Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-23-2014, 10:02   #1 (permalink)
Member: 1774414
Sonork: 100.1594422
Thanks Meter: 4
Cm flare s100 error in atf jtag
hi i have cm flare s100...
i try to flash with my new activate atf jtag...
but i get this error..
Default language ID 0x0409, LR 11
JTAG Interface Connected, S/N 0x8AC368F6
Resetting and Exploring JTAG chain...1 Device(s)
Device #1 ID 0x007730E1 IR4
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 11/26/2013 11:00:00 AM
Phone Type : Cherry Mobile Flare (S100)
CPU Type : Qualcomm MSM8225
Storage TYpe : eMMC 4GB
Boot Package : Full Factory Restore
Android Version: 4.1.2 (Jelly Bean)
Kernel Version : 3.4.0
Build Number : TBW592250_8572_V006045
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
8. Full Factory Restore takes 40 minutes to Finish
Restore Boot...
Waiting for Device Connection 20 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting eMMC #1 ID...65646F4D204D4F524E460001000000F0
Flash Description: Unk. 0x65 M MORN, 128 MiB, SN 00010000, Unk 1997
Partition Config: No boot enabled, Boot ACK OFF (0x00)
Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
Testing Device Memory...OK
Sending Flash Loader...OK (91447 Op/Sec)
Restoring Partition #1...Flash Write Error at 0x00000000, Loader Error, Code 0x71
please anyone help me
this is the reason why i activate my atf
Old 09-23-2014, 10:39   #2 (permalink)
Member: 1774414
Sonork: 100.1594422
Thanks Meter: 4
up for this tread please help me....
Old 09-23-2014, 11:21   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@mizuke45
What ATFJ are you using?
Please download and use the latest version here:
ATF_JTAG_v1.0.11_Full_Installer.exe
Also, many CM Flare have bad eMMC... I am not sure if you eMMC is bad, but this looks like it does not accept data writes to it.
Old 09-23-2014, 11:43   #4 (permalink)
Member: 1774414
Sonork: 100.1594422
Thanks Meter: 4
yeah i think my emmc is bad because i see the others thread is same us my problem..
anyway thanks for ur fast reply....
Old 09-23-2014, 12:04   #5 (permalink)
Member: 651945
@mizuke45
Maybe there is a way to fix your phone.
Asan location mo?
Old 09-24-2014, 03:45   #6 (permalink)
Member: 1774414
Sonork: 100.1594422
Thanks Meter: 4
d2 poh manila bossing...
i want want to ask why my atf can't login to account...
always get this log
ATF Network Error İnvalid Response
Old 10-03-2014, 05:52   #7 (permalink)
Member: 1494304
Sonork: 100.1606186
Thanks Meter: 108
up this thread
any solution for this kind of error
atf jtag version v1.0.11 same error
TIA
Old 10-03-2014, 06:23   #8 (permalink)
Member: 1856544
Sonork: 100.1606364
Thanks Meter: 23
Originally Posted by warshock View Post
up this thread
TIA
emmc damage bro 128 mb only,u need 3.61 gb emmc detection before proced to flashing dump
The Following User Says Thank You to chance^09 For This Useful Post:
Page generated in 0.27091 seconds with 8 queries
