Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-19-2015, 12:21   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,604
ATF DRIVE v12.31 Update!! Public Discussion Thread:
ATF Auto-Update 12.31
May 22, 2015
1. You Need to click "Check For Updates" then get ATF 12.31
2. Run ATF 12.31, then click "UPDATE IMPORTANT FILES"
eMMC Tool 3.2 (PRO)
---> Fixed UAC Problems for ATF DRIVE 32/64-BIT "Mount Drive Failed!"
---> Added "Direct ATF BIG Box Connection (3.25V on PIN 2)" in CPU Type. Now you can use again your home eMMC Adapters with ATF BIG BOXES
Release Date: May 19, 2015
Firmware Version Required : 11.0.10 or 11.0.12
ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
ATF Plus eMMC Tool 4.0 (PRO)
Introducing ATF Drive !!! 100% FREE FOR ALL ATF BOX USERS
D.R.I.V.E. = Data Recovery Interface Via EMMC
First In the World Solution that will MOUNT eMMC Partitions as a Windows Removable Disk!
Now you can Recover Data from a Dead Phone by Simply using Windows Explorer "Search" and "Copy + Paste".
Special Features:
--> Supports Windows XP, Vista, 7, 8.0 and 8.1 (All 32-Bit and 64-Bit Versions)
--> You can load Partitions via Direct ISP eMMC Connection (4 wires + Vcc/VccQ) or via eMMC Binary Dumps
--> Supports FAT12, FAT16, FAT32, exFAT, NTFS Windows Phone Partitions
--> Supports EXT2, EXT3 and EXT4 Android Partitions (1)
--> You can READ + WRITE to Mounted Partitions as if they were USB Drives on your PC! (2)
--> Supports Recovery of Windows Phone 8.0/8.1/10 DATA Partition EVEN if MBR, GPT and BOOTLOADERS are ERASED!
--> Faster READ/WRITE Speeds when compared with other Products
--> Supports MBR + GPT Partitions of Android and Windows Phones
Video Demonstration on Lumia WP8 Phone Here:
http://forum.gsmhosting.com/vbb/f609...phone-1949888/
Video Demonstration on Android Phone Here:
http://forum.gsmhosting.com/vbb/f609...phone-1949890/
(1) : EXT2, EXT3 and EXT4 Support Requires Additional Installation of
a FREE Software Paragon EXTFS which can be downloaded here:
https://www.paragon-software.com/home/extfs-windows/
(2) : WRITE Operations on EXT2, EXT3 and EXT4 are not Supported by FREE Software
Paragon EXTFS. If you want to WRITE to Android/Linux Partitions, you can
still do so "AT YOUR OWN RISK" via using another FREE Software named
Ext2Explore. More Information here:
Ext2Read download | SourceForge.net
---> Added "Samsung eMMC Write CID" Function for writing Custom CID to Samsung eMMCs
Lumia 8.0 + 8.1 BOOT RECOVERY via USB
--> Windows Phone 8.0/8.1/10 Flasher now has an improved BUILT-IN BOOT REPAIR Function via USB.
--> If your WP Phone is TOTALLY DEAD or HALF DEAD or TOTALLY ALIVE, ATF WILL FLASH it via USB ONLY! (3)
Added Support for 40 New Lumia 8.1 Phones
RM-1068 : Lumia 435 DS
RM-1069 : Lumia 435 DS
RM-1070 : Lumia 435
RM-1071 : Lumia 435
RM-1114 : Lumia 435 DS
RM-1017 : Lumia 530
RM-1018 : Lumia 530
RM-1019 : Lumia 530 DS
RM-1020 : Lumia 530 DS
RM-1031 : Lumia 532 DS
RM-1032 : Lumia 532 DS
RM-1034 : Lumia 532
RM-1115 : Lumia 532 DS
RM-1089 : Lumia 535
RM-1090 : Lumia 535 DS
RM-1091 : Lumia 535
RM-1092 : Lumia 535 DS
RM-976 : Lumia 630
RM-977 : Lumia 630
RM-978 : Lumia 630 DS
RM-979 : Lumia 630 DS
RM-974 : Lumia 635
RM-975 : Lumia 635
RM-1027 : Lumia 636 4G
RM-1010 : Lumia 638 4G
RM-1040 : Lumia 730 DS
RM-1038 : Lumia 735
RM-1039 : Lumia 735
RM-1078 : Lumia 735
RM-983 : Lumia 830
RM-984 : Lumia 830
RM-985 : Lumia 830
RM-1049 : Lumia 830
RM-927 : Lumia Icon/929
RM-1045 : Lumia 930
RM-1087 : Lumia 930
RM-937 : Lumia 1520
RM-938 : Lumia 1520
RM-939 : Lumia 1520
RM-940 : Lumia 1520
Refreshed Support for 28 Old Lumia 8.0 Phones
(Now uses loaders based on RM-xxx Type)
RM-820 : Lumia 920
RM-821 : Lumia 920
RM-822 : Lumia 920
RM-824 : Lumia 820
RM-825 : Lumia 820
RM-846 : Lumia 620
RM-860 : Lumia 928
RM-867 : Lumia 920T
RM-875 : Lumia 1020
RM-876 : Lumia 1020
RM-877 : Lumia 1020
RM-885 : Lumia 720
RM-887 : Lumia 720T
RM-892 : Lumia 925
RM-893 : Lumia 925
RM-910 : Lumia 925
RM-913 : Lumia 520T
RM-914 : Lumia 520
RM-915 : Lumia 520
RM-917 : Lumia 521
RM-941 : Lumia 625
RM-942 : Lumia 625
RM-955 : Lumia 925T
RM-994 : Lumia 1320
RM-995 : Lumia 1320
RM-996 : Lumia 1320
RM-997 : Lumia 526
RM-998 : Lumia 525
(3) : Not all Phones can be Repaired via USB Cable Only. Some Phones might have a
buggy eMMC Inside which requires Direct EMMC Connection or JTAG to Repair.
BUG FIXES:
1. Fixed Bug on Nokia X2 (Android) Flashing/Boot Repair
Added New Lumia Models to Nokia.ini
--> Lumia 540 Dual SIM (RM-1140)
--> Lumia 540 Dual SIM (RM-1141)
*** WARNING ***
Starting ATF 12.30, "Skip Flash File Checksum Verification Before Flashing" is
now SELECTED in "Settings" ---> "Nokia Settings".
This allows FASTER LUMIA Flashing Procedure on Slower PCs. However, your Phone
might DIE if your FFU File is Corrupted. Anyway, you can still repair the phone
via USB Cable after your have Downloaded a NON-CORRUPTED FFU File.
Who will buy this if you can get more in ATF?
__________________________________________________ ________________________
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
India: Advance Box - .:: GsmIndia ::.
Official Iran Support Forum : ASANGSM FORUM
Bangladesh: Advance Box - Dhaka Mobile
Chinese Support forum : www.yananliuhuan.com
The Master Piece
The Following 19 Users Say Thank You to gsmfun For This Useful Post:
Old 05-19-2015, 12:24   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
ATF v12.30 Mediafire Mirror
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 05-19-2015, 13:35   #3 (permalink)
Member: 2388409
lumia 630 RM 978 repair boot error
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Connect Phone to the USB Port
2. Press and Hold the VOLUME DOWN and POWER Buttons
3. Wait until the Phone Vibrates Shortly...
4. Stop Pressing the Buttons...
If the Phone is DEAD BOOT
2. Install Correct Drivers:
"Nokia Emergency Connectivity"
Recovery Handle Found! - (WinUSB)
PBL Emergency Download Detected
Start Sending Firehose Loader...
Firehose Loader Sent!
Executing Firehose Loader...
Start Processing Firehose Payload...
MSG_SIGNATURE Sent....
ERROR: error code= 1 value= HW_INIT:init storage:fail
ERROR: Flashing Failed!
Old 05-19-2015, 13:43   #4 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Look at error code.
Means probable emmc problem.
Check phone pcb, probably just needs rework.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 05-19-2015, 13:55   #5 (permalink)
Member: 1169259
Sonork: 100.1648194
Thanks Meter: 149
Samsung eMMC Write CID why this option i need more info please ?
Someone requested this option since some MTK phones check the emmc type.
So now you can clone CID of other emmc and make phone think it is the required emmc.
Old 05-19-2015, 14:50   #6 (permalink)
Member: 804397
Thanks Meter: 51
isp connection for alltype emmc
need isp connections for all type emmcs
Old 05-19-2015, 17:35   #7 (permalink)
ZiDanRO's Avatar
Member: 1722871
Thanks Meter: 116
Direct emmc coection for lumia 630 can be found without removing the emmc?
I'm searching and searching on the forum and no luck
Old 05-19-2015, 17:45   #8 (permalink)
lionfinger2007's Avatar
Member: 576282
Thanks Meter: 145
Originally Posted by ..::Angel::.. View Post
Please stop giving us link with captcha, give us direct mediafire link that doesn't need captcha.
Old 05-19-2015, 17:52   #9 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
You try download from here
ATF_v12.30_Full_Installer.rar
But why don't have patience to enter captcha ., that would take 20 sec .,
The Following 4 Users Say Thank You to Smart-gsm For This Useful Post:
Old 05-19-2015, 18:43   #10 (permalink)
ZiDanRO's Avatar
Member: 1722871
Thanks Meter: 116
If you install 12.3 and then press update software it say new version found and installs 12.2
Old 05-19-2015, 18:50   #11 (permalink)
islamic.tj's Avatar
Member: 1533366
Thanks Meter: 131
big boom update sir thx all atf team !!! i think if you add samsung tool i'm buy 1st in customers
D.R.I.V.E. = Data Recovery Interface Via EMMC )))))) cool name
Old 05-19-2015, 19:19   #12 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Not use at the moment "Autoupdate" button, leave this UNcecked, will be solved soon i think.
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 05-19-2015, 19:24   #13 (permalink)
allumts's Avatar
Member: 1564612
Other link working 100% by 4Shared
allumts
The Following 8 Users Say Thank You to allumts For This Useful Post:
Old 05-20-2015, 08:10   #14 (permalink)
Member: 2269610
after update to 12.30 my big box can't detect any emmc,,,,,on 12.20 all working well???
Old 05-20-2015, 08:16   #15 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 151
just use full installer file
Page generated in 0.23232 seconds with 9 queries
