10-14-2014, 23:58 | #77 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | problem solve with this trick You will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder |
The Following User Says Thank You to sefiu1 For This Useful Post: |
10-17-2014, 14:16 | #79 (permalink) | |
Freak Poster Join Date: Jan 2014
Member: 2100924 Status: Offline Thanks Meter: 19 | Quote:
OPEN_SSL_64_BIT > 2 Dll ( libeay32.dll, ssleay32.dll ) C:\AdvanceBox Turbo Flasher\ libeay32.dll, ssleay32.dll Not OK huhuhu | |
The Following User Says Thank You to zintung2911 For This Useful Post: |
10-17-2014, 17:44 | #80 (permalink) |
Freak Poster Join Date: Nov 2011 Location: GSMHOSTING
Member: 1691378 Status: Offline Sonork: 100.1645448 Thanks Meter: 141 | Suppoters please help My box is already activated with network account and jtag But today it says You need 49 credits to activate network account and atf box is not activated for jtag |
The Following User Says Thank You to AC-GSM971 For This Useful Post: |
10-18-2014, 08:07 | #82 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Rangamati, Bangladesh Age: 40
Member: 1089621 Status: Offline Sonork: kk Thanks Meter: 62 | Nokia 105 RM-908 Flashing Error Pls Help Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-908\rm908_004.350 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00000000~0x0001FFFE ERROR: Erase IMAGE Block Failed !!! Flashing ERROR |
The Following User Says Thank You to konok.kk For This Useful Post: |
10-18-2014, 12:19 | #83 (permalink) |
Insane Poster Join Date: Jan 2013 Location: sylhet,bangladesh.......?
Member: 1872574 Status: Offline Sonork: 100.1625986 Thanks Meter: 28 | ATF_v11.70_Full_Installer - Download - 4shared - Linus Hernandez ATF Offcial Support Area / file-support / ATF Full Installer / ATF_v11.70_Full_Installer.rar gd update nice work new suport............................... |
10-29-2014, 08:33 | #84 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
10-31-2014, 07:30 | #86 (permalink) |
Junior Member Join Date: Oct 2014 Location: UAE
Member: 2275864 Status: Offline Thanks Meter: 0 | Hi, I am tryin.g to activate atf software but I could not. It says that the server is busy. Could you please help me out, when I would be able to activate it. thanks faissy |
10-31-2014, 09:02 | #87 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
10-31-2014, 09:05 | #88 (permalink) | |
BR allumts | |
11-05-2014, 16:11 | #90 (permalink) |
Insane Poster Join Date: Feb 2004 Location: KSA, Al-jouf
Member: 53180 Status: Offline Thanks Meter: 11 | atf nitro takes long time in booting what is the problem with my atf nitro..it takes time in booting atf exe....yesterday seems ok...only now....i have the latest atf exe which is 11.70...it takes 4 minutes in booting...whats the problem...i already reinstall and install the latest exe... |
