09-14-2014, 14:39 | #1 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1682611 Status: Offline Thanks Meter: 3 | ATF flash 520 error 19:35:01 : Windows Phone 8 Lumia Flasher 19:35:01 : ================================================== ==== 19:35:01 : 19:35:01 : If the Phone is ALIVE 19:35:01 : 1. Power On the Phone and Connect it to the USB Port 19:35:02 : 19:35:02 : If the Phone is DEAD 19:35:02 : 1. Connect Phone to the USB Port 19:35:02 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 19:35:02 : 3. Wait until the Phone Vibrates Shortly... 19:35:02 : 4. Stop Pressing the Buttons... 19:35:02 : ================================================== ==== 19:35:02 : 19:35:13 : Nokia Phone Info Mode Initiated... 19:35:13 : Please wait upto 15 Seconds for SW Reset 19:35:13 : IMEI: 358995056150229 19:35:13 : Version: 1.1.1.3 19:35:13 : Product Code: 059S357 19:35:13 : Module Code: 0205435 19:35:13 : Continuing Previous Boot... 19:35:13 : Please wait upto 30 Seconds for Boot Re-entry 19:35:14 : 19:35:14 : Boot Flash Mode Successful... 19:35:15 : Buffers Flushed OK... 19:35:15 : 19:35:15 : Phone Info Query Start... 19:35:15 : Blocks Returned: 0x07 Blocks 19:35:15 : Block ID 0x01 :00241000 19:35:15 : Block ID 0x02 :00240000 19:35:15 : Block ID 0x03 :00E90000 19:35:15 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 19:35:15 : Block ID 0x0D :0001 19:35:15 : Block ID 0x0F :0301010100000101FF 19:35:15 : Block ID 0x10 :0100030000 19:35:15 : Checking SD Card Size... 19:35:15 : Card Size: 0x00000000 19:35:15 : Checking Platform Security Status... 19:35:15 : Platform Secure Boot Status: Active 19:35:15 : Secure FFU EFUSE Status: Active 19:35:15 : Debug Status: Active 19:35:15 : RDC Status: Not Active 19:35:15 : Authentication Status: Not Active 19:35:15 : UEFI Secure Boot Status: Active 19:35:15 : Checking Secure FFU Mode... 19:35:15 : Secure FFU Mode : SYNC + ASYNC 19:35:15 : Query Flash App Information... 19:35:15 : Flash App Information: 02010E011900 19:35:15 : UEFI App: FLASH APP 19:35:15 : Flash App Protocol Version: 1.14 19:35:15 : Flash App Implementation Version: 1.25 19:35:15 : Query ROOT KEY HASH... 19:35:15 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD 19:35:15 : 19:35:15 : Sending Image Signatures... 19:35:15 : Image Signatures Accepted! 19:35:15 : Erasing Data Partition... 19:35:15 : Data Partition Erased Successfully 19:35:16 : Fixing Partitions... 19:35:16 : Preparing Buffers for DATA LOOP... 19:35:16 : Allocating System RAM OK! 19:35:16 : Start Sending DATA BLOCKS... 19:35:16 : ERROR: DATA BLOCK REJECTED at 0x00300000 19:35:16 : Check your Flash File and Phone Connection 19:35:16 : ERROR: Flashing Failed! |
