06-03-2014, 09:16 | #1 (permalink) |
Registered User Join Date: Feb 2009 Location: in my mind Age: 35
Member: 962014 Status: Offline Thanks Meter: 7 | Can I Jtag nokia xl - (SOLUTION INSIDE - GET NEW AFP for NOKIA XL) i cant find AFP BOOT FILES for Nokia XL my device dead ! pls upload nokia XL AFp files Last edited by gandolf007; 06-03-2014 at 09:25. |
The Following User Says Thank You to gandolf007 For This Useful Post: |
06-03-2014, 13:05 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
It is here in 4shared folder NOKIA_XL_RM-1030_FULL_BOOT_1.1.0.6 - Download - 4shared - Linus Hernandez l will upload it to ATFJ server later... for now download from link above. B.R. | |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
06-03-2014, 13:20 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Now Also available via the ATFJ Server.... Click ---> Help ---> Updates ----> Check Updates you will find it there. B.R. |
06-03-2014, 13:49 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gandolf007 This version 1.1.2.20 is for REVISION 2 phones only. It will not work on non REVISION 2 phones, since boot is different. If your Phone's Product Code is not in list below, it means your phone is NOT REVISION 2 and this firmware is NOT COMPATIBLE with your phone. Code: 059W161: RM-1030 NDT APAC ID ERA V2 059W162: RM-1030 NDT APAC ID PAR V2 059W163: RM-1030 NDT APAC ID TRI V2 059W159: RM-1030 NDT APAC KH V2 059W160: RM-1030 NDT APAC MY V2 059W158: RM-1030 NDT APAC PH V2 059W157: RM-1030 NDT APAC TH V2 059W156: RM-1030 NDT APAC VN V2 059W168: RM-1030 NDT EURO KZ V2 059W166: RM-1030 NDT EURO PL V2 059W164: RM-1030 NDT EURO RU V2 059W165: RM-1030 NDT EURO TR V2 059W167: RM-1030 NDT EURO UA V2 059W180: RM-1030 NDT IMEA AE V2 059W181: RM-1030 NDT IMEA BD V2 059W173: RM-1030 NDT IMEA EG V2 059W171: RM-1030 NDT IMEA IN V2 059W174: RM-1030 NDT IMEA KE V2 059W179: RM-1030 NDT IMEA KW V2 059W175: RM-1030 NDT IMEA NG V2 059W177: RM-1030 NDT IMEA OM V2 059W170: RM-1030 NDT IMEA PK V2 059W178: RM-1030 NDT IMEA QA V2 059W176: RM-1030 NDT IMEA SA V2 If you badly need to use 1.1.2.20 on a NON REVISION 2 Phone, then UNCHECK 7 BOOT Partitions before clicking the FLASH Button in ATF Software...: xxxxxxx_emmc_appsboot.mbn xxxxxxx_emmc_appsboothd.mbn xxxxxxx_oemsblhd.mbn xxxxxxx_oemsbl.mbn xxxxxxx_qcsblhd_cfgdata.mbn xxxxxxx_qcsbl.mbn xxxxxxx_fat.bin Then you can flash the firmware to your phone. Post Results after you have fixed your Phone. B.R. Last edited by Advance-Box; 06-03-2014 at 13:55. |
06-09-2014, 09:44 | #6 (permalink) |
Member: 962014 Status: Offline Thanks Meter: 7 | problem with j tag nokia xl i downloaded NOKIA_XL_RM-1030_FULL_BOOT_1.1.0.6 afp files and when i push restore button ، say below error in picture !! jtag chain is ok ! qualcomm cdma technologies msm drivers is installed! whats problem ? Last edited by gandolf007; 06-09-2014 at 09:53. |
06-09-2014, 15:22 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Hi, Please Download the FIXED AFP file for working with latest ATF EXE. (Original Nokia XL AFP was not compatible with latest EXE) So here, you will see it... Here is my Test Result on latest AFP and latest EXE build 4551... Here is my wired Test Phone... B.R. |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
06-10-2014, 10:47 | #11 (permalink) | |
Because you are trying to flash V2 firmware to your NON V2 Phone. I already explained that this will KILL your phone. If you really want to flash V2 firmware, then the safest way is to just flash the KERNEL (SYSTEM) partition. For your dead phone, for full recovery follow steps: 1. Repair Boot via JTAG * I uploaded 1.1.1.0 and 1.1.1.4 boots for RM-1030 to ATFJ Server already so you can use them if you like 2. Flash phone via USB Recovery with Firmware Version preferably same as Boot Version used when you repaired via JTAG. 3. Phone should be 100% working now... If you want to flash V2 firmware at this point, then 4. Flash V2 Firmware SYSTEM Partition Only. Phone will be working and with latest kernel inside... But you know, in reality 1.1.1.4 is newer than 1.1.2.20 So better use 1.1.1.4 instead and skip step 4 above | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-29-2014, 19:49 | #12 (permalink) | |
Junior Member Join Date: Jun 2014
Member: 2213792 Status: Offline Thanks Meter: 0 | Quote:
What difference nokia xl and nokia xl V2 in hardware&saftware? | |
07-29-2014, 15:20 | #14 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Nairobi,Kenya
Member: 390521 Status: Offline Thanks Meter: 57 | @ Advance-Box please share the test points to use(for RM-1030) nokiaXL.. i saw in your earlier post you said they resemble that for 510..RIGHT?..i find it easy to use molex ( i intend to use molex) |
