10-02-2010, 20:01 | #1 (permalink) |
Registered User Join Date: Sep 2006 Location: lby
Member: 342145 Status: Offline Thanks Meter: 26 | c1 [Problem Solved October-4-2010] VBATT OFF ... VBATT ON Setting VBATT Done!... Booting Phone... ERROR: Phone did not Boot !!! Make sure that you plugged the cable to the RJ-45 Port Marked << EXTENSION >> ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE Try booting this phone with "Live Phone" option Check the option beside the "Scan Phone" button Flashing ERROR |
10-03-2010, 03:55 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mr__gsm Have you flashed other Infieneon Phones (1616, 1202, 1280, 1800) before with this Box? Have you verified this pinout? For Problems with the EXTENSION PORT (the left side RJ-45 Socket) You can fix by the "Update EEPROM Button" in the "Product Support" --> "Box Tools". Make sure that only ATF is connected to your PC USB Port when you click Update EEPROM Button. Otherwise, it will be very problematic. |
10-03-2010, 10:31 | #5 (permalink) |
Member: 342145 Status: Offline Thanks Meter: 26 | Advance-Box ok working box after Update EEPROM see post ________________________________ ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_003.000 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: C237 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2140288 bytes Data Checksum: AD73 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_003.00ic PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003F897E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2001280 bytes Data Checksum: 69CB Uploading Data Blocks to phone... ______________________________ what is propl |
10-03-2010, 11:19 | #7 (permalink) |
Member: 342145 Status: Offline Thanks Meter: 26 | after remove cable & flash VBATT OFF ... VBATT ON Setting VBATT Done!... Booting Phone... VBATT OFF ... VBATT ON Setting VBATT Done!... Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted after 2 attempts... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_003.000 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: C237 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2140288 bytes Data Checksum: AD73 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_003.00ic PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003F897E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2001280 bytes Data Checksum: 69CB Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm6890_nai03.00ic CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F013BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 332736 bytes Data Checksum: 7BCF Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:23 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 03.00 31-08-10 RM-689 (c) Nokia IMEI: 353794044992411 Product code : 059B341 Model : ð Mastercode : 0304073341 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 Asic : 11 Provider : Default Test Operator FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK ____________________________________ now thanks Advance-Box Product Manager |
10-03-2010, 19:30 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @GSM Style Now is OK,, after write EEPROM 1 time,, Infineon will be OK like you see the threadstarter. B.R. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
