09-23-2014, 11:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | <<<< ATF NETWORK SERVICES SUSPENDED on OLD EXE >>>> @ALL ATF END USERS Right now we will be changing servers for ATF Network related Services. From Today, September 23, 2014, all OLDER ATF EXE will no longer work for ATF Network Services. Only ATF 11.70 PRE-FINAL Beta and Future Versions will work. Here is ATF 11.70 PRE-FINAL Beta: AdvanceBox.exe <---- PRE-FINAL BETA Just put this file to: C:\AdvanceBox Turbo Flasher\ If you find any "NETWORK" related problems, please post here. @ALL ATF CREDIT RESELLERS Please contact gsmfun on Sonork (100.33333) so that you will get the new RESELLER ACCESS Link for the new server. The old RESELLER/DISTRIBUTOR Access will no longer work. All Login Credentials will be saved... only URL will change Last edited by Advance-Box; 09-23-2014 at 11:55. |
The Following 12 Users Say Thank You to Advance-Box For This Useful Post: |
09-23-2014, 12:19 | #2 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Hindu-stan the land of Hindus
Member: 2253673 Status: Offline Thanks Meter: 61 | Thanks for this valuable information . Please add MTK phone in upcoming update |
The Following User Says Thank You to Pratap Sing For This Useful Post: |
09-23-2014, 16:40 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | activation also not done message come again and again. Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software |
09-23-2014, 17:14 | #8 (permalink) |
Member: 570093 Status: Offline Thanks Meter: 1,067 | @Yudi when i direct place new exe then no need activation .then i unistall and reinstall 11.60 then replace with new Exe after that need activation for Pc. |
09-24-2014, 07:39 | #11 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Vojvodina Age: 45
Member: 44395 Status: Offline Thanks Meter: 7 | ATF 11.70 Big box invalide response to a server Sir I have a same problem i installed a new .exe 11.70 on a 11.50 but nothing changed, invalid response again! Advance Turbo Flasher Found ================================================ Driver Version : 00020422 Library Version : 00030119 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.70 AdvanceBox SN : EF714B0396A0783C915C7C7F Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ |
