09-09-2013, 09:39 | #1 (permalink) |
Freak Poster Join Date: Aug 2011 Location: Uganda Age: 42
Member: 1640892 Status: Offline Sonork: 100.1651734 Thanks Meter: 25 | Nokia 1oo locked sreenshot MCU: V 03.60 17-11-11 RH-130 (c) Nokia IMEI: 354587054807845 Product Serial Number: 6408CBEBI Product Code : 059P270 Module Code : 0204875 Basic Production Code: 059N126 PPM SW Version : V 03.60 17-11-11 RH-130 (c) Nokia AE ADSP Version : p V 03.60\n17-11-11\nRH-130\n(c) NMP\nae MCU SW Version : V 03.60 17-11-11 RH-130 (c) Nokia HW Version : 3051 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BARACOAv90 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 2280200000000000 PROFILE_BITS : 8000000000040002 ASIC : 11 PROVIDER : Sunrise Communications AG;Switzerland [GSM] Block [1] 1:Close Block [2] 1:Close ST_LCD_TEST : PASSED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... br barugatec |
09-09-2013, 10:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Decrypt PM120 Hash from this phone, if phone is 20-digit then ATF will not make LBF files, if phone is 15-digits then files will be made and you can upload ATF Server 35xxxxxxxxxxxx.job file for 20 ATF BF Credits in order to get Master Code of this phone. BR |
09-26-2013, 14:30 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | i have bought Nokia 100 / 101 FFS PRO2 Fbus Cable , i cant not scan the Phone there are 3 settings, MT , Cyclone , UFS, i select UFS i Plug the cable in Extension Port, and try 5,1k, 7,5k, 10k it will not work. some can help ? Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... ERROR: Phone did not Boot !!! Make sure that you plugged the cable to the RJ-45 Port Marked << EXTENSION >> ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE Try booting this phone with "Live Phone" option Check the option beside the "Scan Phone" button Flashing ERROR ERROR : PHONE READ INFO FAILED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
11-26-2013, 08:53 | #6 (permalink) |
Member: 753732 Status: Offline Thanks Meter: 252 | sir my old advanca box was damaged, i have bought new ATF nitro. i want unlock Nokia 100 it hangs on : SBL Successfully Sent... Code: 08:48:48 : Waiting for Phone to Go Online... 08:48:49 : Elapsed Time: 1s 08:48:50 : Elapsed Time: 2s 08:48:50 : ERROR: Read PM Failed 08:48:50 : NO PHONE DETECTED/PHONE DISCONNECTED 08:50:23 : 08:50:24 : MCU: V 04.30 18-09-12 RH-130 (c) Nokia 08:50:24 : IMEI: 35895xxxxxxx 08:50:24 : Product Serial Number: 1FF9975BH 08:50:24 : Product Code : 059L5W8 08:50:24 : Module Code : 0204881 08:50:24 : Basic Production Code: 059R191 08:50:24 : PPM SW Version : V 04.30 18-09-12 RH-130 (c) Nokia AD 08:50:25 : ADSP Version : p V 04.30\n18-09-12\nRH-130\n(c) NMP\nad 08:50:25 : MCU SW Version : V 04.30 18-09-12 RH-130 (c) Nokia 08:50:25 : HW Version : 1001 08:50:25 : UEM Version : 1328 08:50:25 : UPP Version : 8850 08:50:25 : LCD Version : TPO:BARACOAv92 HX5081 08:50:26 : ********** SIMLOCK INFO ********** 08:50:26 : CONFIG_DATA : 2620700000000000 08:50:26 : PROFILE_BITS : 8000000000040002 08:50:26 : ASIC : 11 08:50:26 : PROVIDER : O2 (Germany) GmbH & Co. OHG ;Germany [GSM] 08:50:26 : 08:50:26 : Block [1] 1:Close 08:50:26 : Block [2] 1:Close 08:50:26 : ST_LCD_TEST : PASSED 08:50:26 : 08:50:30 : 08:50:30 : Make sure you have installed the 08:50:30 : COMPLETE Flash Package for this Phone... 08:50:30 : 08:50:30 : Goto "Settings" --> "Nokia Settings" and verify that 08:50:30 : the Folder where you installed your Flash Files are 08:50:30 : in the "PRODUCT PATH TO SCAN" List... 08:51:53 : VBATT Powering Down <<<< 08:51:55 : VBATT Powering Up >>>> 08:51:56 : SET VCCIO Level Done 08:51:56 : SET BSI Load Done 08:51:56 : 08:51:56 : Booting Phone... 08:51:56 : CPU ID Response: A200341100 08:51:56 : CPU Type: XG110 2.1B 08:51:56 : Phone Booted at after First attempt... 08:51:56 : 08:51:56 : ****************************************************** 08:51:56 : START INFINEON BUS CHECK 08:51:56 : ****************************************************** 08:51:56 : 08:51:56 : 08:51:56 : Sending PBL 37888 bytes... 08:51:56 : PBL Successfully Sent... 08:51:56 : Unique Data: A0D08421062005829202 08:51:56 : Sending SBL 65024 bytes... 08:51:57 : SBL Successfully Sent... |
