06-03-2015, 16:01 | #33 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Solder it properly like what I did. I already showed you pinout... I already made repair file from my phone dump. Nothing else for me to do, all on you now | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-03-2015, 18:35 | #38 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Man look at pinouts.... You don't need such adapter. Just connect direct to ATF box. Pinout already very very very very clear! |
06-04-2015, 20:14 | #39 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Had understan that you are the first time doing one Jtag or Direct EMMC in this case.... You must need of an enameled copper wire of 0.10mm, one RJ45 cable, (8 pin), not to loock the colours in the cable but loock diagram posted from X-Shadow, use numbers.... with soldering iron a fine tip connect pinout in phone and other side directly in the 4/5 wires of the RJ45 cable...connect in the box...scan eMMc button then press "write" and select the Dump uploaded by X-Shadow...waith that process finish and enjoy.... BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
06-08-2015, 09:37 | #41 (permalink) | |
Junior Member Join Date: Jun 2015
Member: 2402477 Status: Offline Thanks Meter: 1 | 640 XL dead boot Quote:
i do everything true but how many time long after push "WRITE"? | |
06-15-2015, 10:39 | #44 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @behza_rad, the only thing that can help you is to start to have knowledge of what a JTAG, what an EMMC direct, as is welding itc... from the first moment, (have just wrote), have understand you not have any knowledge about these procedure...Not is one Offense all are been newbie...but not start with one nokia of this....use device damaged for starting and understand how is easy and work Atf Box about these repair... @X-Shadow have explained you in 10 or more mode all tip but you answer if have need of use Adapter V2....sorry but start with good welding manuality ant later you'll see that all rest is very very easy.... Regards allumts |
