ATF Lumia 640 XL DS WinPhone 8.1 Full Flashing + EMMC TP !!! - FIRST IN THE WORLD ATF Lumia 640 XL DS WinPhone 8.1 Full Flashing! Also check out other Lumia WinPhone 8.0/8.1/10 Phones Flashed by ATF: Microsoft Lumia 430 DS - Fully Tested Microsoft Lumia 435 DS - Fully Tested Nokia Lumia 520 - Fully Tested Nokia Lumia 530 - Fully Tested Nokia Lumia 620 - Fully Tested Nokia Lumia 625 - Fully Tested Nokia Lumia 630 - Fully Tested Nokia Lumia 638 - Fully Tested Nokia Lumia 720 - Fully Tested Nokia Lumia 735 DS - Fully Tested Nokia Lumia 810 - Fully Tested Nokia Lumia 820 - Fully Tested Nokia Lumia 822 - Fully Tested Microsoft Lumia 830 - Fully Tested Nokia Lumia 920 - Fully Tested Nokia Lumia 925 - Fully Tested Nokia Lumia 928 - Fully Tested Microsoft Lumia 929 - Fully Tested Microsoft Lumia 930 - Fully Tested Nokia Lumia 1020 - Fully Tested Nokia Lumia 1320 - Fully Tested Nokia Lumia 1520 - Fully Tested You Can Download Flash Files Here: http://forum.gsmhosting.com/vbb/f609...added-1660094/ Microsoft Lumia 640 XL DS WinPhone 8.1 Flashed Successfully with ATF Here are the Screenshot: http://174.120.45.27/tmp/LUMIA_640_XL_FULL_FLASH_A.jpg Here is the Flashing Logs: Code:
http://174.120.45.27/tmp/LUMIA_640_XL_TEST_PHONE_A.jpg FLASHING The Phone... http://174.120.45.27/tmp/LUMIA_640_XL_TEST_PHONE_B.jpg BOOT Repair Tests will follow :) BR X-Shadow |
why you not use ATF Big box? What is difference between Big and Nitro? huh? |
ATF Big box is good and add more hardware... |
Hi I have 640 xl rm-1067 dead boot when I want flash with atf log sey use emmc or JTAG but I can't find emm file, please help me for recover boot |
Show logs... otherwise we don't have a clue. |
640 XL dead boot Quote:
640 XL deadboot Quote:
Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Recovery Handle Found! - (WinUSB) ERROR: NOT Supported for USB BOOT Repair! Use eMMC or JTAG Method to Repair Boot... ERROR: Flashing Failed! ==================================== please help |
when i connect my phone in the device manger show me QHSUSB__BULK...it's normaly? |
@behza_rad For now, 640 XL is not supported for USB boot repair. I will open my phone now to check if we can do repair via eMMC direct connection (soldering required). |
Tnx I'll be witing tnx again |
Also, you might want to check if battery is just empty.... New Lumia 8.1 like 640, 640XL, 430, 435 etc... They all get detected as QHSUSB__BULK or Nokia Emergency Driver when battery is removed or DEAD. SO possible,, your battery is just totally empty. If I connect my 640 XL to the usb port without the battery attached, I also get QHSUSB__BULK... B.R. |
Men posble my battery is empty,if my battery full show me what? |
I have opened my phone and there are eMMC pinouts :) |
Tnx I'll be witing for file sir tnx |
How many progress eMMC? |
