07-05-2012, 11:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: In My ThinkPad
Member: 756569 Status: Offline Thanks Meter: 185 | E5 flashing problem, dead !!! Code: Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0CA0000A ID DWORD 1 : C3A40344 ID DWORD 2 : 82A42A7E ID DWORD 3 : A04D0F66 ID DWORD 4 : BC193FE9 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum BD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 012.014.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 04 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 86 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0000 DevID :0000 ExtID :0000 RevID :0000 Flash Descriptor Manufacturer Code : 0000 Device ID : 0000 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00000000 (0 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request No PAPUBKeysHash Returned Scanning Simlock Applet Type... ERROR: FBUS Boot FAILED Code: ATF Software Version v8.95 ATF Box FBUS Flash Started... Number of Image Files: 4 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-632\rm632_081.004_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 478 Entry Point : 0x01FD Page Format : 128K Maximum Page Size : 0x00040000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0CA0000A ID DWORD 1 : C3A40344 ID DWORD 2 : 82A42A7E ID DWORD 3 : A04D0F66 ID DWORD 4 : BC193FE9 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum BD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 012.014.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 04 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 86 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0000 DevID :0000 ExtID :0000 RevID :0000 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 Certificate 5 Name : PARTNERC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B STORE_CERTIFICATE_REQUEST_BB5 : Error BB5_STORE_CERTIFICATE REQUEST FAILED ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 03B20000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 03BC0000 Size : 0ABC0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0E780000 Size : 109C0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A000003B20000000000040000000203BC00000ABC000000000008000000010E780000109C00000000000A000000011F140000003C000077 DDR PROTOCOL ERROR: Phone did not Ack !!! ProcessPartitionInfo_DCT5 : Error Operations Failed.... Flash Log With #Skip HW ID Check # Skip Cert # Factory Reset Code: ATF Software Version v8.95 ATF Box FBUS Flash Started... Number of Image Files: 4 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-632\rm632_081.004_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 478 Entry Point : 0x01FD Page Format : 128K Maximum Page Size : 0x00040000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0CA0000A ID DWORD 1 : C3A40344 ID DWORD 2 : 82A42A7E ID DWORD 3 : A04D0F66 ID DWORD 4 : BC193FE9 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum BD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 012.014.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 04 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 86 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0000 DevID :0000 ExtID :0000 RevID :0000 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request No PAPUBKeysHash Returned ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 03B20000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 03BC0000 Size : 0ABC0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0E780000 Size : 109C0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A000003B20000000000040000000203BC00000ABC000000000008000000010E780000109C00000000000A000000011F140000003C000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0E77FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : rm632_081.004_prd.core.fpsx Total blocks to write : 478 DDR PROTOCOL ERROR: Phone did not Ack !!! Flashing FAILED BB5_WRITE_FlashFile Operations Failed.... |
07-05-2012, 11:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @nazrul islam Show logs when trying USB Flashing... Also, DO NOT UNCHECK BACKUP RPL because I can see in your logs that you always uncheck them... You don't want to save Phone's IMEI? |
The Following User Says Thank You to Advance-Box For This Useful Post: |
07-05-2012, 14:06 | #3 (permalink) |
Member: 756569 Status: Offline Thanks Meter: 185 | Thank You Sir For Your First Replay. This Is Usb Flash Log With # Backup Rpl # Backup Simlock Code: Number of Image Files: 4 Processing Image File : rm632_081.004_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 478 Entry Point: 0x01FD Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm632_081.004_C00.01_DEFAULT_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 38 Entry Point: 0x0139 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm632_081.004_34.01_APAC_QW2_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 202 Entry Point: 0x0139 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm632_081.004_U005.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 97 Entry Point: 0x0139 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0CA0000A ID DWORD 1 : C3A40344 ID DWORD 2 : 82A42A7E ID DWORD 3 : A04D0F66 ID DWORD 4 : BC193FE9 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: BB5_ALGORITHM_LOADER NOT FOUND! Flashing Failed.... Booting/Flashing Failed... Please Try Again... |
07-05-2012, 20:50 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Code: SearchForBootstrap_DCT5 : No Error - 0 (0x00) ERROR: BB5_ALGORITHM_LOADER NOT FOUND! Flashing Failed.... Booting/Flashing Failed... Please Try Again... Code: Pabub KEY Request No PAPUBKeysHash Returned Scanning Simlock Applet Type... ERROR: FBUS Boot FAILED Full ERASED the phone before... if its just erased device, then there should not be any problems on flashing... Even you use FBUS or USB cable. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
