05-20-2015, 10:37 | #17 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
If so, then yes it is disabled in 12.30. Why disabled? Because it causes problems to some people who do not know how to correctly select "CPU Type" in emmc tool. If you need it, I will add 1 check box to enable it again. | |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
05-20-2015, 10:39 | #18 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Can post Screenshoot of what phone you have connected via emmc direct and do "Scan emmc" not to see this phone? NOTE: remember that there's also button for ATF DRIVE "MOUNT" where you can see all partition of you emmc, need of download FREE version, (read only) of "Paragon extFS"... read Update about Android and Lumia with this method.. BR allumts | |
05-20-2015, 10:48 | #19 (permalink) | |
Junior Member Join Date: Oct 2014
Member: 2269610 Status: Offline Thanks Meter: 0 | Quote:
05-20-2015, 10:57 | #20 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | I get this error when try to mount lumia 620 data partition readed earlyer with atf: https://www.dropbox.com/s/r26y9w1jih...error.jpg?dl=0 What could be the problem? ps.: I installed the paragon sw already |
05-20-2015, 11:05 | #21 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Sorry @X-Shadow, was writing when you have answered above. Have one question, i've tested with I9505 and can Read all Partition by "MOUNT" button, now i want know if is possible from what there wrote here: Quote:
BR allumts | ||
05-20-2015, 12:15 | #22 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Quote:
Maybe my dumps have problem? Or need i configure anyting ? Many thanx for answering. dazexy | |
05-20-2015, 13:24 | #23 (permalink) | |
No need to configure anything. Maybe make sure you are using administrator rights on your windows. Or manually set C:\Advance Turbo Flasher\Drive32.exe to "Run As Admin" in file properties. | |
05-20-2015, 17:07 | #24 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @X-Shadow i've the same problem above and i'm Admin of my PC....but charge correct from "MOUNT" button but when i want Read one partition one time say that file is more big of LBA....if select only "modem" say cannot Mount Disk.... Have add in Fw exception exFat program, have run all as admin but always same problem... cannot Mount Disk...please why this problem? BR allumts |
05-20-2015, 18:28 | #26 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | on my third computer is also fail to mount, ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300811A91BC40DF CSD : D02701320F5903FFF6DBFFEF96404063 Selected Drive Letter: E Mounting Drive... Failed! ERROR: Cannot Connect to eMMC! ERROR: Cannot Connect to eMMC! ERROR: Cannot Connect to eMMC! cant send private message to X-Shadow because mailbox is full. I'm ready to give some teamwiever access to try it on my computer. Many thanx for helping! dazexy |
05-21-2015, 08:03 | #27 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384731573005201294905011 CSD : D02701320F5903FFF6DBFFE18E404029 Selected Drive Letter: I Mounting Drive... Failed! ERROR: Cannot Connect to eMMC! |
05-21-2015, 10:37 | #28 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL I think some problem exists in 32-BIT Windows for now. Anyone here care to show me in teamviewer right now? My mailbox always full after few days of delete.. now I delete messages again. SO can send PM if even have teamviewer ID> |
