and replaced. | |
