sir X-Shadow after ma clik ko update software update wa n mag open akung nitro..,how can i fixed this ?.., |
i just baying a new ATF advance box. how to get a user name ? where i can register ? Driver Version : 00021000 05:16:09 : Library Version : 00030207 05:16:10 : Box Type : ATF Lightning 05:16:10 : Box Firmware : LogiCore 10.3.80 05:16:10 : Software Version : v12.31 05:16:10 : AdvanceBox SN : F001C168B00E07F399789ADF |
@tc electronics and @TRABELSISAMI Why post anywhere? if want help goes where's wrote "New Thread" opend each one You own and can recive help, seen Not read how always the Sticky Thread in section. BR |
Advance box latest drivers help How to find latest drivers for my atf its really confusing please supporters just share the latest drivers for atf that we use it easily i did update important files but failed i did check software update but failed cant update software (even in 4 different pc`s) but failed please i have alot of work to do with atf and now my atf not working and asking for .......... ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ |
@adduangel, Same thingh for you. Why post anywhere? if want help goes where's wrote "New Thread" opend You own and can recive help, seen Not read how always the Sticky Thread in section. Now who post anywere his problem not receive any Help becouse this THREAD is only for ATD D.R.I.V.E.. BR |
Which is the best unlock for Samsung phone Sent from my iPhone using Tapatalk |
Which is the best unlock box for nokia Sent from my iPhone using Tapatalk |
Which is the best unlocked box for the Sony Ericsson Sent from my iPhone using Tapatalk |
Please help me Sent from my iPhone using Tapatalk |
ATF pls view the screen shots and do the needful Model L520 rm-914 http://C:\AdvanceBox Turbo Flasher\Logs\Screenshots |
I had the same problem on w 7 64bit and this way I've managed to make it work |
ATF pls view the screen shots and do the needful Model L520 rm-914 |
Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xE7144AB8 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x207D00E1 IR11 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x207D00E1 IR11 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x207D00E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 4/8/2014 2:50:00 PM ================================================== ======== CPU Type Supported : ALL LUMIA WIN8 Except Snapdragon 800 Storage TYpe : eMMC ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type 6. Use RESET JTAG button to check the JTAG Connection 7. Click CUSTOM R/W to Start Read or Write Operations ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...11010030303847393200D065C6524099 Flash Description: Toshiba 008G92, 7.28 GiB, SN D065C652, Apr 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5985 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_im_india_269_01_ 444377_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x8E51A28E Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...Flash Write Error at 0x00000200, Loader Error, Code 0x72 Please send this log and "..\Logs\.log" file to support! |
nokia mtk support please add nokia mtk support in next update other box already have that.. |
@nokiagopan Upload this file here: Please send this log and "..\Logs\.log" file to support! |
